Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I can't find my manual, and I need to unhook my gas range. How
How do you easily unhook a gas range?
  • 8,197 Answers
Ranges are real easy to install. Here is a manual to instell them. go to page 42 for the info. It might not be your model but the all hook up the same.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-85131.PDF
Good Luck and Please Rate
Posted on Jan 22, 2009
  • Jyackle5
    Jyackle5 Jan 22, 2009
    Are you that nieave. All that you have to do it reverse the install that is in the manual. or do you want a step by step way to do it. i so I will walk you through on a chat
  • Jyackle5
    Jyackle5 Apr 08, 2009
    Did you get it done or what
I have a 1976 Gaffers & Sattlers slide in range I want to replace. Any idea how to remove it? Thanks
this taken from ehow site:
Slide-in ranges and freestanding ranges use the same installation techniques, with one minor difference: the slide-in range rests on the edge of your counter top. Removing a slide-in range is not difficult but will require a friend to assist. Removing the storage drawer from the slide-in range first will give you access to the power cord and gas shut-off valve, if your unit uses gas
Instructions
    • 1 Pull the bottom storage drawer out as far as it will slide. Lift up the front of the drawer and unhook the back of the drawer from the drawer guide. Pull the drawer away from the range.
    • 2 Reach under the slide-in range and unplug the power cord from the wall outlet. Turn the gas valve to the off position on the house line coming from the wall.
  • 3 Lift the top of the slide-in range with the assistance of your helper, and pull the range forward enough that you can access the back of the range.
  • 4 Go behind the range and locate the connection between the house gas line and the range gas line. Disconnect the flexible gas line from the house gas line with a pair of channel lock pliers or a pipe wrench.
  • 5 Lift up on the rear of the slide-in range while your partner lifts the front. Slide the range out of the cabinet opening and out of the house. Lifting the unit will prevent unnecessary damage to your counter tops.
  • Read more : http://www.ehow.com/how_5959888_remove-slide-range.html
    Jan 03, 2015 | Kitchen Ranges
    The gas range spark igniter does not work. I have a new part. How do I access the range top to replace it?
    The whole top of the stove lifts off. You need to pull it out from the wall, unhook the gas, loosen and remove any screws that are on the back that hold the back to the top section. Open the stove doors and look up from the bottom to see if there are screws holding the top down, take those out and lift the top off. You can then access all the parts for the burners.
    Oct 31, 2014 | Kitchen Ranges
    Whirlpool range XFG361LVQ2 manual
    I need natural gas orfice for this model whirlpool gas range xfg361lvq2 to convert it from lp gas to natural gas.
    Mar 22, 2013 | Whirlpool Kitchen Ranges
    I have a Kenmore Gas range. The major stove top no longer gets really hot and we are having trouble boiling large pots of water. It used to be able to boil a large pot of water easily. I would like to...
    This could be a problem with the gas regulator, gas supply pressure or the burners need to be cleaned. Here are the cleaning instructions for the burners. If you are still having problems with the burners I would recommend having the gas pressure & regulator checked.
    Jan 16, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
    Amana Model ACS3350AS Oven temp is 25 degrees hoter than display. What do I need to repair it? How do I find a manual for this. This came with the house.
    Oven temperature can be adjusted for a maximum of 35 degrees farenheight.
    Refer to the page 11 of your owner's manual.
    A PDF version of the owner's manual can easily be find at
    http://shop.amana.com
    Jan 11, 2011 | Amana ACS3350 Gas Kitchen Range
    Need burner base replacement for XL44Self-Cleaning Gas Range model IGBP34GEP2AD - need part, cost and location. Thank you. Pat L.
    That is not that hard to fix and you can easily buy the parts yourselfonline...
    Here is a tip that will help you with the online buying...
    How to Buy Appliance Parts Online
    heatman101
    Oct 20, 2009 | GE Spectra JGBP35 Gas Kitchen Range
    The oven door locked and won't open, please help
    Push and hold the cancel/off button for 4 seconds.
    See if a code appears. If so write it down.
    Turn off the gas supply to the range.
    Unplug the range.
    Pull the range out from the wall.
    Remove the top and bottom rear panel covers.
    On the left side just below the rear burner is the latching mechanism.
    Unhook the actuator rod from the mechanism and open your oven.
    Do you have a code to report?
    Mar 09, 2009 | Whirlpool GS460 Gas Kitchen Range
    HELP
    DO NOT UNHOOK THE GROUND!!! If it is a newer range it needs a 4 wire circuit ( 2 hots, neutral and ground). The range needs 220 volts for the heating elements and 110 volts for the controls. Call an electrician!!!
    Dec 26, 2008 | Magic Chef CEL1110 Electric Kitchen Range
    Oven
    The lock spring unhook back cover must open / gas must be shut down. before open back cover., spring might cut spring hook corroded possibility door door lock malfunction.
    Jan 03, 2008 | Hotpoint RGB745 Gas Kitchen Range
    Frigidaire convection free standing range
    new ranges come set for natural gas. in the installation instuctions there should be instruction for converting the range to lp. some models require that the orafice for the burners be replaced as part of the coversion, if so the there should be a pack of them with the new range. others you just have to tighten the orafices that are all ready in the range. you installation guide will tell you which one you have to do
    Nov 24, 2007 | Tappan MGF500PBW Gas Kitchen Range
    GE Profile Spectra JGBP90 Gas Kitchen Range Logo
    332 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
