Question about Samsung Washing Machines
How to solve the error Uc in washing machine samsung Wf8690ngv
5 Suggested Answers
Maanita
  • 1142 Answers
SOURCE: washing machine
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Posted on Jun 23, 2008
FAV6800AWDIY
  • 526 Answers
SOURCE: code uc and not spin
Most likely a very common clutch malfunction possibly brought on by a leaky Tub Seal.
See if this post will help Clutch Fix
If you have other questions I will try to help.
Rich
Posted on Jul 11, 2010
  • 6277 Answers
SOURCE: I have a Samsung Automatic
As it's only 2 days old I suspect it has not been installed 'balanced'. If what follows does not cure it CONTACT YOUR VENDOR. Anything else could invalidate whatever warantee/guarantee you have!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 14, 2011
Daniel S
  • 4323 Answers
SOURCE: What is mean Uc error
Hi
If you are sure that the error code is UC not UE then it means unbalanced condition & indicates an issue with either the clutch assembly or the control board that is bad. You can leave the washer unplugged for 15 minutes to see if the error returns. Please post back with some more details about the issue for further assistance.
Daniel
Posted on Sep 18, 2011
Please how do I resolve error code UC on my Samsung diamond drum washing machine?
Washing machines have computers. They are literally designed for no ''DIY.'' Error code would likely mean ''new computer needed.'' Either way, you need a laptop with a factory testing program installed in it That's how these guys work nowadays. The laptop tells them what to do next, and you (and I) can't have one.
Aug 15, 2015 | Samsung Washing Machines
My sumsung washer is showing an error (Uc) dont know what to do with it, if you have a solution it will be appreciable.
The UC error code represent a malfunctioning main PBA or a power fault related to an electrical power supply that is incompatible with the Samsung washing machine.
Contact Samsung service department!
Jan 02, 2015 | Samsung WF337AA Front Load Washer
Vibrating and banging
how to fix error Uc samsung automatic
Feb 13, 2014 | Samsung Washing Machines
Samsung washing machine error code uc
Since you are receive UC error code, Please call the after-sales service.
Source: Samsung CS Portal
May 24, 2013 | Washing Machines
What is mean Uc error in samsung washing machine WF8550NHW model?
my samsung washing machine paused becuase of the power voltage is not instable. what should i do?
May 12, 2010 | Samsung Washing Machines
I have a top loader and i have been getting an LL error
I would next check the TDS. Are you taking the error in Spin Cycle of the wash cycle?
Let’s do this quick check and see what you get for test results.
Tub Displacement Sensor Diagnostics check. This test is done with the washer lid raised see page 19 of the SM for the details.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
What are your results?
Rich
Mar 14, 2010 | Maytag Neptune FAV6800AW Top Load Washer
UC code, doesn't spin out correctly
on last spin washing machine will not spin all the water out.
May 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Uc code error
uc code means unbalanced condition. My research shows this as being an unbalanced load or a faulty control board.
Make sure your load is balanced, otherwise you may have to replace the control board.
Jun 04, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
easy alberta
easy alberta
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
