Question about Radio Communications
Bad thermostat Have to set knob to 450 but heats to 350 will not maintain temperatures looking for replacement thermostat for Gas range!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 54 Answers
Repair clinic.com has you part
Posted on Feb 28, 2013
My wolf red ch-6-29-ft22l-lbl the oven has to b set at 425 to maintain 350 is this a tstat problem or gas valve issue ?. when set on 350 the flame cuts back at 275 and holds there..
it could be a thermostat problem as it controls the gas valve settings
As it is gas , call in the gas technician for the unit and have it diagnosed and fixed properly
Mar 07, 2016 | Kitchen Ranges
How to light the pilot
From looking at this parts list, I see that the gas valve is powered by a thermal generator. The generator holds open the gas valve AND operates the gas valve solenoid. Their are 2 thermostats one of which determines the desired cooking emt and another which is a limit that kills the operation if the oil exceeds 450 f. To light this puppy you move the gas valve selection knob to the PILOT position. Press in on the knob and light the pilot with a match. Keep holding down the knob till the flame stays on without the knob being pressed. Advance the knob to the ON position once you have the pilot lit. Most common problems for this rig: Bad thermal generator/thermopile. Weak thermal generator holds the safety pilot on till heat is called for then shuts down when the solenoid is energized. Bad solenoid operator on gas valve (non replaceable you must buy a new valve) Bad thermostat or limit. Pretty easy fix if you like getting greasy. LOL
Aug 29, 2012 | American Range AF45LP Deep Fryer
My gas oven overheats and burns my baking. With one temperature test it was set at 300 and within thirty minutes the temperature was reaching 400 and leveling off. However, the next test with the oven at...
bad thermostat.....buy new at lowes .....its inside the oven.....usually at the top of oven..looks like copper rod with copper wire ....easy to change...buy at lowes or homedepot
Nov 16, 2009 | Tappan TGF320 Gas Kitchen Range
Erratic oven temperatures adjusted the thermoatat as per instructions in manual no change
if adjustment of the screw behind the oven knob did not help:
replace the oven thermostat the part can be found at: searspartsdirect.com
Sep 05, 2009 | Kenmore Kitchen Ranges
Temperture in wall oven is much hotter then setting
have it calibrated, usually behind the knob when removed,
or more easily remember this and get a little oven thermometer , Theyre better anyways and the stat if not junk will maintain desired setpoint without much variance
Aug 25, 2009 | Whirlpool GS475LEKS Gas Kitchen Range
Too hot temprature is incorrect
yes, in the senter of the shaft of the oven knob.
Dec 02, 2008 | Maytag MGR5750 Gas Kitchen Range
Oven temp set at 350. only heated to 310 after 1 hour! Set to 390 before reached 350. What to do?
Use an oven thermometer Try to figure out if by setting it to 390 it will maintain 350 accurately. (A 25 degree change while it cycles is normal. It will probably overshoot before going off and undershoot a little before cycling on.) If so the thermostat has just drifted. Pull off the control know and look usually there is an adjustment on the shaft to change the temp showing on the knob. set it up 50 degrees. If the knob can't be changed just know that you have to adjust yourself. If it won't maintain a steady temp the thermostat is bad and will need to be replaced. The thermostat will be over $100 it may not be worth it. If this is a computer controled unit (pushbutton temp selection) the sensor needs to be replaced. This is a lot cheaper than a thermostat.
Jul 03, 2008 | KitchenAid Kitchen Ranges
Whirlpool 465 oven temp
Go to Calibration mode and adjust the temperature up by 10, 20 or 30 degree. This is in each manual.
Jan 11, 2008 | Whirlpool GS460 Gas Kitchen Range
GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Sep 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Radio Communications Logo
21 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
