Question about Water Heaters
It is not a refridgerator, it's a hot water heater!
It is leaking behind the panel that covers the temp cantrol and other assemblies, it's leaking in the back of the piece that has the white and black wire going into it.
    New Friend:
  • 51 Answers
The element is right behind that panel,sounds like that is whats leaking. The elements just screw in or have a plate that compresses againt the element and gasket. Either way sound like a simple fix be carefull those wires are 240 volts most of the time inless its a small water heater.
Lowes has the elements just shut off the power and drain the heater before you start. If its an older heater it will be rusted any may not come out,just be ready to a buy new heater if you cant remove the element and damage the heater due to all the rust. Good luck
Posted on Jan 12, 2013
  • 37 Answers
SOURCE: GE Profile Smart Water Heater leaking at top/no hot water
Hi, has your problem been solve yet? please respond
Thanks
Posted on Nov 23, 2008
rick_stokes_
  • 61 Answers
SOURCE: No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Posted on Sep 19, 2009
Testimonial: "Thank you very much, Rick! "
pipesster
  • 20 Answers
SOURCE: My hot water heater has a red and a black wire,but
Your 220v hot water heater does not need the neutral(white) wire coming in. Bare wire goes to ground -green headed screw. Black goes to black, Red goes to red. White gets teminated with a wirenut or some electrical tape.
Posted on Jan 25, 2010
  • 3 Answers
SOURCE: Our Rinnai tankless water heater is producing water as hot as pre
Power outage will reset Rinnai unit to that temperature. Read manual for more info.
Posted on Jan 26, 2010
SOURCE: wh 9L amtrol water heater..the
Amdrol makes indirect-fired water heater that gets heat from a boiler
http://www.amtrol.com/boilermate.htm
1) Pdf manual on amdrol website show a mixing valve that mixes cold water with the hot water so water temperature going to faucet stays the same:
http://www.amtrol.com/pdf/MC10169%20BMconstantempflyer.pdf
You set the temperature of the mixing valve.
You can also set up 2 sets of pipes ... one is connected to mixing valve that goes to sinks and tubs. The other pipe bypasses mixing valve sends hotter water to washing machine.
2) The manual for Amdrol:
http://www.amtrol.com/pdf/9040-586%2001_09%20BoilerMate%20Indirect%20IO.pdf
The new models has a temperature sensor that plugs into digital readout.
This is a thermistor sensor wire that can be ordered as repair part
3) Amdrol has e-mail address:
info@amtrol.com
4) You can post your question on a water heater forum
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Posted on Nov 12, 2010
Where do you turn the water temp up my electric water heater moderl SE50M12AAH
Behind a little cover at top & bottom of side of water heater. you will see the thermostat. Use a flat blade screwdriver to turn the dial to desired new temperature.
they will look like the pic below.
Feb 24, 2015 | Water Water Heaters
How to turn up the temp. on a Rheem mod. 82v52-2 hot water heater
To adjust the thermostat, turn off the water heater. Then remove the access panel(s) and any insulation. The access panels are above the drain valve. Take a small flat blade screwdriver and rotate thermostat dial pointer. (The lower temperature settings are to the right.) Replace the access panel(s) and insulation and then turn on the water heater. Do not remove the protective cover on the thermostat.
Wait for water to heat and then check the temperature at various faucets. Make sure to adjust the anti-scald temperature limiter at any faucet that may be accessed by a small child or adult who might be injured by high water temperatures. (Just put a thermometer in the flowing water. Check the faucet installation information. The high temperature limiter will be under/behind the handle for single handle fixtures.)
I hope this helps.
Feb 21, 2015 | Rheem Water Heaters
Turn temp higher
If this is an electric water heater, there generally is an upper & lower thermostat behind the upper & lower panel. Open the panels, and their will be a dial with temperature setpoints that you can change with a flat screwdriver. It may be a good idea to turn the power off before taking panels off and making adjustments.
Jan 15, 2015 | Water Heaters
Rheem rp4036m
Under the gas valve is a removable panel. On models of that era there should also be a second panel behind the first. remove both.
the pilot light should be clearly visible.
If no pilot, turn the gas valve to OFF. wait 60 seconds. locate the tubes from the gas valve to the pilot location. turn the valve to pilot, and with a long match or grill lighter lit, place flame at the pilot location and press down on the pilot button beside the main valve.
pilot should light. If not shut off the gas and call a technician. If yes, hold the pilot button for 60 seconds, then slowly release. Pilot should stay lit. If not, shut off gas and replace thermocouple, start relight sequence over. If pilot stays lit, replace inner cover and adjust temp to 120 deg. If heater fires up, replace outer cover. Done.
If heater does not light, replace gas valve or entire unit. Water heaters have a limited life expectancy, and if my recollection is correct your unit is 10yrs past warranty.
Dec 04, 2013 | Water Water Heaters
I have a 640dors reliance capacity40 water won't stay hot long(electric)
remove the two covers one high and one low and set the temp higher. This time of year with colder water comming in the house the water heater has to work harder to raise the temp of the incomming water. In the summer the incommong water is much warmer. 40 gal is a small water heater and you will only get about 15 gal of hot water with the ice cold water entering the water heater as you use the hot water. You can get a bigger water heater. even better is to go tankless and a have never ending hot water and save money at the same time.
Jan 10, 2013 | Reliance & 40 Gal Electric Mobile Home...
Water leaking from bottom of quick and hot dispenser only 18 mos old
I had the same problem. There is a 2 piece metal tank inside. The top and bottom of the tank are connected with screws & nuts, and there is a rubber o-ring between the two pieces. The grove for this o-ring is very shallow and it doesn't fit tightly, increasing the probability of misalignment during the assembly process. I was unable to fix the leak, IMHO the grove is too shallow and the o-ring is not thick enough. I decided it was poorly designed & trashed the unit.
Aug 26, 2011 | RTO Waste King AH-780-UL Quick&Hot Instant...
No hot water on electric but burning hot on lp gas,what can my problem be.
Need to confirm hydro to water heater, all switches breakers etc on, and check to make sure switch at back of water heater at connection box on as well. If power to back of water heater, then check for reset in center of ECO on back behind cover. If power going to element ( behind cover as well) then replace element. Be careful when removing cover on back. Shut breaker off at main panel until you can get cover off and ready to test voltage.
Feb 26, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Mt 6 gal. atwood hot water heater ignites but will not stop I put a new relief valve on it because it was leaking.
Excessive temperature from running too long will cause relief valve to open. If water temperature is too hot, thermostat & ECO should be changed. They are in behind that little foam cover where the letters are marked on cover. Check that they are up against tank good when you remove foam cover, as that may be the cause as well. They need to be held against tank, by the little coil spring and retainer. If they are against tank good, then replace them.
Dec 09, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Hot water not very hot..also seems low in pressure
pressure temp valve leaking
tank leaking
hot water line leaking
shut off water to tank and leave sit for 4 hours turn on water tap and test temp if hot you have a leak
Oct 17, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Combi boiler hot water far to hot.
Yes the temp can be adjusted, the dial is behind the cover. Turn off power before removing cover.
Sep 11, 2009 | Water Heaters
Water Heaters Logo
26 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
