Question about Video Game Consoles & Games
I accidentally plug my Wii that I got from US from 120v to 220v. I got the converter but I mistakenly plug it to the wrong voltage:(. I heard the poop sound. Did I burn the power adapter or the wii it self? Please help, I'm in Indonesia now. Thanks
    Novelist:
  • 159 Answers
You have most likely cooked the Wii itself, To check connect the correct power adapter to the correct system and in the correct power source ( 120v or 220v ) if it works all good if not you know you cooked it. If you are unable to test in this manner have it checked by a qualified technician.
Posted on Jan 12, 2013
4 Suggested Answers
  • 51 Answers
SOURCE: Wii power source probably broken
Plug something else into the adapter to make sure it works, if it works you may have blown the Wii's fuse which will need repair.
Posted on Jul 28, 2009
  • 85 Answers
SOURCE: Wii plugged to 220v oulet. Burning plastic smell on adapter only.
Probably the adapter if you saw it burning from the adapter. I think you can replace an adapter from a store. Hope that helps.
Posted on Jan 20, 2010
brianw74
  • 400 Answers
SOURCE: Wii 100v plugged into 220v
Might try a different a/c adapter from gamestop or someplace else.....If that doesnt work, it may have internal fuses that popped.....If it doesnt the its toast.
Posted on Apr 14, 2012
I purchased remington shaver in US now it not working properly and not getting charged. where do i have repairing centre in hyderabad
Many Remington shavers sold in the US are only for use with 120V. Voltage in your country may be 220V-240V. If you attempted to use a 120V charger in your 220V electrical outlet without a voltage converter, you have probably damaged the charger.
Chargers can be purchased at shaveroutlet.com. You will need your shavers model number to select the correct cord. And, you may need to use a voltage converter if the replacement you get is for use with 120V
ShaverOutlet com ShaverOutlet com Cords Chargers Stands Shaver Replacement...
Feb 27, 2016 | Remington MS2-390 Electric Shaver
I have a crosley CR8005A and i conected in my country (CHILE, SOUTH AMERICA) and here we have 220 v. can it fix it?
You need a step-down voltage converter to convert 220V to 120V.
Amazon has them. One example - http://www.amazon.com/VCT-VT-300-Voltage-Transformer-Converts/dp/B000J65PJQ/ref=sr_1_13?s=electronics&ie=UTF8&qid=1365005058&sr=1-13&keywords=convert+120V+to+220 or http://www.amazon.com/Voltage-Converter-220-240-110/dp/B001ES8YY6/ref=sr_1_2?s=electronics&ie=UTF8&qid=1365005058&sr=1-2&keywords=convert+120V+to+220.
Look for words like "voltage converter", "voltage transformer" and "travel"
Mar 24, 2013 | Audio Players & Recorders
Apr 13, 2012 | Nintendo Wii Console
I live in South Africa and my son has brought back a Panasonic shaver from the USA. Can our std 220v power outlet be suitable to charge the shaver? The power pack only mentions 120v input AC?
If the power supply that came with the unit says only 120V, you must use a voltage converter with the unit. If you plug the charger into your 220V system without a convertr, it will damage the charger
Apr 17, 2011 | Health & Beauty
Can a Panasonic DMP-BDT310 Blue-Ray player from the US be set to 220V? Does it have a voltage selector?
No it does not have a voltage selector.
These units are made specifically for different regions A B or C.
I suppose you could get a converter.. 120v 60 hz to 220 V 55 hz.. but I would want to make sure it would play the proper format for your region before going through the trouble.
Best of luck
Apr 12, 2011 | Panasonic Televison & Video
How do i convert motor from 120v to 220v
you should have a label on the pump that shows the connections. 120V=low voltage 220V=high voltage. Here is an example of a label:
Conect the internal motor wires to the terminals indicated. Then connect your line to the terminals indicated
Jul 19, 2010 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Will my Logitech X-230 speakers work in a country with 220-240 V power outlets or would i need an adapter to use them there? If i connect them directly to the 240 V outlet, will they run properly or would...
Check the back of your sub to check your voltage range. You will see something like this: 110V-120V or 110V-220V. If you see the later, you are ready to go. If you see 110-120V only, you will need a power converter to power your speakers as well as any other 110-120V equipment. But no matter what, if it is 110-120V DO NOT PLUG DIRECT TO 220V!! It will blow your speakers. (I lived in Germany for 11 years.)
Aug 12, 2009 | Logitech Z-2300 Computer Speakers
Jul 28, 2009 | Nintendo Wii Console
Plugged to wrong voltage
first thing to do would be check the fuse that is usually in line to the transformer hope this helps regards JIm
Apr 29, 2009 | Sony SLV-D370P DVD Player/VCR
Plugged 4w 120v trimmer into 220v outlet with a 50-2000w 220-110v coverter - it blew fuse and doesn't work. soldering melted off wire inside
scrap the trimmer...
probablly damaged beyond cost of new one
a step down transformer would have been a better choice than a voltage converter ( not trying to be a wise guy here)..
Nov 04, 2008 | Remington HC-600 Hair Trimmer
Video Game Consoles & Games Logo
124 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
