Question about Garden
How to test the coil for spark - Garden
    Sergeant:
  • 322 Answers
The proper way is with a spark tester. A backyard mechanic way is to put a screwdriver in the spark plug boot and hold it close to the engine block, pull the starter rope and look for a spark from the screwdriver to the block. Doesn't always work right and may not tell you for sure it isn't working
Posted on Jan 16, 2013
No spark at spark plug could the coil be bad and how do you test it ?
put an insulation screw driver in the wire end that connects to the cap, obviously disconnecting it from the cap. Crank over and move metal part of screw driver next to some metal and you should see a spark coming from the wire to ground if coil is good.
Feb 14, 2016 | ATVs
How do you check coil on a B&B intek206 engine
It is basically a go / no go test. Disconnect the wire from the kill terminal. Then spin the engine flywheel at least 250 - 350 rpm and check for spark. If there is a spark the coil is good; if no spark then the coil is bad.
A more definite test for strength of the spark is that it arc must across a gap of .166 " using the spark gap test tool that Briggs has but the above test is what most of techs use unless are an especially difficult problem of missing or similar problem.
Jan 28, 2015 | Garden
Test ignition coil honda gx25
Okay. You have eliminated the plug. Now disconnect the coil kill wire and try for spark again. Also check grounding between the coil laminates and the cylinder with you ohm meter should read zero.
If grounding okay and with the kill wire disconnected you still get no sparks then replace the coil pack as it probably a failed internal trigger which can not tested for.
Dec 31, 2014 | Atom ATDDLX 25cc 4-Stroke Honda...
I have a 2001 roadking it has no spark
Remove the plugs and visually check the condition of the plugs and then reinstall them and leaving both plugs installed remove the spark plug cable from one of the spark plugs and THEN attach the HT cable to a SPARK TESTER and clip the tester to the cylinder head bolt and crank the engine over looking for spark and repeat the procedure on the other cylinder also. Be aware that the Engine will not spark with both spark plugs removed, so when checking for spark, use a SPARK TESTER with both plugs installed.
If you have no spark test the coil first. There should be power to the coil primary all the time the run switch and ignition switches are ON. If not check all switches, relays and fuses.
If the CKP is defective you will also get no spark so check it last.
Test the primary coil resistance on your coil. Disconnect all the wires going to the small terminals (primary) on your coil. Using a good ohmmeter on Rx1 setting, test the resistance between the two small terminals. You should read somewhere between 2 and 3 ohms. If you read more, the coil is bad. Before you do this test short out both leads of the ohmmeter and if the reading is not zero you will need to write down or otherwise remember the number and subtract it from the reading you get from the primary circuit test or you will have an incorrect resistance reading for the primary wires because you will also be reading the ohmmeter internal resistance and/or the wire and lead resistance added to the primary wiring resistance.
You can also test the coil by leaving the "hot" wire on the coil and replacing the other side (ground side) with a short piece of wire. Turn the ignition on and temporarily ground the short piece of wire you put on the "out" (ground) side. When you take the wire away from the ground, (which will collapse the primary current into the secondary) you should see a spark at the plugs if it is a wasted spark system or at one of the plugs if it is not a wasted spark system. If you have current to both sides of the primary of a two part coil both plugs should get a spark whether wasted spark system or not as you are energizing both sides of the primary and collapsing both into both secondaries at the same time when you remove the ground wire from the cylinder head ground.
MORE:
Ignition Coil Primary Circuit Test
Remove the coil. THEN set your ohmmeter scale to RX1 and place ohmmeter leads on the primary coil windings A (front of coil) to B (middle of coil), B to C (front of coil) and check for primary coil winding resistance which normal resistance range is 0.5-0.7 ohms. If primary resistance is not within this range check out test results below.
Ignition Coil Secondary Circuit Test
With the ignition coil removed from the motorcycle and the ohmmeter set to the RX1K scale place the ohmmeter leads on the secondary coil windings B (middle terminal) to
R (rear secondary terminal/socket), B to F (front secondary terminal/socket) and check for secondary coil winding resistance which normal resistance range will be 5.5-7.5K ohms. If secondary resistance is not within this range check out test results below.
Test Results
A low resistance value indicates a short in the coil winding which requires coil replacement.
A high resistance value might indicate that there is some corrosion/oxidation of the coil terminals requiring the coil terminals to be cleaned and the resistance test then repeated and if after the test is repeated the resistance is still high after the terminals were cleaned the coil must be replaced.
If there is an infinite ohms or no continuity) resistance value the coil is open and must be replaced.
Sep 29, 2014 | Harley Davidson Motorcycles
BIKE RAN GOOD BUT HAD BACK FIRE ONCE IN A WHILE REPLACED COIL RAN GOOD FOR 100 MILES SHUT IT OFF NOW HAVE NO SPARK TO PLUGS
Could be an ignition module. Check the coil first.
Check your pick-up sensor located inside the timing cover, behind the adjustor plate. If the filament is not intact you will have no spark.
A defective coil, cam position sensor, or stator will also cause a no spark condition.
First check for diagnostic trouble codes (DTCs). THEN check the condition of the battery and do a voltage test
and recharge the battery if it is below 12.60V. THEN check the condition and tightness of the battery connections
and perform either a conductance test or a load test and replace the battery if and as necessary. THEN remove the spark plug cable from one of the spark plugs and remove the plug and visually check the condition of the plug. THEN attach the HT cable to a SPARK TESTER and clip the tester to the cylinder head bolt and crank the engine over looking for spark and repeat the procedure on the other cylinder also. Be aware that the Engine will not spark with both spark plugs removed, so when checking for spark, use a SPARK TESTER with both plugs installed.
Test Results
May 13, 2014 | 2001 Harley Davidson XL 1200 S Sportster...
The number 1 cylider not firering ,there is power coming to it but no spark ,ECU was tested they see no problem ,Compresion test tested and fine ,Coil packs ,enjectoers ,tested and all fine. There is still...
Swap the coils around. See if the no spark follows that coil, or stays at number 1. Could be a bad plug wire, too. Or the wiring to the coil for number 1.
Nov 28, 2013 | Cars & Trucks
I changed the magneto on my Honda GX160 QX2 5.5hp. small engine and I still have no spark. Any suggestions on what to check ?
There could be an issue with the oil sending unit, spark plug boot or faulty on/off switch. Easy tests. Always use a new plug for testing. Unplug the oil sending unit wire and retest for spark. If spark may need to change the oil or low oil. If still no spark, leave the sending unit wire unplugged and remove the boot from the plug wire. Insert a short piece of paper clip wire into the end of the plug wire and hold near metal of the engine for test. If spark, replace boot. If still no spark, unplug wire from on/off switch and retest. If still no spark suspect faulty coil ~ redo all tests using old coil. If still no joy return new coil for exchange. I use a growler to test coils(growler used for testing armature for short, place one leg of coil on each pad of growler and activate growler for short burst). Good luck.
Aug 10, 2011 | Electrical Supplies
What should a multimeter read on a continuity test on the coil packs? i'm getting 1.9,1.7,1.7
The multimeter can read the resistance and if it is not open or shorted out, I'd say that your readings are in the normal range, comparing each resistance with each other + or - 10%.
I looked up the resistance readings on my online resource, but they did not list it specifically.
I looked up the following on autozone.com:
There are 3 dual-tower ignition coils that are part of the ignition control module (ICM). The ICM contains coil driver circuits that command the coils to operate. The Powertrain Control Module (PCM) controls each dual-tower ignition coil by transmitting timing pulses on the ignition coil control circuit to the ICM for the proper coil to enable a spark event.
  1. Inspect the spark plug wires for proper orientation.
  2. With the ignition OFF, remove the fuel pump relay.
  3. Crank the engine and test for a strong spark on each cylinder spark plug wire using a suitable spark plug tester. Ground the companion cylinder spark plug wire of each cylinder when it is tested.
    If a strong bright blue spark is present on all of the cylinders, remove and inspect all of the spark plugs for proper torque, proper gap, wear, damage, and fouling. Replace the spark plugs if necessary. If there is no spark on any of the cylinders, test the ignition voltage circuit of the Ignition Coil Module (ICM) for an open/high resistance or short to ground, or test the ground circuit of the ICM for an open/high resistance, or a faulty ICM. The wire circuit resistance should measure less than 3 ohms. If there is no spark on any of the cylinders, or spark is weak or intermittent, test the IC circuit for an open/high resistance, or a faulty ICM. The wire circuit resistance should measure less than 3 ohms. If spark is present on one or more of the cylinders, inspect and test the spark plug wires for arching, cuts, rubbing on other components, and proper resistance. If all tests are normal, then the system is operating correctly.
Oct 08, 2010 | 2000 Chevrolet Venture
Car wont start
test light on neg with key on power at both sides of coil ???? next test light on bat plus put to coil neg and have somone turn car over if test light flashes and still no spark coil is bad if test light no flash ignighter is most likely bad the ignighter switches ground on your coil for spark
Dec 23, 2008 | 1994 Toyota Camry
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
