Question about Hotpoint Ovens
My hotpoint DQ 891/1 top oven is not getting hot enough, what can I do?
The hotest it gets to is 155c
barkencoa
  • 3463 Answers
SOURCE: oven not getting hot
The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
Access is by removing the inner rear cover of the oven, there you will see the element.
Replace with a new one.
It is possible the base element is faulty in the top oven of the Hotpoint EW95,
The other possibility is that the high speed grill element is only part working.You need to check both these elements.
If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
If it does heat, then it could be a faulty thermostat or possibly selector switch.
Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
Plz rate my solution
Thanks.
Posted on Dec 27, 2008
SOURCE: maytag electri single oven, not getting hot enough?
replace the lower element. easy fix. TURN OFF POWER. remove two screws inside that hold element in place. Pull forward. disconnect clips that connect wire to element. reverse steps to replace with new element.
Posted on Mar 17, 2009
dblred
  • 68 Answers
SOURCE: I think the oven needs calibrated
You can only calibrate the temps about 20 degrees. If it isn't getting close to the temp you set it for, you probably have a faulty oven sensor and need to replace it. They usually run around $50-$90, and are easy to replace.
Posted on Oct 05, 2009
apart4u
  • 213 Answers
SOURCE: Hotpoint UD47 electric oven not hot enough
For all Free appliance repair videos visit our VIDEO TUTORIALS
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 14, 2010
Testimonial: "Thankyou for your help. Turned out to be the element as expected. When I took it out it was all burned and had blown. Replaced and back up and running"
SOURCE: Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Posted on Feb 07, 2010
SHOULD BAKE ELEMENT GET RED
Yes. It gets red when it is heating; it'll go on and off to maintain oven temp. If it doesn't work at all it could be loose, burned out, to other electrical problem.
Apr 16, 2014 | Kenmore 47702 / 47704 / 47709 Electric...
Oven not getting hot
I would recommend checking the circuit breakers, assuming that there is a 230 volt supply for the heater elements. If that is OK you might have a bad heater element.
Jan 13, 2012 | Frigidaire Ovens
Is the top heating element inside the oven supposed to get hot even if not set on broil?
Yes the top element does get hot even on bake but it does not get red hot just hot. It will get hot enough to burn you so be very carful.
Apr 06, 2011 | Kenmore Ovens
Set oven to clean, get flashing door indicator lig...
If this is an Electrolux oven then F9 relates to micro-processor resets itself.To get this to reset fully its reccomended that you disconnect the unit from the electric supply and then reconnect then retry.
Hope this helps
May 10, 2010 | Ovens
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My oven wont heat up at all. gets no gas. the top
your glow coil is wron out , need to replace it, you may see it glowing in there but it isnt getting hot enough, usually you can switch out the broil one for a quick fix to get you outta truoble. easy do it yourself problem
Feb 05, 2010 | Frigidaire FEB27S5A Electric Single Oven
OVEN WONT WORK
Even though the igniter is red, if you are not getting gas it is almost 100% sure that the igniter is simply not getting hot enough. A new igniter should get that valve to open and you will be baking like crazy.
Nov 30, 2009 | Maytag CWG3100A Gas Single Oven
Simpson Evolution 904 wall oven cooks very unevenly
I agree, the heating is very uneven in our oven, however, when I calibrated the temperature with a thermocouple, I discovered that the temperature gauge was 25C too hot! That is, if I set the oven temperature gauge to 155C, it was actually 180C inside the oven! Taking this in to account, it is now much easier to cook things without them burning.
Sep 26, 2009 | Ovens
VDGO viking gas oven upper won't heat
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 16, 2009 | Ovens
Ovens Logo
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
 Fix Your Board
Fix Your Board
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
