I want to connect a sharp HT SL75 Soundbar to the TV. Is HDMI 1 ARC compliant?
SOURCE: Have a HT-X810 Samsung soundbar
Dear rayoneill,
I just got an HT-X810 and hooked it up to my TV and had the same problem. I suggest that you ensure that you've selected the proper device input on your TV. My TV has a couple HDMI ports, in addition to a host of other connection choices, and I found that I was selecting the wrong HDMI input for viewing a dvd. Alternatively, when I was looking for an HDMI cable to hook up my unit I came across many chats/discussions/reviews that noted the properties of HDMI cables. The consensus among the discussants was that an HDMI cable either works or it doesn't - meaning that if there is a problem with the cable, you don't get a degraded image and sound you get nothing. Things that may lead to this include a loose connection or perhaps, and there was some disagreement among commentators on this, a poorly manufactured HDMI cable. Many claimed that due to the nature of digital signal transmissions, all HDMI cables are created equal so quality doesn't matter. However, when I was reading product reviews for cables available on amazon.com, many people were very critical of the cheap cables' performance. At the same time, most everyone seemed to agree that expensive 'Monster' cables were a waste of money. I settled on a $10 HDMI cable and haven't had any problems.
Good Luck, Justin
Posted on Dec 04, 2008
  • 33 Answers
SOURCE: sharp television and panasonic cinema system with hdmi connection
Ok, here's the deal. You can have sound being putout from hdmi coming from one of those sharp units, but it just depends on how you are connected. If you are using a digital audio output, from the tv, it wont push out the sound the way that it should. You will have to downgrade to using audio composite cables to connect to your external speaker system from the audio ouputs, not the digital audio outputs. Its not designed to push out sound from an hdmi cable. The BEST way to have this setup is to run your sound directly from the cinema to the external audio source(leaving the hdmi cable in the tv).
Posted on Dec 12, 2008
SOURCE: Cannot turn TV off when playing CD's with samsung HT-X810R/LG50PG
Problem traced to Samsung's Anynet+ System interacting with LG's Simplink. They seem to be
compatible. Cured by Menu/Option/Simplink/OFF. Hope this helps with anyone else having this problem. trev6.
Posted on Jan 10, 2009
  • 4 Answers
SOURCE: "Display connected non-HDCP compliant" error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
Posted on May 18, 2009
  • 4 Answers
SOURCE: Non-HDCP Compliant Error
Soundbar connection from Phillips TV to a Samsung HD 550 soundbar
The sound bar only needs sound input from the tv so optical cable connection will work fine. HDMI cable will also work fine. Use the one that you have available.
Mar 18, 2017 | Samsung Televison & Video
I have a Sony sound bar Model CT380. It has HDMI ARC and optical digital connections. The TV does not have these connections. What can I do to work around this?
How to connect a TV Sound Bar system to a television. - SONY
https://us.en.kb.sony.com/.../how-to-connect-a-tv-sound-bar-system-to-a...
Jump to If your TV has an HDMI terminal (without ARC) and an ... - Then connect theTV's Optical digital ... If your TV does not have HDMI input ...
2.1 ch Soundbar with Bluetooth ' HT-CT380 ' Sony US
www.sony.com/electronics/sound-bars/ht-ct380
Sony Corporation
Rating: 4.1 - ‎9 reviews - ‎$249.99
Discover the 2.1 ch Soundbar with Bluetooth from Sony & explore all the Sound Barsfeatures. ... filter higher frequencies to distribute audio smoothly around the room. ...against the sound bar to make an instant Bluetooth connection. No NFC? ... the HT-CT380 to allow data to pass through the sound bar straight to your TV ...
Dec 28, 2015 | Sony Audio Players & Recorders
How do I connect my Sony soundbar ht-ct 260h to my blu ray player etc, I have no optical port or arc hdmi port,at the moment connected through the audio lead to soundbar & tv ?
hook your dvd player up to the tv via hdmi, then take the optical audio output from you tv to the soundbar. Make sure to enable to audio output jack in the tv setup menu as some manufacturers disable this jack by default.
Mar 30, 2015 | Sony HT-CT260H Soundbar and Wireless...
How do I connect my ht ct260h step by step, with hdmi input do I use
HDMI can be a bit confusing when first connecting a system. Overall, the HDMI cable system allows for less clutter and digital audio and video, but you need some background to get it right.
The simple answer to your question is that the HDMI on your TV that is labeled HDMI out will go to your soundbar's HDMI input. Now, the reason you have a picture but no sound, will be one of 2 problems. If your TV is labeled with ARC, this means that it has an HDMI with Audio Return Channel and will be compatible with your CT260h soundbar. If you don't have sound, then you need to replace your HDMI cable with a ver1.4 HDMI cable so that ARC is supported in the cable design. If your TV does not provide ARC, then you will need to connect the audio using the digital optical connection which is a fiber optic cable of the TOSLINK variety. This cable should have been included with your soundbar packing.
Also be aware that if you buy a HDMI1.4 with Redmere technology to save on the size of the cable, it has a direction for the signal flow which must be adhered to, otherwise the cable will not pass either audio nor video.
I hope that answers your question.
Feb 16, 2015 | Sony HT-CT260H Soundbar and Wireless...
Hi I've just brought the sharp HTS-L75 and I don't know how to active it to my tv menu model LC-42LE771K?
There are several different options. But you will probably want to use the HDMI (w/ ARC) connection from the TV to the subwoofer. (HDMI cable) The soundbar attaches to the sub with a standard speaker cable. You will need to configure the 'Sound Mode' and 'Digital Out' settings in the TVs Sound Menu to output the audio on the digital output / HDMI connection.
Jan 29, 2015 | Sharp Televison & Video
Does the Samsung UN50f6300af smart led tv support the Samsung Wireless audio soundbar HW-H450?
Because your TV is not Bluetooth-enabled and you are trying to connect it to a Bluetooth-enabled soundbar via Bluetooth. There are other ways to connect your TV to the soundbar:
1. analog AUDIO OUT (L/R) of your TV to the AUX IN on the soundbar (use a 3.5 mm.-to-RCA audio cable).
2. Optical OUT on your TV to Optical IN on the soundbar.
3. HDMI port to HDMI port (this may not work if your TV is not ARC compliant you have to try).
You get better sound quality with option 2.or 3. (if this one works for your TV)
Here is the link to download the soundbar's User Manual for help with the connections:
http://downloadcenter.samsung.com/content/UM/201411/20141114104022428/HW-H450-ZA-1114_Bookmark.pdf
Jan 05, 2015 | Samsung 2.1 Dolby Digital Wireless...
What remote can be used to control a HT-SL75 sharp
Features
Other than the cool things you can do when setting up the Sharp HT-SL75 system, there are no features to really play around with. This means no screen, no extra options to tinker, no virtual surround sound, no Wi-Fi and no Bluetooth. It is meant to be connected to the TV and it just works from there. No remote control is included either since you can simply use the TV remote control to adjust the volume.
Sep 25, 2014 | Televison & Video
Connect a Sharp TV to Sharp sound bar
Call a local custom audio/video installer that can help you for a small fee. It's okay to pay a professional and get the right help. It shouldn't cost you more than $50 at most, but probably half that amount since it's a very simple connection.
Here's a couple of weblinks that may be helpful...
http://hometheater.about.com/od/hometheaterglossary/g/Audio-Return-Channel-Arc.htm
http://www.sharpusa.com/ForHome/HomeEntertainment/SoundBar/Models/HTSB40.aspx
Dec 03, 2013 | Televison & Video
I just bought the sharp home theater system ht-sl70/ht-sl75 and I cannot get the volume to be controlled thru my remote. I have a 60 inch sharp aquos tv. It has no arc and when I use the rca connection it...
Hi
I just bought HTSL75 speakers. Its manual saying its volume is controlled by TV's remote control
But i am having Samsung UN46EH6000 LED. and Speakers is connected to LED via RCA and LED is giving fixed output, so all the time, speaker is working on full volume
Is there any workaround, so that i can control volume while using sharp HT-SL75 speakers with Samsung UN46EH6000 ?
Is there any volume control device to control the volume of the speakers in my case ?
Thanks for your help !!
May 09, 2012 | Sharp Audio Players & Recorders
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
