Question about Panasonic PT-LB60NTU LCD Projector
I turn on unit and it turns off like ten secondfs later
  • 93 Answers
Check the lamp for any bubble like structure on the filament.if ok
the ballast unit has to be at fault
replace the ballast power supply!
Posted on Jan 18, 2013
I bought from a private party a used Wolf range Challenger Model CHR-4-29-HB11, oven worked fine. First I was baking and heard stove making a phfttt, phftt, noise. Then took food out and noticed oven...
Pilot lights go out because the Thermocoupler is either bad or not getting hot enough. It will be a copper tube that should touch the pilot light flame. these are replaceable and usually any appliance repair supplier can get you one. Some units reuire changing out the entire gas control
Oct 17, 2013 | Wolf Range CHR-10-229-FT11 Kitchen Range
Leq1442eso
Good Afternoon Terry, thank you for your post!
Often constant beeping is an indication that the unit is experiencing a possible error. I under you have tried resetting the dryer by flipping the breaker. It is important to wait roughly ten minutes before turning on the unit. If the beeping continues, then the appliance could be experiencing a communication issue with the control board or a potential wiring failure. I would recommend connecting with a qualified appliance repairman to proceed further.
Aug 29, 2013 | Frigidaire FEQ1442ES Electric Dryer
I have a hussmann commercial freezer model GGSM-3 when I plug it in after like ten minutes it turns off and three seconds later it comes back on and kepps turning on and off what could be causing this...
The freezer is low on freon... it is cutting in and out on low pressure. It does not for the first ten minutes because the temperatures are higher when it is warmer... then as the temps come down the pressures drop and the vicious cycle begins....
Double check the type freon that is in there before adding so you do not mix refrigerants...there are a few possibilities...depending on the age of the unit.
This is not a DIY project, make sure to have a licensed pro do this for you!!
heatman101
Apr 30, 2011 | Freezers
El led del papel se queda parpadeando y no imprime es como si tubiera algo atorado
Units built before June 18, 2008
Units with a S/N having a Year Built and Week Built code earlier than "08-25" are reset using the following procedure:
1. Open the media compartment and remove any media.
2. Press the Feed button and hold it approximately ten seconds until the Power, Communications and Error indicators turn off and stay off.
3. After the three indicators turn off, reload the media and close the media compartment cover.
4. Wait at least ten more seconds and press the Power button. The Printer will restart and normal operation can resume.
Units built after June 18, 2008
Units with a S/N having a Year Built and Week Built code of "08-25" or later are reset using the following procedure:
1. Press and hold the power button for 5 seconds and then release. The printer will power down.
2. Re-start the Printer as usual. Any pending data in the printer will have been deleted and must be re-sent.
Dec 16, 2010 | Zebra MZ 320 Thermal Printer
1995 buick rivera,won'tstart, turns over ,later it will start
i had the same problem recently. After checing all the simple stuff:fuses, relays, gas, fuel pump I became baffled. Turned out it was my air intake sensor.
Mar 03, 2009 | 1995 Buick Riviera
Monitor goes blank less than a second after turning on.
Monitor is bad for sure. Try another known good monitor on your computer and if the problem stops then you know for sure the original monitor is bad. Hope this helps.
Feb 01, 2009 | Dell Dimension 3000® Pentium® 4...
Panasonic PT-LB60NTU LCD Projector Logo
47 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
