Getting Eaccess violation when opening cdlib 5.1
Running windows 7 pro 64 but looking to upgrade to windows 8 pro 64
  • 174 Answers
You will need a codec.
Posted on Mar 01, 2013
Can Vista Home Premium be upgraded to window's 7?
      If you're running a 32-bit version of Windows Vista, you can only upgrade to a 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only upgrade to a 64-bit version ofWindows 7. Otherwise, you'll need to use the Custom option to install Windows 7.
      Upgrading from Windows Vista to Windows 7 - Windows Help
      windows.microsoft.com/.../windows7/.../upgrading-fro... Microsoft Windows
    Feedback
    windows.microsoft.com/.../windows7/.../upgrading-f...
    Microsoft WindowsIf you're running a 32-bit version of Windows Vista, you can only upgrade to a 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only upgrade to a 64-bit version of Windows 7. Otherwise, you'll need to use the Custom option to install Windows 7.
    How To Upgrade from Vista to Windows 7 Home Premium ...
Feb 08, 2016 | Computers & Internet
Just installed windows 10 from Windows 7 but I don't know if I can get 64 bit?
It depends on the processor on your motherboard. Normally an upgrade will detect it automatically.
Oct 16, 2015 | HP Mini Computers & Internet
Is the ensoniq mr61 compatible with windows 8? Is there a device or upgrade for this?
Supported Operating Systems and Hardware MQ Essen
tials
Midi
Quest
Midi
Quest
Pro
Info 32-bit Windows support: Win 8, Win 7, Vista, XP checkyes.png checkyes.png checkyes.png 64-bit Windows support: Win 8 x64, Win 7 x64, Vista x64, XP x64 checkyes.png checkyes.png checkyes.png Windows Midi Quest x64 with x64 plug-ins to support 64-bit VST hosts checkyes.png Intel Macintosh systems: OS X 10.9, 10.8, 10.7, 10.6 and 10.5
Check this link
May 29, 2014 | Computers & Internet
Windows 8 pro sound problems
You can sometimes you can use Win 7 drivers for the audio, found on the HP website: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4062&lc=en&cc=us&dlc=en&sw_lang=&product=3837660#N231 ,for your onexant High-Definition SmartAudio 221 . That said, you may have to change the compatibility of the driver to WINdows 8, you did not say 32 or 64, and install it to your audio device. Have you notices other devices in Device Manager that are not working properly? I had a similar situation, Audio, Modem, Card Reader, when I upgraded an old (2005) Gateway MX6421 to Win 7 pro N 64 I had to locate the drivers, (from a HP site), change a few lines of code in the drivers and change compatibility to Win 7.
Nov 06, 2012 | Computers & Internet
Installing adobe acrobat pro 6 to windows 7
This is an old version of Acrobat that was written for NT, Win2K and XP. Due to changes in the OS, it's hard to get the program to install in Windows 7.
Which version of Win7 do you have? (32-bit or 64-bit and Home Premium, Pro or one of the other variants) Since you indicated this under the Dell Dimension E521 with 1 GB of memory, I'll guess Win7 Pro 64-bit. (This uses the 64 bit CPU) You can check by clicking Start > Control Panel > System and Security > System. If the Windows version ends with x64, it is the 64-bit version. Otherwise, you have the 32-bit version.
Under the 64-bit OS, you need one of the following workarounds: a second computer, a dual boot computer or a virtual computer running an older version of Windows. If your hardware supports virtualization, this might be a good bet if you can add memory to computer. With Win7 Pro or Ultimate, you can download and install Virtual PC and XP mode from Microsoft and run XP for free. Then install Acrobat in XP mode as if it were your only machine. (Note: the Virtual PC requires a share of your total memory and doesn't give it back to the main computer while it is running.)
The other methods listed require a licensed version of an older Windows OS.
If you have the 32-bit version of Windows 7, you can try the compatibility mode. Right click on the installer and choose Properties. In the compatibility tab, check always run in the compatibility mode and select an older version of Windows. Then click Apply to save the changes and then click OK. Then right click again and choose Run As Administrator. You may have to repeat the compatibility mode changes for the program itself.
You may want to consider upgrading to a Windows 7 compatible version of Acrobat. The current version is Version X.
I hope this helps.
Dec 26, 2011 | Dell Dimension E521 AMD Athlon 64 X2...
On starting CDlib.exe I get message "Provider cannot be found" after upgrading from Vista Home Preium to Win7 Pro (64 bit-both).
Awalatuch,
Uninstall the software you have and re-install after downloading from here:
http://www.ziotek.com/templates/searchdetail.asp?productID=4667
If that does not work I would suspect a problem with the provider.
Jul 24, 2011 | Ziotek Media Carousel Plus, Beige Burner
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
Feb 17, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Is it possible to upgrade windows xp professional x64 to windows 7 professional x64
Hello
Yes it is.
Just make sure you download or purchase Win 7 x 64.
If your doing the upgrade you need to have winxp x 64 installed on your pc first.
Jun 10, 2010 | Microsoft Windows XP Professional for PC
I'm trying to upgrade from 64-bit Vista to 64 bit Windows 7. When I run the installation disk, I'm getting the following error message, which appears to be contradictory in my opinion:...
I have seen this type of problem before, the only real way around it is to install a fresh copy of windows 7 not to upgrade, you will receive a message that asks you if you want to keep the previous windows in a folder called old windows, from there you will be able to access all your old files and programs, be aware though some programs may not work on windows 7, and you may need to have updated drivers for the systems peripherals. So when you run the windows 7 disk choose clean install and go from there. i hope this helps
Feb 04, 2010 | Microsoft Computers & Internet
103 people viewed this question
 Grubhead
Grubhead
