Question about Philips SPA3210 2 Speakers
No power
Where can I find a power cable for subwoofer philips HTS6600/12?
Local Philips Dealer or buy direct from Philips Use Philips website
Mar 13, 2015 | Philips Audio Players & Recorders
My speakers won't work there is no power no light
If the speakers require an aux power supply like a power adapter patched to the speakers from a wall type transformer; then try another adapter as the one you have may be damaged and not putting out current. Replacements are cheap. Go to RadioShack wit the one you have and they will test yours and if bad, they have the exact replacement.
Jan 04, 2014 | Philips MMS 321 Computer Speakers
I have a philips DSP 2500/5.1 home theater its power ic for speakers has gone it does not have any name in the ic please help me
There is a service manual for a Philips model 2500, but I am not certain it's the same model as yours, as it uses the HST letters before the number. You can look at that it's free.
Jul 17, 2012 | Philips 5.1-Ch. Home Theater System with...
Philips spa2360/17 subwoofer making a humming noise
Check your audio and electrical connections. This may be a bad cable connection. Also, so not run the power line and audio cables in parallel. They should only cross at 90 degrees, to reduce induced power hum.
Jul 05, 2012 | Philips SPA2360 21 Speakers
How do I get the driver for the philips model dss33017 speakers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
if you dont have a disk with the drivers you will have to download them
http://www.boxdrivers.com
using this link you will be able select your drivers
http://www.drivermax.com/driver/update/MEDIA/Philips/Philips-DSS-330-Speakers/1290742
http://www.drivermax.com/driver/update/MEDIA/Philips/Philips-DSS-330-Speakers/1290147
http://www.drivermax.com/driver/update/MEDIA/Philips/Philips-DSS-330-Speakers/1290487
if these arent right you will find free sound drivers
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)but don
Sep 12, 2011 | Philips DSS 330 Computer Speakers
Cannot find power adapter for mms171w philips system. Needs AC/AC adapter with 10v ac at 1.8 amps output. Cannot find aftermarket counterpart either. Help. Lost adapter while moving.
What does the other end of the adapter look like?
Is it a conventional circular one or is it a special port like it's thin square like or USB like maybe?
If it's conventional any 10v 1.8amp or 2 amp output should do and a lot of them are available in e-bay or if there's a Best Buy, Staples, Etc near you can just drop a visit purchase one and it should work like a charm.
However if it's not a conventional adapter you may have to contact philips and purchase one that is compatible from them.
Hope this shed some light on your problem!
May 31, 2011 | Philips MMS171 Computer Speakers
I Lost my power adepter for my philips speakers model no 430/00. Can you please let me know the adopter power means how much volt I need to use. also I need to connect it to my pc and i do not have any...
http://www.p4c.philips.com/files/m/mms430_00/mms430_00_dfu_eng.pdf
The specs for the adapter are not shown in the manual but I imagine they're marked on the speaker module.
Places like Radio Shack could set you up with an adapter that has a compatible electrical and physical connection.
The audio cable is standard RCA stereo on ne end and whateve rmatches your PC on the other.
http://cgi.ebay.com/PHILIPS-MULTIMEDIA-SPEAKER-SYSTEM-MMS-430-/200578744138?pt=UK_Computing_DesktopComponents_RL&hash=item2eb36cbf4a
Feb 25, 2011 | Philips MMS430/00 Main / Stereo Speaker
Hi my philips hometheater HTS3450 subwoofer power supply is blown off and the philips guys are giving estimate of 100$. my question is if i dont want to use the subwoofer and the speakers but only connect...
yes.modern TVs have good speakers,and the bravia has a good set,with adjustable sound fields,plus a decent amp in them.just use good cables,and use component video cables,or HDMI if yr DVD has it.most have 1080 video resolution nowadays
Jul 01, 2010 | Philips HTS3450 System
Very low output
Are the Philips speakers powered ????
Try in the headphone socket on a radio and check the sound then.
Jul 31, 2008 | Philips SBP1100/37 Portable Speaker System...
Philips SPA3210 2 Speakers Logo
46 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
