Question about Dell Latitude D600 Notebook
Serial keyboard I'm still lost! I have a couple of generic old keyboards - which don't require any special drivers when you plug them into PS2 ports. I think the appropriate keyboard driver is on the machine, but it doesn't know to use it with the serial port. I saw something on the Microsoft site saying that for NT the drivers add registry entries associating the keyboard with a port, but I couldn't find an example for XP. To get this done I would need more explicit instructions.
  • 1 more comment
  • p_kies Jan 26, 2009
    I gave up and got the port replicator back. Finding drivers for the com port and an old keyboard was next to impossible without knowing exactly where to look for them. The bulk of the drivers I could find on the net were for newer PCs, newer keyboards or different equipment entirely. I guess it's all about selling new equipment and nobody cares about making laptops compatible with old peripheral devices. Without a PS2 port on the back, you either have to buy the port replicator or a USB or wireless keyboard. FYI, the original question was posted athttp://www.fixya.com/ThreadView.aspx?prd...
    Yeah - I have the same connector, PS2 to serial - which I've similarly employed with an optical trackball. But keyboard is somehow a different issue; hook it up and the machine doesn't even recognize that new hardware is attached.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    p_kies: Here is the official MSN keyboard troubleshooting technique. As you can see all hardware devices need a driver. Also, with the low cost of keyboards you may want to measure if this is worth your time against buying a new keyboard.
    The keyboard is not functioning
    loadTOCNode(2, 'moreinformation');
    If the keyboard is not functioning, make sure that it is connected correctly to the computer. Check all the keyboard's plugs (PS/2 and USB) to make sure that there are no loose connections.
    If an adapter (USB to PS/2 or PS/2 to AT) is being used, verify that it is the adapter that came with the keyboard or that the keyboard supports adapting to a different port. For example, the Internet Keyboard does not adapt to a USB port, and a PS/2 to USB adapter will not work. It does not include an adapter.
    If the issue continues to occur, connect the keyboard to a different computer. If the keyboard functions correctly on a different computer, the port to which the keyboard was connected on the original computer may be damaged. If this is the case, contact your computer manufacturer to inquire about how to repair or replace the damaged port.
    If the keyboard does not function correctly on another computer, the keyboard may be defective. If this is the case, and the warranty on the keyboard is still valid, you can exchange the defective keyboard for a new keyboard.
    To remove and then reinstall the driver, follow these steps:
    1. Disconnect the device from the computer.
    2. Turn off the power for the device, if the device has a separate power supply.
    3. Open Device Manager.
      Note If your device is not listed, this means that the device was removed automatically when you disconnected the device. Continue to the next step.
    4. Restart the computer.
    5. Turn the power back on for the device, if you have to, and then plug the device into the computer. Your computer detects the device, and then reinstalls the drivers for the device.
    To download the latest drivers for the keyboard that you are using, visit the following Microsoft hardware Web site:
    http://www.microsoft.com/hardware/downlo... http://www.microsoft.com/hardware/downlo... To change your port connection:
    1. Shut down your computer, and then plug your device into the correct port.
    2. Make sure that the plug is pushed securely into the connector on the computer.
    3. Restart your computer. Microsoft Windows detects the change, and then installs the drivers on the new port automatically.
  • 520 Answers
Have you tried just plugging keyboard in..you have usually 2 ext ports one for ext keyboard and one for mouse you can also use usb keyboard/mouse.
if you have a problem with existing keyboard have you tried the on screen keyboard....start,all programs,accessories,accessability,on screen keyboard..when u say serial port do u mean the com port..
for com port you have to assign keyboard and you will need drivers cos not recognised as plug and play
Posted on Jan 26, 2009
  • tat4u
    tat4u Jan 26, 2009
    even though I have ps2 mouse I use a usb track ball cos its much faster and easier to use.you can get a serial to ps2 connector Ive got one somewhere.dont even know where or why I got it ..maybe it came with some hardware I got yrs ago.
  • tat4u
    tat4u Jan 26, 2009
    keyboards wont work via serial to ps2 I think thet were only designed for mouse and ext cables...its a long time ago since a dealt with serials and parrallel ports but if I remember correctly
    serial was for direct imput for shell ext and parrallel could program better but needed software.I used a interface via serial to program my cards for satellite you could also crack sky with a interface card(plugs into sky like regular card but links upto pc)
    you could also top up dead telephone cards,not that I did,,mmm
I purchased a used HP keyboard mod 5187-7583 but my computer does not recognize it. I'm using Windows 10-64. Do I need to download drivers for this keyboard?
It could be the "adapter", read this The pros and cons of PS 2 to USB adapters and converters
If you really, really like this keyboard you could always install one of these 2 Port USB 2 0 2 Port PS 2 Combo to PCI Adapter Converter Card NEC Chipset
Personally, I don't see the sense this is a old keyboard and HP didn't even release Windows 7 drivers for it, forget about Windows 10. This means that none of the special function keys or media control will work.
Feb 27, 2017 | HP Computers & Internet
I bought an old Mac Mini Intel Core 2 Duo, 2 GB Hard Drive, OS X Yosemite, with serial # C07CS2TPDD6H. What adapter cord could I use to connect it to an iBox C1752, TFT LCD Monitor?
That Mac has a hdmi port and a mini display port. The monitor has a saga port. So ether a hdmi-svga. Or miniDisplay port-svga.
Any usb keyboard will work. So any Mac keyboard newer than 12 years should be good, and newer pic keyboards will work. Beware of older keyboards that have round plugs. On macs these were ADB ports. On PC's, they used PS2 (ADB, ps2, usb are all different, you want the flat rectangle USB)
U.S. pc keyboards also have two modifier keys wired different than the U.S. Mac keyboards, but this can be adjusted in the system preferences. Can't say for non U.S. KBs. They are the windows/alt keys. Vs Opt/Command keys. That is, if you are soused to using a Mac, the key that is closest to the spacebar (command key) is applied by the second key over rather than the first. Again, this can be modified in the Sys Prefs.
Jun 06, 2015 | Apple Mac Mini Desktop
I am running windows xp, my wired keyboard Microsoft Comfort Curve 2000 v1.0 is not typing . i tried updating drivers but it's still not working
Ensure the keyboard is plugged into the correct place. If it is a USB keyboard it can be connected to any USB port and should be installed by itself. (All keyboard are generic devices and do not need additional drivers)
If it is a PS/2 device (Round plug) Ensure it is plugged into the keyboard port and not the mouse port. Also ensure no pins in the plug have bent or broken.
Try the keyboard on another computer to ensure it functions properly. If it does not, the keyboard may be defective, if it does work on another computer, you may have an issue with the port on your computer.
As stated before. Keyboard are generic devices and do NOT need additional drivers to work.
As a last test, ensure the keyboard is plugged into the computer BEFORE it's turned on.
Feb 13, 2015 | Microsoft Computers & Internet
Why can't I get a new usb mouse and keyboard to work on a very old Win98SE system that has working usb ports, but the old mouse and keyboard were ps2 connection?
You need to go to the manufacturer of both the keyboard and the mouse web sites and download the windows 98 drivers for both of them and install them.
Jun 28, 2012 | Computers & Internet
Keyboard locked
Maybe you keyboard is bad or your keyboard has been hijacked by a virus.
Make sure you keyboard is plugged in good on the back of the computer. If the end of your keyboard that plugs into the computer is Round and it plugs into the green port on the back of the computer you have a PS2 (serial) type of keyboard and you cannot unplug it and expect it to work if windows has already booted up. If you remove this type of keyboard connection, you have to Reboot your machine otherwise the keyboard is locked.
If the end of your keyboard that plugs into the computer is Flat, then you have a USB type of keyboard that goes into the computer's USB Port. This type of keyboard is Plug and Play so you don't have to reboot if you remove it. If you have this type maybe the USB Port you plugged it into does not work, so try plugging into another USB Port.
Try booting in Safe Mode and see if the keyboard performs.
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.
Apr 09, 2012 | Acer Aspire Z5700 PC Desktop
On booting up, computer can not load keyboard system.
One possible problem is that your PS2 keyboard port at the back of your PC is ruined. In time, those so called "outlets" become loose specially the ones with cables which usually got pulled or tangled and make the port strained and the contacts get loose.
If that is the case, you might need to replace the keyboard port, or just stick with your usb keyboard.
Jan 07, 2009 | Dell Dimension 2400 PC Desktop
Keyboard intermittent
There might be a problem with the keyboards PS2 port. You can bypass the PS2 port all together by buying a PS2 Y-adapter to usb port. This Y adapter will allow you to plug your PS2 mouse & keyboard into it and than you plug the other end into a free usb port. You do not have to plug the PS2 mouse in if you do not want to. Just plug in the keyboard. If your keyboard functions than there is a prolem with the keyboard's PS2 port. The PS2 Y-adapter to USB runs about $12.00 to $15.00. You can find one at Wallmart.
Jan 07, 2008 | E-Machines eMachines Desktop PC
Sk-6000 keyboard
For the touchpad: if your keyboard equipped with standard COM connector try: http://www.acersupport.com/library/ti_note/2x0tpad.exe (older synaptics driver - working with COM port based touchpad perfectly) - or if you have converted it to PS2 connector (i converted my one from COM to PS2) you can use the latest generic touchpad driver from http://www.synaptics.com/support/drive.cfm . (sadly synaptics dropped support for comport based devices in the latest drivers...)
Dec 23, 2007 | Maxi Switch Silitek SK 6000 Keyboard
Dell Latitude D600 Notebook Logo
216 people viewed this question
Alun Cox
