Question about Indesit W 123 Front Load Washer
Indesit WIA102 keeps draining, even when washing
My Indesit WIA 102 Front Load Washing Machine keeps draining water from the outlet hose. When I begin the process of washing, it then takes the detergent powder and drains it with the water which is suppose to stay to begin washing. Whats the problem?
  • Indesit Master
  • 3,463 Answers
Try lifting the drain outlet higher than it is, if it is too low the water will syphon out as it is filling, there by causing the problem you are experiencing, if that does not solve the prob, then it sounds like the pump is on all the time, this being the case, then it would appear that it has a faulty programmer.
Plz rate my solution.
Thanks.
Posted on Jan 23, 2009
Drain water from widl146
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Dec 29, 2011 | Indesit W 123 Front Load Washer
Washine machine full of water
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Thank You for using fixya
Sep 23, 2011 | Indesit W 123 Front Load Washer
I have an indesit wia 101 front loader washing machine. At the moment it will not drain or spin & the red light flashes really quickly
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump may need replaced
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Indesit W 123 Front Load Washer
Wd12x wachine machine. Washes clothes okay but does not drain. It stops and the dial keeps going round. If the door is opened, all water flows out. I think there may be a problem with the filetr but not...
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. CHECK AND CLEAN THE DRAIN FILTER. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Jul 22, 2011 | Indesit W 123 Front Load Washer
My washing machine will not drain the watere
CHECK PUMP/SEE IF ANYTHING STOPPING FROM PUMPING OR IT PUMP IS BAD,CHECK CLOGGED DISCHARGED HOSE ..
FRED
Feb 14, 2010 | Indesit W 123 Front Load Washer
Washing machine will not drain
TAKE THE HOSE OFF ON THE BACK {DISCHARGE HOSE} IF THE WATER FLOWS OUT IT IS THE PUMP MOTOR IF IT DOESN'T THERE IS SOMETHING BLOCKING THE OUTLET, SMALL CLOTHING ITEM
May 29, 2009 | Indesit W 123 Front Load Washer
Indesit washing Machine W93
Pump or hoses still blocked,Or pump has had it,Can supply new pump by post if req.
Sep 18, 2008 | Indesit W 123 Front Load Washer
Indesit 123. Will not drain. Goes into spin cycle when set but no water comes out. Checked hose at front and rear.
You need to clean out your outlet filter;(which is accessible thru the front bottom right side of machine, small push door, or plastic screw) this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain water if the outlet is clogged. For the pump, tubes, etc you hav to open up behind the machine. Be prepared for water to come flowing out....... You need good pair of grip pliers for the tubes.
And rate me pl, if the solution has worked......
Nov 26, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
408 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
