Question about Dryers
Need specifications on Maytag Dryer Model # MDG11PDAAW
2 Suggested Answers
  • 1314 Answers
SOURCE: I NEED FAULT CODES FOR DRYERS
PF Power Failure
“PF”
flashes to indicate that a power failure occurred while the dryer was
running. Press START to continue the cycle, or press PAUSE/CANCEL to
clear the display.
F-01 Primary Control Failure “F-01” flashes when there is a primary control failure. Replace the machine
control electronics. See Accessing & Removing the Electronic Assemblies.
F-02 Keypad/User Interface
Failure
“F-02”
flashes when there is a stuck button or user interface mismatch. This
fault code will ONLY appear when in the diagnostic test mode. See TEST #5.
F-22 Exhaust Thermistor Open “F-22” flashes if the thermistor is open. See TEST #3a.
F-23 Exhaust Thermistor Shorted “F-23” flashes if the thermistor has shorted. See TEST #3a.
F-26 Motor Drive System Failure “F-26” flashes if there is a motor drive system failure. See TEST #2.
F-28 Moisture Sensor Open “F-28” flashes if the moisture sensor strip is open. This fault code will ONLY
appear when in the diagnostic test mode. See TEST #4.
F-29 Moisture Sensor Shorted “F-29” flashes if the moisture sensor strip has shorted. This fault code will
ONLY appear when in the diagnostic test mode. See TEST #4.
1M 2M 3M 5M 6M
= Contacts closed
Contacts
Function
Start
Run Red
Lt. Blue
Blue-White (Elec)
White (Gas)
Green-Yellow
Red
Black-White
BLACK
BLUE
WHITE BLUE
WHITE
WHITE
Pluggable Drive Motor Switch Gas Valve - Gas Dryer
Centrifugal Switch (Motor)
Gas Valve this is about close as i can come its matag electronic but not comercial should be about the same software though some where on or in the dryer should be a tech sheet with codes
Posted on May 21, 2008
How do i disassemble the Maytag dryer model MDW9700AZW to replace the front felt seal?
I don't know about your specific model, but there are videos on youtube that might help you and give you an idea about how to disassemble yours.
Nov 17, 2016 | Maytag Dryers
Is this a reliable product? what is the retail cost?
Electric Dryer (MED9600SQ ) ' - Maytag
www.maytag.com/-[MED9600SQ]-1102962/MED9600SQ/
MaytagLearn about features and specifications for the Maytag Electric Dryer (MED9600SQ ) ... Manuals & Literature; Product Help; Parts & Accessories; Features ...
Maytag MDE7600 Electric Dryer - E-Opinions
www.eopinions.com/search/dryers/price...maytag.../1893?...
125 results like Maytag MDE7600 Electric Dryer Maytag MDG8500 Dryer ... ProductFeatures: Power Source: Electric; Dryer Type: Home Dryer; Load Type: .... Maytag MED9600S Electric Dryer ... Durable and dependable features in this dryer representMaytag brands committment to uncompromising strength and reliability.
Jan 11, 2016 | Maytag MED9600S Electric Dryer
How to replace dryer belt on stacked Maytag washer/dryer?
Hello! There is a trouble shooting guide for major appliances that frequently suggest parts and video links on youtube that diagnose your problem & instruct you how to repair your appliance. The site is called Repairclinic.com. Make sure you have the model number before you begin since the instructions are model specific. Good luck. You can also access the information by part & those parts usually have installation videos.
Jun 21, 2015 | Maytag Washing Machines
Dryer blows air, but the tub inside the dryer does not turn. What is the most likely problem?
The belt has broke. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the replacement. You might have to watch a different video for disassembling your model. Enter your model # for diagrams and illustrations of your specific model.
Mar 31, 2010 | Maytag PYE2300AY Electric Dryer
I have a maytag dryer that has a squeek
It's difficult to tell what might be causing a specific squeaking noise, but check the following:
The belt tensioner
The drum support rollers
These would be the two most common causes. You will need to remove the back panel of the machine to check these items. You may be able to lubricate the tensioner and support roller bearings temporarily, but if they are squeaking, they may be failing.
Dec 10, 2009 | Dishwashers
Convert Natural Gas Dryer to LP Gas
A dryer is a dryer. Most cases they all work the same. You will need to get an LP conversion kit for that model to complete the task.
Jan 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
What is the capacity of the maytag neptune mdg4000aw
motor 1/2 horse power,,,electrical,,120 60 hz,,15 amp breaker needed,,weight 160 lbs,,,capacity 3.2 cubic feet..about 26 pounds...onthe job
Jan 18, 2009 | Maytag Dryers
Maytag performa model#pyg2300aww takes four cycles to dry
how long is dryer vent run ? does it go up or out to the side ? Sounds like the dryer vent is clogged. A long run on your vent will also cause this problem with a small amount of lint. Try cleaning out your lint screen on the dryer vent they can get pretty caked up with lint. If you have a long dryer vent run post back the length and direction and I will get you the maximum length for your specific run. You may need a booster fan if it is excessively long or straight up as through the roof.
Dec 29, 2008 | Maytag PYE2300AY Electric Dryer
PF Power Failure
“PF”
clear the display.
Failure
“F-02”
1M 2M 3M 5M 6M
= Contacts closed
Contacts
Function
Start
Run Red
Lt. Blue
Blue-White (Elec)
White (Gas)
Green-Yellow
Red
Black-White
BLACK
BLUE
WHITE BLUE
WHITE
WHITE
May 21, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
37 people viewed this question
Top Dryers Experts
