Question about Horizon T50 Motor Control Board
Displays light and beeps when push function buttons, but motor wont run and no controls work
Took apart and checked ribbon cables and all conections when unplug from motor board at bottom of machine and plug back in red led UP light comes on and elevation motor tries to work but will not move. Could the motor be bad to the elevation function?
2 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: when you push the start
Unplug treadmill from wall outlet. Wait 60 seconds, allowing lower board to discharge built up energy.
Then reseat the 12 pin connector.
I had same issue, but mine was under warranty and they sent me a board. Have you tried a calibration?
http://www.horizonfitness.com/uploadedFiles/Customer_Support/Horizon_Fitness/Troubleshooting/Treadmill/Universal_Calibration_Instructions.pdf
Call T/S, good techs there.
Horizon Fitness Tech Support a call, toll free, at 1-800-244-4192. We're open Monday through Friday, 8:00 am to 5:00 pm Central Time
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Posted on Jan 21, 2011
Norditrack E7 SV display malfunctioning.
The control panel is defective is the most likely cause.
Jan 18, 2017 | The Video Game Consoles & Games
Ribbon cable torn off front
ribbon cable is just pushed into where it came out of. There will be a locking mechanism on the point of connection. Ribbon wont go in all of the way until it is in the unlocked position. Once inserted, lock it again.
Jan 01, 2014 | Cell Phones
Tappan microwave has se or 5e on diplay wont push buttons
this a problem a dust in the control board keypads, You must open the keypad, and clean any connector with contact cleaner specially the ribbon cable or plastic and use pencil eraser for to fix the corrosion, dust, and try again.
Jul 08, 2013 | Microwave Ovens
Kenmore oven keeps beeping, shows F7 on display.
HI. this is a board fault. the control, or erc/eoc must be replaced in order to correct this issue you are experience.
The Function keys on the integrated touch pad are damaged.
Sep 16, 2009 | Kenmore Ovens
Oven is beeping flashes f7. goes from push start for hi broil to low broil
HI, your key pad or touch pad is malfunctioning. most units will have a integrated touch pad. In this case, you will need to replace the entire control board, in order to restore normal functions. Now, if you units control and key pad are separate entity's, i recommend this test below to determine which is at fault.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Aug 21, 2009 | GE Ovens
Error code f7 on Kenmore wall oven 911.41165791
There is a probelm with the control panel. You can fix it for about a penny. The panel has a printed ribbon cable that plugs into the relay board. The ribbon cable is actually two cables pressed together, which can be seperated by simply lifting them apart. The ribbon cable has a defect in that the plasic insulation is defective, causing the leads between the two ribbons to cross, or short circuit. Simply place a thin sheet of paper between them, and make sure you push the paper down all of the way to the plastic housing, fold over the edges around the cable, you are done.
May 27, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Quit working only beeps
i took my camera apart,and cleaned all contacts including battery posts and contacts for battery in camera. when removing the flexible ribbons take note that some have 2 wedges on either side of the connecters, which must be gently prised away from the conection in order to free the ribbon. the lcd screen (if i remember correctely) has a black tab running the length of the connecter, and this gets prised up to free the lcd screen--FOR CLEANING, I RUBBED EACH CONNECTION WITH A PINK PEARL PENCIL TYPE ERASER. CAMERA NOW WORKS GOODY GOODY.
Dec 19, 2008 | Samsung Digimax D53 Digital Camera
Humidity buttons don't seem to work.
the control board is a very simple design and it is to signal and switch options like fan speed, power on/off, humidity up/down and sets the on/off run time. Like above the board does collect dust,but the true problem runs deeper.
My unit was stuck in run mode with the fan speed, humidity and run timmer non functioning. the unit worked and the power switch turned it on and off. The display said ON
I removed the front cover (two screws) and slight pressure on the side of the cover to remove it. This exposes the control board. The control board can be removed by removing the 6 screws on the board. the cable can then be removed by pulling out the multi-pin ribbon cable.
I diagnosed that only two of the 5 push button switched were functioning. There was also dust and mold on the board. This board is poorly protected from the moist air entering the unit and the constand moisture causes corrosion on the board, the switched seem to be the weak link.
By using a multi meter I noted that only the power switch and the humidity down button were making contact when pressed. Now it all came together. I could turn it on and off. and if you press the humidity down button to the lowers setting (ON) means run all the time.
I used a elecronic contact cleaner and sprayed it into each of the switches. I wiggled it around and blew it out with canned air. It took a few wiggles and blasts but all switched then made contact. I the board back on and tested all functions and it was like new. The contact cleaner should keep it protected for a while. The non functioning of the switches works both ways. They can stick on also. This would explain most of the other control problems. These switched are common and can be picked up at Radio Shack. On a do-it-yourself bananna scale it was a 2 for me, but I had the tools and the spray. I am not sure what sears gets for the PC control board,but this is the issue and if they were to address this the unit complaints would drop greatly.
Feb 03, 2008 | Kenmore 54701 Dehumidifier
Sony CDX-M630
not open the face? or not get on the stereo? if not open the face maybe is too fit on the space for the stereo, check down if have space, if dont get on, check if are well conected
Nov 02, 2007 | Sony CDX-M630 CD Player
Kenmore electric built-in oven control panel beeping
We had the same problem. F7 error code and beeping. We turned off at the breaker- left it off for hours turned it back on and still f7 and beeping. We call repairman to come out and he removed the cover on control panel (3 screws on bottom of controll panel and it pops off). He unplugged the ribbon keypad connection - Cleaned the ends with a pencil eraser and said it is fixed and we would not have a problem.
Well, that was a fast way to spend 60 bucks but it has been a week and the oven has been great. No more beeps or error codes. SAVE YOUR MONEY DO IT YOURSELF!
Oct 08, 2007 | Ovens
Horizon T50 Motor Control Board Logo
22 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
