Question about Bugaboo Cameleon Baby Gear
My bugaboo chassis has broken where the handlebar attaches to the base. It seems that a clip that holds the handlebar to the base of the chassis broke. I see that I can buy the clips on ebay but I a
There are three black circular connectors to the base on each side. One is for the handlebar and two are for the wheels (front and back). Its the outside connector that the pin broke off from.
  • adrienne mauntel Jan 14, 2013
    Here's a little more detail for the issue plus a picture... where the handlebar meets the two cars that connect to the wheels, there are three black rings that come together, attach to a cross-bar and are secured with a silver disc on the outside of the bar. My silver disc broke and fell off. When that happened, the clip inside the first black ring also broke (I believe this clip controls the telescoping handle). I need to replace the clip as well as the disc but am looking for some instruction on how to do this.
  • 126 Answers
SOURCE: Bugaboo Frog
CONTACT BUGABOO
PHONE: 1-800-460-2922
E MAIL: service@us.bugaboo.com
WEB SITE: WWW.BUGABOO.COM
Posted on Apr 28, 2008
  • 126 Answers
SOURCE: broken harness on bugaboo frog
CONTACT BUGABOO
  • 11 Answers
SOURCE: Bugaboo cameleon handle bar
HIYA.... YOUR BEST BET IS... TAKE THE HANDLE BAR BACK OFF AGAIN. TAKE THE SPRING OUT OF THE SIDE THAT WORKS FINE AND TAKE IT TO YOUR LOCAL DIY STORE AND GET A REPLACEMENT, IF YOU CANT FIND IT ASK SOMEONE IM SURE SOMEONE WILL BE ABLE TO SEND YOU IN THE RIGHT DIRECTION... PROVIDING ITS JUST THE SPRING, IF YOU BUY ANOTHER TO REPLACE THE BROKEN/LOST 1
THIS SHOULD SOLVE THE PROBLEM :)
Posted on Jul 14, 2009
  • 11 Answers
SOURCE: Bugaboo chassie
HIYA... THE CHASSIS STAYS FILMSY AND UNSECURE UNTIL THE SEAT UNIT OR CARRYCOT UNIT IS ATTACHED, THEN ITS LOCKED INTO PLACE AND SECURE :)
IT ISNT A FAULT, THIS IS JUST HOW ITS MEANT TO BE
HOPE THIS HELPS X
  • 23 Answers
SOURCE: Spare Parts for Bugaboo Wheeled Board
For Bugaboo spare parts, the best way is to contact Bugaboo direct (www.bugaboo.com) or a local Bugaboo stockist who should be able to order in the spare part for you.
Posted on Sep 17, 2009
When I open the frame of the bugaboo, I push the knobs towards me and I successfully lift the handlebar up. When I try and lift the handlebar up to kick the wheels out, I can sometimes do it but at other...
There a three parts / assemblies to a Bugaboo Chassis that all pivot around the central hub (the thing with the large chrome domes). The white release buttons only control the handle locks in the outer set of hubs. The two wheel assembles are locked by the seat / bassinet clipping on to the frame and locking the inner hub. This hub is the heart of your Bugaboo and there is a reason Bugaboo put a can of silicon spray in the maintenance kit. Keep those hubs and the brake lever well lubricated and you'll get good service from your Bugaboo. Check out my Tips section for more info.
Jan 14, 2011 | Bugaboo Frog - Black Stroller
My bugaboo cameleon chassis 2007 model won't open,
Go to www.buggypitstop.co.uk they are the only company that repairs bugaboo chassis
May 19, 2010 | Bugaboo Cameleon Jogger
My Bugaboo Chameleon bent
The best advice that I can give is to contat Bugaboo (www.bugaboo.com) who will be able to advise on the cost of a replacement chassis. Alternatively, you can purchase these from eBay most of the time.
I hoep this helps.
Apr 14, 2009 | Bugaboo Frog Stroller
Bugaboo chassie
HOPE THIS HELPS X
Mar 13, 2009 | Bugaboo Frog - Black Stroller
Dec 08, 2008 | Bugaboo Frog Stroller
Unfolding the Chassis - Handlebar Loose
I had the same problem... the handlebar would 'un-pop' and shake around a lot making the whole stroller unsteady. I started to get all upset and worried about sending it back but i decided to clean it first. After using the silicon spray from the maintenance kit on the joints of the stroller IT WORKS LIKE NEW! yay! Try this before assuming its broken :)
Apr 12, 2008 | Bugaboo Frog Stroller
Faulty Bugaboo Bee
I to had this problem, my problem was i also lost proof of purchase so couldnt get a new chassis, Bugaboo even though the prams havent been out for two years wouldnt replace so i had to try and either fix the pram or buy a new chassis for £235. I then read on the internet about how to remove the rivets on the chassis, you need a rivet gun and a drill the problem was the rubber had broken and fallen way down the pram chassis and if you can replace this with some new rubber the chassis is good to go (just make sure you do this slowly so you can see what part goes back where), you need to buy new rivets as when you remove the old olds these are no longer useable, i am soo happy i tried to fix this, it took me and my sister 1/2 hour and saved me £235 (the price quoted by Bugaboo for a new chassis). Hey hope this helps anyone and saves you having to line Bugaboo pockets, hey theres a clearly a niche in the market as Bugaboo do not have a work shop, they clearly want you to keep spending!!!!
Mar 22, 2008 | Audio Players & Recorders
Bugaboo Chameleon's Handelbar
CONTACT BUGABOO
Feb 02, 2008 | Bugaboo Cameleon Jogger
Bugaboo Frog
CONTACT BUGABOO
Aug 16, 2007 | Bugaboo Frog - Aubergine Stroller
Baby Gear Logo
296 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
