Question about EliteGroup P4VMM2 V5.X Via P4M266A Motherboard
CMOS SETUP WRONG
I have VIA P4VMM2 motherboard, whenever i switch on my PC its showing cmos setup wrong n also replaced new cmos... plz solve this problem
    Sergeant:
    Champion:
  • 259 Answers
Go into the bios setup and change it
Posted on Jan 22, 2009
When i switch off power and restart the pc i get error 'cmos/gpnv checksum bad' and sometime 'cmos setting wrong press f1 to set defaults or press f2 to enter cmos setup'. I replace the...
sir have you tried clearing the jumper settings. if it still persist remove power supply of board and cmos battery for 5 mins. Then try to startup.
Sep 14, 2011 | Asrock P4I45GV...
I need to change password
Switch off the power to the PC. If you have forgotten the password for CMOS setup, locate the CMOS reset/clear jumper terminals on the motherboard. Put a jumper across the terminals for about 10 secs. Remove the jumper. Switch on the PC. Press Control+Alt+Delete to go to CMOS setup & put a new password in the setup.
Jul 25, 2011 | Computers & Internet
AFTER SWITCHING ON, SCREEN STAYS FROZEN AFTER SAYING CMOS CHECKSUM ERROR- DEFAULTS LOADED
When starting your PC, the following error message is displayed:
CMOS wrong
CMOS MEMORY size WRONG
CMOS Checksum Bad
CMOS checksum error defaults loaded
Warning! CPU has been changed please re-enter cpu settings in the cmos setup and remember to save before quit!
You are prompted to:
Press F1 to resume
Press F2 to load default values and continue
This is due to the fact that the CMOS, which contain data related to the BIOS, has been reinitialized and that your PC has been reset to factory settings.
Solutions:
Reinitializing the BIOS
  • Change BIOS battery
    • If the problem persist this may be due to the fact that the battery powering the CMOS (when the computer is shut down allows the CMOS to store information), is depleted.
    • The CMOS battery is a small pin found on the mother board, you can refer to the manual provided with your motherboard to change it or have the nearby computer technician change it for you if you don't want to risk any damage.
    • More information with: Replacing the battery of your motherboard (CMOS battery)
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | Sharp Actius PC-RD10 PC Notebook
Bad cmos dell motherboard
If u changed the CMOS battery then it should not show the f1 continue . first remove your BIOS chip on the motherboard and then replace CMOS battery and then replace it again after 5 minutes. your problem will be solved
Aug 26, 2009 | Computers & Internet
Press F4
svjyrat
"always message to press F4 at the time of star up". this problem happen when CMOS detect any error. is also happen if CMOS battery fail (Chack sum error).
to solve this problem at first check CMOS battery (it voltage less then 3V or not) if it bad then replace it. u can buy this battery form any computer accessories shope.
or if u not connect floppy drive, and controller enable. if u desable floppy drive contoller from CMOS setup (in intel mother board is show BIOS setup) then this problem solved.
Jul 03, 2008 | Intel Motherboard
Problem regarding usb booting
the hard drive registered in the standard cmos utility is the only one that could be registered for boot in advanced cmos setup and no other, if your usb hard drive and pen drive could be registered in the advanced cmos setup - where boot options are registered, surely it will boot your pc.
uzowuanya
e-mail:uzowuanya@yahoo.ca
Feb 16, 2008 | Asrock P4I45GV R5 Motherboard
My ecs p4vmm2 cannot open to windows
you must have a faulty floppy disc unit, you need to press F2 or Del to get into the bios and check the time and date if they are wrong then the cmos battery needs changing.
Sep 11, 2007 | EliteGroup P4VMM2 Motherboard
Motherboard related problem
you need to update your bios for the later stepping proceesors from asus, download to a floppy disc and insert before you start up your system http://support.asus.com/download/download.aspx?SLanguage=en-us
Jun 14, 2007 | ASUS P5PE-VM Motherboard
P4VMM2 - ???
disconnect drive 'A' floppy drive and see if it will boot up without it connected. It may be that the floppy is faulty if you know the ide cable is on the correct way round, as your pc may be set to halt on all errors
Apr 09, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
158 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
