Question about HP LaserJet 5000n Printer
HP Laserjet 500N error 41.3 unexpected paper size?
How to fix error 41.3
SOURCE: hp laserjet 4350 printing slow down
Look on the left side of the tray. There should be 3 white fingers that stick out. Make sure they aren't broken or out of place. Also slide the paper size lever and make sure they work properly. There is also a custom and standard switch. Try to print out of the MP tray(fold down tray). If it prints normal speed, you probably have a problem with the tray.
Posted on Nov 16, 2006
CompuGuy44
  • 432 Answers
SOURCE: HP COLOR LASREJET 3500 41.3 ERROR
Check your settings under the properties menu. and in the software your using.
Posted on Jun 26, 2007
Soulvisitor
  • 1113 Answers
SOURCE: HP LASERJET 4250n PRINTER-PROBLEM WITH PAPER JAMS AND "FUSER ERROR"
Put a maintence kit in your machine, easy install, everything just clicks in, Every 200 000 prints it should be done, it includes the fuser, all feed rollers, sep pad and transfer roller.
These are great printing machine, they only ever need the MK and on this model a fuser drive gear wears and get noisy, but once that has been done once, it is ok from then on.
KIts seem expensive but they are meant to last 200 000 prints and usally do. These are one of the best most reliable printers in the market.
fee693c.jpg LINK to part info
Posted on Jan 09, 2008
Nikhil Gedam
  • 87 Answers
SOURCE: hp laserjet 4250
This happens when the printer is printing duplex job. i.e. trying to print the other side of the page.
However check the functionality of the printer by performing Paper path test.
This would help us to know whether the printer as a stand alone ... is fine or not.
From the control panel of the printer, scroll to Diagnostic > paper path test.
Select the following in sequence.
Source: All trays
Copies: 10
Duplex: ON
Print Test Page
Check if you get the same error.
If yes, upgrade teh firmware of the printer.
Let me know the end result. We still have more depending on the above test.
- Nikhil
Posted on Nov 04, 2008
  • 4 Answers
SOURCE: HP 1280 Error message
OK, to make this clearer, I had the same problem on my HP C7180. It seems to be rampant throughout their Multifunction printers.
My Fix, combining several others:
1. Go to Printers and Faxes on your Start Menu. In the Printers window, select Server Properties from the File menu. Use the Forms tab of the Print Server Properties dialog box to view printer forms. You may also see lots of forms that you wish your printer could see, but don't worry, it'll see the one you create now. And be sure when you create your form that you use the narrower dimension for the width and the longer dimension for the height. Usually for envelopes you will print in landscape mode.
2. Select the Create A New Form check box.
3. Enter a new name for the Form in the Form Description For field.
4. Use the fields in the Measurements area to set the paper size and margins. *Use the narrower dimension for the width and the longer dimension for the height*.
5. Choose the Save Form button to save the form. The Save Form button only gets pick-able when you type in a different name than what's there already.
Now go to your document program, such as Word. Make sure the window for the document you want to print is the active window. Select File/Page Setup..., Paper Size Tab, and there select the form you just created from the dropdown list
Still in your document program, select File/Print... then Properties. Select the Features tab, which may be differently named. Under Resizing Options/Size dropdown, select More... and there you'll find your newly created form down at the bottom, under Custom. Pick it.
If you're printing envelopes or other things where the way you view it it's wider side-to-side than it is tall, be sure and select "landscape" in both "page setup..." on your document program and in File/Print.../Properties/Features?Basic Options.
When I did all this methodically, I was able to print my Christmas envelopes. Yay!
Posted on Dec 18, 2008
3800 printer 41.3 UNEXPECTED SIZE error
The paper you are feeding is not the size that the printer is set for. Check the paper sizes that are set on the printer to make sure they are correct. Also make sure that all the tray stops are in the correct position for the paper that you are using. If you have worn rollers, the paper may be slipping when fed and causing a timing issue.
Sep 03, 2014 | HP LaserJet 3800n Printer
Laserjet cp1215 error message unexpected paper size
Did you check the settings non the paper cassette?Also check the properties of the document and make sure it is set to the proper size.It could also be double feeding causing the paper to appear to be longer.
Apr 14, 2014 | HP LaserJet Office Equipment & Supplies
Unexpected paper size message
go to the printer preference settings and change the paper size to A4 if you are using A4 and paper type to plain paper. and do the same on the printers settings menu.
Nov 12, 2013 | HP LaserJet 4050n Printer
Error 41.3 on a 4345mfp
41.3 UNEXPECTED SIZE IN TRA 2
Dec 08, 2011 | HP LaserJet 4345mfp Printer
What is 41.3 paper error on the hp laser jet4plus printer
41.3 is paper error on hp laserjet 4 plus is an unexpected paper size error. Check your paper guide settings.
Jul 12, 2011 | Office Equipment & Supplies
41.3 unexpected size in tray 2.my printer is hp laserjet 4200.can you solve this
Thank you for contacting FixYa with your printer Inquiry.
41.3 Unexpected Paper Size Explanation
  • The printer detected a paper size different than what it was expecting.
  • This is typically caused if two or more sheets stick together in the printer, or if the paper tray is not properly adjusted.
Recommended action
  1. Reload the tray with the correct paper size.
  2. Ensure that paper in the tray is loaded under the front and back tabs.
  3. When printing from tray 1, verify that the correct paper size is selected in the control panel (see the Paper Handling Menu section in the User Guide ).
  4. When printing from tray 2, 3, or 4, verify that the three paper size adjustments on the paper tray have been made correctly (see the description of adjustments in the section on Loading Trays 2, 3, and 4 in the User Guide ).
  5. After performing the actions above, press GO. The page containing the error will automatically be reprinted if jam recovery is enabled. Or, press CANCEL JOB to clear the print job from the printer's memory.
    Hope this helps. Please keep us updated and remember to rate this answer.
Feb 07, 2011 | HP LaserJet 2420 Printer
Hp2840 printer error "Too large to print" even with a very small file.
The unexpected paper size may cause the above error. Whenever your printer detects an abnormal size, this error appears on the device. It mainly happens when more than one sheet are attached with each other or when the paper trays are not set properly. To handle this issue, reload the trays with appropriate paper size followed by front and back tabs. For all the trays verify that correct paper size adjustments have been done. Now enable the jam recovery button and press the button 'GO' to print your document.
http://www.fixya.com/support/t6355639-hp_2640_half_right_side_page
Oct 08, 2010 | HP LaserJet 2840 Printer
Our hp 4200dtn jams frequently and often spits out several blank sheets. when it jams, the error message reads "unexpected size"
Make sure the guides for width are snug, and also "fan" the paper before putting in the tray
You might also try a heavier paper or different brand as a test.
Oct 09, 2009 | HP LaserJet 4200dtn Printer
hi ray, it's chris. i called your cell phone, but figured you might see this. replace the registration clutch. after some research, this seems to be the solution given that should solve the issue in that printer, and it's an independant part from the paper pickup assembly...
RK2-0247-000CN
chris
May 27, 2009 | HP Color LaserJet 3500 Printer
HP LaserJet 5000n Printer Logo
229 people viewed this question
Seeker5211
Seeker5211
