My hot water keeps going warm then cold. The pilot light starts and fires up but then it goes off and starts up again. Need help please. Thanks
  • 4 Answers
Possibly the thermostat cut off switch is not working
Posted on Jan 11, 2013
  • Raman Vasanthan Jan 11, 2013
    Where would the it be, b24 hydroline
2 Suggested Answers
SOURCE: My hot water keeps going Luke warm the. Cold. Central heating is working, pilot light is firing up when I put the hot water on. I think it could be the diverter valve. Could it be anything else. If so
check the hot water coming from a faucet, if it stays hot your problem is in the thing getting or using the hot water, maybe the hot water line is sitting somewhere before it is being used.
If the water is luke warm coming out of the tap the problem is the hotwater heater itself. The coldwater inlet pipe going into the heater has been eaten away inside and is now too high in the tank.
Posted on Jan 05, 2013
Electronic ignition hot water heater (6gal) lights but wont get water hot. The red light inside my RV goes off and back on after about 3 minutes. When I checked the unit outside, the pilot is lt, but not...
check to see if setiment has settled on the pilot....blow it out with air if it has. This issue comes up often with water heaters and rv refers. If that is not the problem and the pilot remains lit, but never increases when the thermostat is turned up, you probably need a new gas valve/thermostat.
Feb 26, 2014 | Jayco RVs
Junkers manual gas hot water
What are you expecting to happen?
I assume the water heater and water inside it is cold (otherwise you would not be lighting it). You light the pilot. The main burner comes on and the pilot lights it. The main burner should stay on until the tank is hot, When the tank gets hot the main burner should shut off but the pilot stay on. If you draw hot water, cold water will run in and cool the tank. If yu do nothing the tank will eventually just cools off. then the main burner should come back on to reheat the tank.
Nov 05, 2013 | Water Heaters
Water not hot even thermostate turned to high. The pilot light is on. Shoulder I be able to visualise the burner actually firing.,or hear it firing. I can see the pilot light clearly. Please help
If you have cold water now, you should hear the unit fire up and run while heating water. Proceedure would be; pilot is lit with thermostat at pilot setting. Once pilot is lit, you turn up to desired temp setting and you should hear the heater running. Depending on lighting, you should be able to see it slightly brighter and may flicker some while heating.
Apr 25, 2011 | Rheem Water Heaters
Do I need to replace the thermocoupling on my Reliance 501 gas water heater? Model is 5 30 NOMT7 C. Recently, I've noticed an intermittent problem with the the hot water not staying consistent. So we're...
The thermocouple is a safety for the gas valve. It tells it the pilot light is lit. If your pilot light is not going out and the burner fires when you turn up the thermostat, it is all working as it should. In other words, if you don't need to re-light the pilot, your thermocouple is OK. Turning up the temperature of the water is a good idea, just be careful not to burn anyone with the hotter water. You mite want to try a water saver shower head. Some don't throw enough water to get the soap off, but I bought one that can be turned to adjust flow and we have been happy with it. If I missed what you need from this, please let me know. Roger
Apr 10, 2011 | Heating & Cooling
It seems to be perking correctly but stops and then starts to perk again and again, this continued until I unplugged it, and also the light to indicate it was done never came on
Your pot needs a keep warm element. the main element works ( perks and perks) The thermostat works ( it turns the main element on and off.) The pot goes on and off because the water is getting cold The problem is the keep warm element. The reason, your pot perk's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. Thanks and please ask if you need more help. Go to repairshack.com for the part. Ron
Sep 25, 2010 | Faberware 10-22 Cup Coffee Urn
Pilot light is lit fires up for 30 seconds then shuts down.
do you have a CO detectors? If so try resetting them
Feb 22, 2010 | Heating & Cooling
Water heater doesn't keep running
Sounds like youo have a problematic gas valve. But I would get a gasfitter to replace it. Not for the amatuer.
Nov 20, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
When i turn the hot water tap on to get hot water the red pilot button keeps going on off and clicking , after some time runing hot it goes cold and the other warning light starts flashing. its a...
Air conditioners do not provide hot water, and gas air conditioners are very rare. I think you would have better results if you post this in a different category.
Jul 27, 2008 | Heating & Cooling
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
