SOURCE: Brother mFc 7820
I had work done on my laptop. I have a Brother MFC 7820N printer, scanner,fax,copier. I cannot find my cd for setting the drivers to have my laptop use the 7820N. Where can I pull the information down on line to enable my laptop to use my printer?
Shaun at [email protected]:
SOURCE: Problem with my fax Machine MFC 420CN
You can cancel a fax job that is stored and waiting in the memory.
1 For MFC-210C,
press Menu/Set, 2, 5.
For MFC-420CN,
press Menu/Set, 2, 6.
Any jobs that are waiting will appear on the LCD.
2 If you have more than one job waiting, press ▲ or ▼ to select the
job you want to cancel.
Press Menu/Set.
—OR—
If you only have one job waiting, go to Step 3.
3 Press 1 to cancel.
To cancel another job go to Step 2.
—OR—
Press 2 to exit without canceling.
4 Press Stop/Exit.
That should do it for clearing faxes you dont need you can also print off all the faxes in the memory and I believe that clears it.
Enjoy,
Lee
SOURCE: our Brother MFC 9440CN laser printer memory, keeps
When Fax Storage is set to On, copies of all received faxes are stored in the memory, thus using up a portion of the memory available for other functions.
The Fax Storage
feature is utilized for Fax Forwarding, Fax Paging and Remote
Retrieval. If you do not need these features, verify that Fax Storage
is set to Off by doing the following:
If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
SOURCE: Brother MFC-5890CN Printer
It sounds like your print heads may need cleaning. However, here is the link from Brother support for your MFC-5890CN on how to improve print quality:
Brother MFC 5890 Print Quality
SOURCE: How to change Brother MFC 5890CN Language
Please follow the instructions below to change the language to English.
1. Turn off the machine
2. Hold in the MENU button.
3. Turn on the machine while holding the menu button
4. Maintenance should come up onscreen and the lights should flash.
5. Key in the numbers 74 and press Mono Start button.
6. Key in 0004 and press Mono Start button.
7. "MAINTENANCE" appears again on the display.
8. Key in 99 at the maintenance prompt to exit to the date and time
It should be now in English.
