Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Television is on but no sound everything else is working
I have a mitsubishi wd 52525 dlp television i just moved it and am not getting any sound i have tried everything i think
    President:
  • 1,952 Answers
Usually when you see a symbol like that, the speakers have been disabled. Is there a menu option for turning off the internal speakers? This option is different than Mute.
Posted on Jan 22, 2009
  • mohammed marika thambi
    mohammed marika thambi Jan 22, 2009
    Is the "mute" indication always on or is there just no sound? If the
    sound is off, check for the speakers being off through the menu first.
    If they are on, then you need to look at where the speakers connect to
    the main board. There should be a small IC connected to a heatsink
    nearby. That IC may be bad and need to be replaced. It should be a
    TAxxx or TDAxxx,
Mitsubishi WD-52725 DLP fast green blinking light, bulb is ok, no picture, no sound
I have several suggestions, are you open to them?
I will ask you to do simple things and tell me what you find.
Steve
Oct 28, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Where can i get a color wheel replacement for my DLP Mitsubishi WD-52525 210719 TV? I have changed the lamp and still the TV goes to black and the status light goes on.
This DLP tv model don't have a colors wheel.U hear alot of clickings sound,when power turn on?The Ballast board it dead.This board,job to help projection lamp to ignite.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Tv stays on for about 3 minutes the shuts off
If it is Mitsubishi WD-52525 DLP TV then it sounds weak lamp problem in TV and TV needs lamp replacement.
How old is this TV and did you replaced lamp recently?
Lamp replacement is written in user manual of TV and it is easy work.
Please buy Mitsubishi original lamp for TV safety.
Thanks.
Oct 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Apr 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD 52525 mitsubishi - how to I get a copy of manual and check balist - or dm board?
you can get the service manual at the following link. Its under the mitsubishi category listed as the V26 DLP service manual.
http://servicemanuals.vstore.ca/
Sep 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Electrical chasis cooling fan for Mitsubishi wd 52525
There are several Parts Houses that carry this part. The one I think that is the easiest to deal with is Andrews.
The URL is:
https://dealer.andrewselectronics.com
Can't find it there, reply to this post and I will respond.
Dec 14, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
