Question about Canon PowerShot G11 Digital Camera
Lens error, restar camera - Canon PowerShot G11 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Posted on Jan 11, 2013
  • 21 Answers
SOURCE: my lens is on the fritz
Check the lens and camera body's contact points for wear, damge or dirt
Posted on Jan 03, 2009
BillB-SA
  • 2761 Answers
SOURCE: Camera wont turn on. Says lens error and restar camera
If the camera has recently been dropped you may have lens damage that will require professional repair. If it has not been dropped, your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may require professional repair.
Posted on Oct 20, 2009
t00nz
  • 4738 Answers
SOURCE: camera is saying lens error, please restart
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Posted on Mar 12, 2010
lock123
  • 6831 Answers
SOURCE: lens error..restar camera
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 30, 2010
t00nz
  • 4738 Answers
SOURCE: lens error and restar camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Mar 07, 2011
How restar camera powershot ELPH 310 HS
Turn it off and then on.
If you're getting a "lens error" then try these procedures.
Dec 19, 2012 | Cameras
Lens error and restar camera
Mar 02, 2011 | Canon Digital SD900 / IXUS 900 Ti Digital...
Camera is saying lens error, please restart
Mar 09, 2010 | Canon PowerShot SD1000 Digital Camera
Oct 19, 2009 | Canon PowerShot S3 IS Digital Camera
My lens is on the fritz
Jan 03, 2009 | Canon PowerShot G7 Digital Camera
Canon PowerShot G11 Digital Camera Logo
63 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
