Question about Apple iPhone 4 Black Smartphone
Hi i am going to put a new battery into my iphone 4 how long would i need to put it on charge for as its a new battery in the phone
    New Friend:
Simply charge it for eight hours, with the phone switched off, thank you
Posted on Jan 11, 2013
How can I recover the data in I-phone 4 in Edmonton AB
If you turned on iCloud backup before you broke your phone, you can go to the iCloud website (http://www.icloud.com), log into your account using your user name (usually your email address) and your password. There you will find any data you backed up. If you didn't back up your data to iCloud, the only way I know is to fix your iPhone if possible, depending on what's wrong with your iPhone. If it simply stopped charging and won't turn on, a new battery may take care of the problem, or it may need a new charge port. If the phone actually turns on but there's nothing on the screen, you can still connect the iPhone to your computer, start iTunes, and see if your phone shows up as connected. If it does, go to the backup section in iTunes and run a complete backup, and choose save backup to your computer. That way when you get a new iPhone, you can restore the backup onto your new phone.
Oct 07, 2014 | Apple Iphone 4s I Phone 4 S Factory...
How long should it take to recharge my iphone 4 brand new battery ?
The first two or three times, don't look, but normally, when you use a 1 A (1000mA/h) charger, within 4 hours. I don't like to use the iPad charger that can deliver 2 Amps, because it will heat up the battery. And the wormer it gets, the sooner you need a new battery.
But, if you want to find out the quality from your battery, just visit the genius bar in an Apple store. They test it for free, and also can point out if there is an app consuming too muck power. I went in with my iPhone 4 and they found an older firmware version. They put in a newer firmware (not the iOS) and since then it is running 2 or 3 days with one charge, with a 4 years old battery. Before I went in, the battery would drain in less than 6 hours.
Sep 30, 2014 | Apple iPhone Smartphone
Why wont my iPhone charge
Don't try anything go to near by Apple Care and replace your charger and get a new one. For any more guidance in solution on apple system problem follow Apple and Mac Technical Support .
Jul 25, 2014 | Apple iPhone 4 Black Smartphone
What would cause an unlocked, fully charged iphone 4 to turn its self off when using a straight talk sim
I had a common problem with my iPhone 4. Using it with maps, it drained the battery within an hour or so. I thought I destroyed the battery. I went to the Apple store, and they offered me a free of charge (3 years old phone) diagnose on the genius bar.
I had to unlock the phone and the genius started an app (I could not see what app) and then put it next to a iPad. The iPad had a program running and within minutes there was the report. The battery was almost as new, but there were a couple of apps, fighting for the first place and draining my battery. It was a known problem, caused by an old firmware (NOT THE OS). They offered me to update the firmware, and half an hour later i was outside with a great working iPhone 4. It still works perfect and I do have a battery life of 3 days (I don't make many calls)
So if you have time to visit the Apple store ask them the same. If he store is not close to you, I would make an appointment using the net. Before you leave to the store, make sure you have a backup, because they will wipe the whole phone.
Success.
Jul 17, 2014 | Apple iPhone 4 Black Smartphone
Iphone 4 battery
If your iPhone battery gets low quick, try disabling features within your iPhone which may help increase battery life.
1. Decrease the screen brightness of your phone.
2. Turn off 3G when not in use ( 3G can decrease the battery life greatly )
3. Turn of Location Services in Settings. ( GPS can decrease bettery life greatly )
4. Turn off bluetooth.
5. Charge your iPhone up to 80% everytime and then stop charging. ( Studies show that charging up to 80% everytime can help increase the life span of your iPhone battery )
Feb 25, 2013 | Apple iPhone4 4G iPhone 4
Hi, I have an iPhone 4 and have ha t for nearly a year now but recently it's started not to charge, it only charges once the battery has gone completely flat so I have to use all the battery and then...
your phone charging ic as voltage protection circuit not working - give regulated Dc 5.6 v ( 600mA - 750mA ) - or" goes to service center.
May 28, 2012 | Lands Phones
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
My iphone not charging and on..help me!! :(
1. Check your charger with another iPhone. If it is working, your battery may be dead. If not, replace the charger. You can buy some at www.amazon.com or any other site you like. 2. Try charging the phone on your laptop via USB cable. Hope this helps. If so, please rate. Thank you
Jan 15, 2011 | Apple iPhone Smartphone
My iphone stopped charging last weekend, i have seen someone in the apple shop who says there is water damage to the charge area. He said there are places that can sometimes put not parts in, does antone...
okay, heres what you need to do, if its a 3g/3gs, if its an original your out of luck. anyway the charging assembly is the same as the speaker and microphone set up its all one piece, search youtube on how to open an iphone, once you do you can see an assembly on the bottom, pull up the tab that says "4" there will be 4 screws to remove in each corner of the set up. once removed pull it out and replace it with a new one. (you can buy these off ebay, search for iPhone 3g/3gs charging assembly)
May 09, 2010 | Apple iPhone Smartphone
Apple iPhone 4 Black Smartphone Logo
41 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
