Question about Whirlpool Refrigerators
Whirlpool refrigerator WSF26C3EXW01
17 X 113/4 glass shelf
3 Suggested Answers
aasc
  • 1606 Answers
SOURCE: I have a model ET20GM Whirlpool refrigerator.
Remove the food and icemaker (if it has one) . Remove all the screws holding the rear panel on and remove the rear panel . Using a hair dryer , start in the middle below the coils , and defrost until you see the drain hole . Keep defrosting the hole , sometimes hot water helps , until water starts to go down . Use a small hose inserted into the hole , and blow thru to blow out any debris collected in the drain tube . Get a piece of ALUMINUM wire , stripped of insulation (14-16 guage ) and put as far into the drain hole as it will go without any force . Sometimes bending slightly will help it go farther . Wrap the other end 1 or 2 turns around the black rod ( defrost heater ) above the hole . When refrig goes into defrost , the heater will transfer heat to the aluminum wire , keeping the drain from freezing again . Reinstall the back panel and icemaker ( if equiped ) and the food .
Posted on Aug 29, 2009
martineznoe8
  • 92 Answers
SOURCE: I have a kenmore refrigerator
HI ,CHECH ON BACK OF THE BOX COULD BE THERE..
Posted on Jul 05, 2011
How to remove the glass shelf for better cleaning PSC25MSSC
if the glass has plastict trim like pieces across the front and rear edges try pushing up on the glass close to the plastic trimat th rear end, the trim should swivel up and the glass pop out of the groove
May 03, 2015 | GE Refrigerators
Refrigerator glass shelf shattered
you purchase the new shelf from the manufacturer, the glas they use in shelves is specialised, be careful.
Nov 16, 2013 | Refrigerators
I need a glass shelf for the crisper drawers 22 5/8
The glass shelf is no longer available but having someone cut glass to size will work, Thanks Sea Breeze
Nov 19, 2012 | Refrigerators
Broke shelf
what shelf did you break?http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Refrigerator-Parts/Model-GS5SHGXKS00/1198/0165000/W0104054/00003?blt=06&prst=&shdMod= go here and look up the part you need,copy and paste.
Sep 13, 2011 | Whirlpool GS5SHGXKS 25.2 Cubic Feet Side...
Maytag refrigerators mtbe1956de liquids have dripped on to the bottom glass shelf and seeped under the edges where it cannot be cleaned. do I have to remove the vegetable drawers and totally dismantle the...
brute force on the glass shelf.... it was just stuck in place by the cold sticky liquid that had seeped under the edges and bonded the glass and plastic together
Jan 12, 2010 | Refrigerators
Cracked border to bottom shelf of frigidare refrigerator
240350614 is the part number for the shelf border that you need...price is around $26
Oct 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Tempered glass shelf shattered with nothin in the
This is caused by stress in the glass which was not properly relieved in the manufacturing process -- in other word, it's a defective piece of tempered glass. The expansion & contraction produced when you cleaned it (subjecting it to changing temperatures) caused the glass to explode.
May 13, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Maytag Elevator Shelf
Let me just say, your post helped me, because I realized that I was not going crazy.  But, I was able to find the manual on this frigerator, which was key.  There was one phrase in the manual that gave me help - "when the glass shelf is pushed to the rear, it will align the rear latches.
Manual from whirlpool website: http://shared.whirlpoolcorp.com/assets/pdfs/literature/MSB2154ARA.pdf
So, the rear latches must be installed in such a way that the sliding glass shelf not only touches them, but pushes them into the correct position.
This fact helped me to try different positions, each time testing to see if the glass shelf would do anything.  Finally, I realized that there is a triangular shaped part of the rear latch.  The hypotenuse of the triangle is what comes into contact with the little nub on the underside of the glass shelf.  The nub on the glass shelf pushes the rear latch along the hypotenuse of the right triangle, and into the correct position.
Here is a picture of it installed in my frigerator,which I am sure will tell it better than any words:
Oct 08, 2007 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
85 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
