A dead General Electric Model 7-4612B clock radio
The clock is only wired for 120 V usage have been used with 220v and it no longer works.
there is no internal fuse ,the transformer indication are ~80v for theblue-white output and 1.07v for the red-black output. what parts otherthen the transformer could be damaged?
tanks in advance .
The solution is to buy a new radio. Clock radios cost as little as $12 on Amazon.
Posted on Aug 21, 2010
  • Wharic Oct 18, 2010
    I am 24 years old and this is the oldest item I still have. Got it when I was 5 or 6 for Christmas and would be upset if I ever encounter a problem with this tech mech late 80's alarm clock. I'm still wondering what year it actually is; I can't seem to find any information on that.
Is it possible to wire compressor motor from sears model 106 174541 to 220v and if so schematic if possible just for motor
If the electric motor says 120/240 then yes. It it only says 120 on the data plate then no. I have attached a good read for you. Should you change your motor from 120V to 240V
Jul 07, 2016 | Air Tools & Compressors
I have a frigidaire electric stove,model # 316433603 there is power to the stove the only working is the clock
General answer for all electric stoves: Electric stoves are usually 220V in the USA. The clock is 120V. My first "guess" is that you have 120v to your clock and maybe light if the stove has one. You should have a separate 220v power cable ( see photo attached) that will power the range itself. The cord may be missing ( simple to unbolt), the cord my be unplugged, or the 220 circuit may be turned off at the fuse box or circuit breaker.
Mar 02, 2015 | Stoves Ovens
Losses Time
what frequency does Jordon use on their power is it 50 hz are the clocks 60 Hz designed power usage.
may need a device to convert 50hz to 60hz
search google for
50 hz to 60hz frequency converter
Apr 15, 2014 | Sanyo R-6800 2-IN-1 ALARM CLOCK AND RADIO...
MILWAUKEE JOBSITE RADIO'S CLOCK DISPLAY WORKS BUT NO RADIO
if it work on battery and didnt work on 120 volt,the transformer is dead,i see a lot of radio with dead transformer.
if it dont work with battery and 120v,the control board have problem.
Oct 18, 2012 | Milwaukee Tool 49-24-0200 AM/FM Radio
My oven is dead - no display, no nothing. Circuit breakers are fine. Turned them off overnight, still nothing on oven this morning. This happened about a year ago but oven came on again ten minutes...
What you need to check is for power at the clock.TURN OFF BREAKER gain access to clock and use volt meter. One the clock will be wires maked L1 & N on those 2 wires when breaker is turned back on their should be 120 vac. IF 120 vac at those 2 wires,replace the clock, if not 120 vac into clock check for burnt/broken wires
Aug 20, 2011 | Jenn-Air Electric Single Oven
CAN WE USE GE THQB1120GF, 1 POLE, 20AMPS GFCI TO 220V AC SYSTEM?
Everything I read says this is a 120VAC Single pole breaker.
There is a 120/240 version THQB1120AF that is also a 20A
This link shows a picture of one but please NOTE the link is for a reconditioned CB
http://www.circuitbreakerservice.com/General-Electric-GE/THQB1120AF_product_info.html
Here is a link for a NEW breaker:
http://www.relectric.com/Store/Circuit-Breakers/THQB1120AF
^--Seems a bit pricey to me. I would shop around. I have seen these in the $80.00 range but never thought to look to see if they were new or re-conditioned until today.
There is no way I would use your THQB1120GF on a 220VAC circuit.
Thanks for choosing FixYa
Kelly
Retired Electrician
Sep 28, 2010 | General Electric GE Circuit Breaker...
RCA RP5430 clock radio transformer TIN HING U2812-093-045E specs
It is 9v and 4.25v, measured from a working transformer in the clock radio
Dec 17, 2009 | RCA RP5430 Clock Radio
Can you convert a 220 dryer element to a 120 ellement
no that machine is wired for a 220v. has 220v components in it. no way to change that sorry
Feb 23, 2009 | GE Spacemaker Washer and Dryer Electric...
Clock radio
Unless thate is an internal fuse it that blew, most likely it will be more expensive to repair than replace. The transformer primary winding is probably burned out. You have nothing to lose, take it apart and see if there is a fuse. If so, replace it with the EXACT same value as the original. If not, its not worth fixing.
You didn't say what the symptoms were, other than it didn't work anymore. I am assuming it is completely dead.
Please let me know if I can be of further assistance to you.
- Jim
Feb 13, 2008 | Audio Players & Recorders
366 people viewed this question
 Grubhead
Grubhead
