Question about Watches
How much dollar rolex 432117
1992 year
How much is wort
about 25 dollars its fake
Jul 19, 2014 | Rolex Watches
My wife's Rolex Oyster Perpetual watch is running very slow. It was cleaned approx 7 years ago and seemed to run properly. I phoned the NY service center which quoted a $600 basic cleaning fee which seems...
Hi , I am sorry to say that a rolex requires servicing on a regular basis . Every 3 - 5 years would be advised . If you consider that your watch is a delicate machine that may be working 24 hours a day for years then its not unreasonable that it needs servicing. Over time the fine oils dry and degrade , they need replacing , and parts can become damaged .
As to cost , this is a skilled job . To service a rolex in the correct way requires not only skill ,but the correct tooling and equipment . Also the materials used must be genuine rolex , this is costly . Your accredited service centre will then provide a 2 year guarantee .
All in all the price of $600.00 reflects the labour of a skilled man and his investment in gaining rolex status .
There will be cheaper alternatives but beware as they will probably not be rolex trained and wont be using original materials .
Aug 01, 2013 | Rolex Oyster Perpetual Day-Date Watch...
Price + rolex daytona
I give you The Cheap Price Rolex Watches Online store i home it helps you rolex daytona price here is 22 dollars & 90 dollars check this
Mar 06, 2013 | Rolex Daytona 116520 Wrist Watch
Cloudy face of my rolex oyster perpetual date, womens
Dont swim with it anymore - Its time for a service.
Take it to any Rolex re-seller that offers repair or to any good timepiece service center. If its a vintage piece i would recommend sending it to Rolex, paying the extra cost to receive the watch with full Rolex repair documents and service history. The Rolex web site has information on this. Also this company does a fine job on Rolex repair. https://www.bobswatches.com/rolex-repair-service
Jul 16, 2012 | Rolex Watches
Mens Rolex Explorer. The no. 11 digit fell off , 16 months after purchase, and is now resting at the base of the watch face rendering this expensive timepeace useless.This Mens Rolex Explorer bought from a...
Its not unheard of depending on the age of the watch (you say you purchased it 16 months ago but it could be a 15 year old watch.) If it was a new Rolex watch you have a 5 year warranty, so it should cost you nothing. If it was a pre-owned Rolex you should have received a warranty from your jeweler, most of those are 2 years. If this is a watch with value, and one you will either hand down or at some point resell then sending an older watch to Rolex is the proper direction - save all the repair documents, with the original receipt and the box. A Rolex Explorer II in good condition in US is about $5k, so $380 for a repair, though high, is worth it. I would recommend that if you do send it to Rolex for this repair and it is an older watch have it serviced too. The watch is returned to you in perfect condition with fill documentation.
Lastly, you need not to send it to Rolex at all. Any good watchmaker/repair jeweler can do this for less than $380US.
Aug 14, 2017 | Rolex Watches
Stopwatch second hand stops/jams at 57 seconds point, jamming the whole works. watch stops. keeps excellent time otherwise if stopwatch not used. 2003 SS model. bought new from rolex.
this watch will need a service from a rolex trained repairer wich wont be cheap 700 dollars min or 500uk pounds min..you could try tapping watch in palm of hand to see if a batton or luminous paint has come loose,then all it needs is movement taking out and blown clean inside case.any decent repairer can do this.sometimes the teeth on a wheel can wear in one place hence it always stops in same place.recomend service as best action,you never loose on a rolex...
Mar 26, 2010 | Rolex Daytona 116520 Wrist Watch
I had my Rolex watch serviced 2 years ago By Rolex and now
Either the stem or latch needs to be replaced. It's a common problem for ALL manual wind watches.
Dec 06, 2009 | Rolex Watches
Rolex
No, it is not. To build a Rolex you need to learn about 10 years of watchmaking.
Sep 30, 2009 | Rolex SS/18kt Daytona
Rolex submariner
Rolex's are wound by your movement. Try moving your arm back and forth and see if that helps. Also make sure that the crown is screwed in securely. If it's not a watch that you're not going to wear all of the time, you might want to buy a winder. I've bought several off of Ebay for around 30 dollars. They simply display and spin the watch off and on keeping it running. Good luck!!
Jun 06, 2008 | Rolex Daytona 116520 Wrist Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
