Question about Hilti Hammering
Type of lubrication for hilti te905 avr demolition hammer
Was striped down need to know what lubricant to use for assembly
4 Suggested Answers
jmgldsmth
  • 1889 Answers
SOURCE: Need manual for Hitachi Demolition Hammer
http://www.hitachipowertools.com/product/files/concrete_masonry/demolition_hammer/H65_OM.pdf
Posted on May 28, 2009
  • 142 Answers
SOURCE: Bosch demolition hammer oozing grease/oil.
Look around there for some O rings we have had this same problem with some of our Bosch hammer drills, and they usually replace a set of seals around the nose of the tool
Posted on Jul 06, 2009
rowdy45176
  • 2176 Answers
SOURCE: Looking for lubrication info on Bosch rotary and
try going to Boschtools.com and you will need your exact model number but they have parts explosions with the grease points listed on most of them Let me know if you need more assistance.
Posted on Mar 06, 2010
I need a control module for a hilti te.70.120v. If you have one or know someone who has l, please let me know.
No parts here and no connections other than a Google search which I assume you have already done.
Sep 28, 2016 | Hilti 120-Volt SDS Max Demolition Hammer...
Why did my hilti te 805 just stoped working when drilling can anyone help
A real Hilti brand means it has got the operating hours on it.
Only service a complete kit of components , this machines are have most liquid oil lubrication (most of the times a very expensive) Turmopol oil and special poor tolerance bearings HILTI and DUSS are high quality machines , Duss machines i prefer some higher then Hilti because of the long last service for more then 40 years old machines they have all te parts for them , but not cheap Unfortunately.
If a hammer stopped working like Dewalt all the parts are simple to get. most of the times a broken powercable or a brush that have become in protected state autostop , Dewalt hammer in the States is not the QS quality of Europe i know . but quality like the old ELU machines instead of black and Decker ,
Nice machines and are not fast leak , but it could also after a long period.
Jul 14, 2014 | Dewalt D25330K 2KG Sds Plus Demolition...
How to put oil in Hitachi H65
OIL ?? I think Hitachi has always a yellow grease lubrication
hitachi grease demolition hammer Google zoeken never seen heart of oil in Hitachi demolitions. but there could be models in your Country thats new for me .
Otherwise BOSCH HILTI and the one and only brand DUSS demolition hammers and also a few brands of Chinese hammers need oil lubrication . an expensive sinc-free hydraulic oil the same as used in some pressure washers life lasting oil but for HItachi look at the link for the grease 2 tubes a enough . good luck and dont forget the piston pin to replace with a new not only the gaskets and o-rings and also the oil and dirt seals on the front where the striking pin is that must be absolutely not air leaking because all your work burns in a few months again out . you can start all-over again.
May 15, 2014 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
I have a te 500 it not knocking at full strength
A Broken front ring which blocks the lock bolt ?
Is there enough lubrication flow if something is broken inside replace ALLWAYS a complete servicekit , because its , beware of the Turmopol oil is expensive. there are equivalent oils if you asked special for it also by Hilti to buy.
Hilti and Duss are not the 2 cheapest brands of powertools.
Special Tolerance-free bearings are used it is all super calculated on a number of operating hours and about if something is defective, a complete overhaul is necessary.
These hammers may leak no trace of oil in the front until 2006 HILTI has in my Country support , but after this date
exclusively support to the end-users and support closed for brokering.
Feb 15, 2014 | Hilti 120-Volt SDS Max Demolition Hammer...
Where do I ad oil to a makita hm1500 demolition hammer
Go to http://www.makitatools.com/en-us/Modules/Home/Default.aspx, put your model number in search box in the top right. Two models of the HM1500 will come up, select yours and open the owner's manual. Find the paragraph labeled 'Lubrication' and follow it precicely. Demo hammers are very picky about what type of grease they use and how much. Too thick and they won't work, too thin and they won't lubricate properly and the parts inside are very expensive to replace. Same applies to how much to use.
Jan 20, 2012 | Makita Hammering
Diagram of hilti te1000 avr
You'll have to call Hilti for that. They're very protective of their material. But I think they'll still fax you a schematic.
Nov 17, 2011 | Hilti TE 1000-AVR Demolition Hammer...
Hitli te 905 avr. light is on. any idea what it
If you have the old type TE905, which is the one with the square type handle at the back, the service light will come on for 2 reasons. Either there is a tight bearing which will increase the amount of current used to work the machine. Or more common the carbon brushes need replacing. To reset the light, simply cure the problem.
If you have the newer type TE905 with the large “D” Type handle at the back. It gets a bit more complicated. The service light will come on for the same reasons as mentioned above, but it will also come on after 200 hours of use. It will continue to work for another 50 hours with the light on, then it will shut down completely. This is to ensure that it gets regular service. Once serviced or repaired, it will require resetting. To do this you with need a Hilti optical interface, a PC, and Hilti ODA Software. This is not available to the general public. If your Hilti is less Than 2 years old, call Hilti. They will pick it up, repair it, and send it back to you in 3 working days FREE OF CHARGE. If it is older than 2 years there will be a charge for the repairs.
I hope this helped you. Please leave feedback
Jul 16, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
I have a Hilti TE 905 AVR the service light came on and it stopped working. Is there a troubleshooting guide to fix and reset this. Also, schematics can be found at:...
Jul 08, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Hammering Logo
271 people viewed this question
Top Hilti Hammering Experts
Todd Arndt
Todd Arndt
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hilti Hammering Expert? Answer questions, earn points and help others
