Question about Dell Inspiron Computers & Internet
How can i connect my vga dell laptop inspiron to a rca sanyo old model tv
  • Official Brand Answer
  • 560 Answers
Claytonward,
You need a converter to connect. At the links below are some resolutions that I found doing a google search.
http://www.newegg.com/Product/Product.as...
That would convert the VGA output to RCA input... then you just need a 3.5mm to RCA left/right audio cable...
http://www.amazon.com/Belkin-Audio-Cable...
Like that one... to connect the headphone jack to the audio inputs on your TV.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Posted on Jan 11, 2013
Nitrotrike
  • 589 Answers
SOURCE: how to connect laptop to tv
You should be ably to toggle the output between the LCD and the output jack by pressing the FN and F5 keys.
**note** check your F keys for a picture of a little monitor, as F5 may not be the correct one for your model.**
Posted on Jan 16, 2008
Fwayne
  • 97 Answers
SOURCE: Connecting Dell Inspiron 1501 to TV, Windows Vista
The PC card you have doesnt appear to work with that adaptor. Dell Has its own Svideo / Video output adaptors.
You need a converter not an adaptor. Try looking on Amazon for this: ITV-900 PC to TV Converter
Posted on Dec 23, 2008
jell587
  • 447 Answers
SOURCE: How can I connect my Toshiba Satellite A305-S6872
VGA to RCA adapter (ebay listings, none are mine), just add the audio cable out to the TV...
Posted on May 12, 2009
  • 3940 Answers
SOURCE: i formatted my dell inspiron b120 model laptop i need lan driver
Here is a link to the Network Driver:
http://dsn.us.dell.com/DSNCR/DSNGateway?target=GetDocument&objectID=0E2392E739334481872AE06262A4FC10&languageCode=EN&regionGuid=DD4C7CB26E136815E030A68F27285B52&open=1
Posted on Jun 06, 2009
  • 181 Answers
SOURCE: how to hook up dell inspiron 1501 laptop to tv
Do the following:
1. Get a VGA cable (male-male) and connect to your TV and your laptop
2. Select your TV's source as PC (check ur TV manual)
3. From your laptop, select video output to external monitor by clicking on the Fn key and the F8 key at the same time
NOTE: Please rate our help to keep this free service online
Posted on Jan 12, 2010
How can i connect my dell inspiron 1721 to my tv samsung led
If your Samsung TV has a VGA input then connect a VGA cable to the TV and the other end of this cable to the video port on your Dell laptop. Turn on your TV and select the VGA (computer) input then boot up your Dell laptop.and then the video data from the laptop will automatically divert to the TV.
You can toggle between the TV and laptop LCD screen by holding down on the Fn key and press the F8 key.
Jan 26, 2013 | Dell Inspiron Computers & Internet
How to connect my dell inspiron 1501 laptop to my hdtv. am using a vga cable with rca out, to connect to the tv. i have tried everything but none works. if this can work please sent me step by step...
1 - the cable you are trying to use will not work - the RCA inputs in your tv can't accept the signal coming from the VGA. To connect the laptop to a tv the tv must have an VGA input, nothing else will work.
2 - When you start the laptop with an external device (such as an external monitor or tv) attached and turned on, the image may appear on either the laptop's display or the external device.
Press to switch the video image between the display only, the external device only, or the display and the external device simultaneously.
Apr 27, 2011 | Dell Inspiron 1501 Notebook
No audio output to tv on my dell 1545
That, & most, earphone sockets, simply doesn't have enough "Current" or signal voltage to drive your TV set's audio in Amplifier. You need to get a Pre-Amp, to amplify the signal, up to a level that can be used by the TV. So you need to purchase, or build from a kit, a small stereo pre-amp and insert it between your laptop & TV audio In.
Feb 04, 2010 | Dell Inspiron 1545 Notebook
Vga to tv
The answer to your question is Yes. You can use a VGA to RCA converter and view the output on your TV. I am assuming that you are using a Inspiron 1200 laptop. Couple of things you may need to check.
1. Toggle display using Fn + F2 (Hold down the Fn key and press the F2 function key), this will toggle the display between Laptop, TV, & Laptop + TV .
2. Right-click on desktop, goto display properties, make sure the second display is set to 800x600 or 1024x768, these are the only display resolution supported by analog TV’s
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 23, 2009 | Dell Inspiron 1200 Notebook
Dell Inspiron 2200 to Phillips 47 " TV
check this out http://answers.google.com/answers/threadview/id/762913.html *A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable. you will need a seperate audio cable unless you are going to use your laptop's speakers
Feb 04, 2009 | Toshiba Tecra M1 Notebook
Dec 23, 2008 | Dell Inspiron 1501 Notebook
Getting vga pic
ck for correct input. composite video on tv.
Aug 03, 2008 | RCA F26317 TV
Computers & Internet Logo
76 people viewed this question
Alun Cox
