Question about Philips SA5145 MP3 Player
I have a philips gogear MP4 player and the files have corrupted so I reset and deleted them all...apparently. But on my computer it isn't seeing any of the files on there but it still says that it is full. I can't seem to delete any of the files and get it working again. cheers Siobhan
  • siobhan_moro Jan 22, 2009
    Thanks heaps.
    It needed to reinstall some software but had very simple to follow instructions and everything worked perfectly. I have my player back!
  • 8,596 Answers
Run a Repair in the Philips Device Manager. If you have lost your CD, you can get the software from Philips website.
-Tha Mp3 Doctor
Posted on Jan 22, 2009
My M3 player just froze up and I can't evn turm it off, Help?
There is a small reset micro switch on the ipod and using an office pin you can press and hold the switch so that the player will reset.
This must bring back the player from the HUNG state. Also connect the player and scan the files, if there is detection of corrupt files then the folders must be removed and copied with safe files after using the media convertor of the GOGEAR.
Please download from this link;
http://www.userdrivers.com/MP3-Player/Philips-GoGear-SA3104-SA3105-SA3114-SA3115-SA3124-SA3125-MP4-Player-Media-Converter-Software-1-0/
Oct 12, 2011 | Philips GoGear ViBE Digital Media Player
I ran the battery on my MP3 player completely down and it shut off. I charged it and now all the songs are gone... is there a way to recover the lost songs?
Try this:
1)Perform a system reset, which won't erase your files, to attempt to correct playback. Locate a thin object, such as pen tip or unfolded paper clip and insert it into the small reset hole on the bottom of your GoGear. Hold the thin object in place until you see the unit shut down completely. Your system has been reset. Power the device back on to see if the corrupted files have been corrected. If the reset failed to correct the issue, perform a file recovery on your GoGear.
2)Initiate a file recovery by first connecting your GoGear to your computer. From your computer's "Start" menu, choose "Programs," "Philips Digital Audio Player," "Area Device Manager" and "Philips Device Manager." The Philips Device Manager software will be activated. Inspect your GoGear to confirm that it is turned off. Plug the small end of the supplied USB cord into the bottom of your GoGear while holding down the "Volume Up." Insert the larger end into a free USB port on your computer. Hold the key as the "Philips Device Manager" reads your GoGear and activates recovery mode. Click "Repair" and follow the onscreen prompts as given by the "Philips Device Manager" to complete the process of memory recovery. Disconnect your GoGear from your computer properly after the process is complete and restart your MP3 player.
3)Reload and replace the files onto your GoGear by first connecting your GoGear to your computer. Plug the supplied USB cord's small end into the bottom of your GoGear and the large end into your comptuer's USB port. Initiate Windows Media Player by clicking on its icon if it doesn't start upon connection with your GoGear. In the left pane of the WMP, click "Philips GoGear Aria." Click the arrow on the top left edge of the WMP window, followed by "Music." Highlight all files, and click "Delete." Click the "Sync" tab on WMP, and drag and drop the music files you would like to replace and reload into the "Sync List" panel. Click "Start Sync." The files will be freshly loaded onto your GoGear.
4)Properly disconnect your GoGear from your computer to avoid memory corruption by first closing all applications in use by the GoGear (WMP). Click the USB device icon in your system's tray (located on the bottom right corner of your screen). Follow the prompts in order to safely remove your GoGear from your computer. When your computer tells you it's safe to remove your GoGear, unplug the USB cord from your GoGear.
Hope this helps!
Apr 08, 2011 | Philips GoGear ViBE Digital Media Player
I have a phillips go gear MP3 player and when i turn it on it freezes only the words www.phillips/welcome.com screens shows. how to i fix this?
Hello
Your GoGear is freezing because there is an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
Sep 02, 2010 | Philips SA3025/37 Flash MP3 Player
My gogear if frozen. Will not power off.
Hello :
Your GoGear may not respond to button presses from time to time. This is often caused by an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
PLEASE DON'T FORGET TO RATE !
Apr 18, 2010 | Philips GoGear Flash MP3 Player
Need help with mp4
just delete the files and put them again .
good luck
Jan 27, 2010 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear SA52XXBT mp3 player keeps on freezing
Support for GoGear SA52xxBT on this site (select your model from the list):
http://www.p4c.philips.com/cgi-bin/dcbint/cpproduct_selector.pl?slg=ENG&searchtxt=SA52
How to format the player is explained under "Latest additions" when you scroll down: select the Frequently Asked Question containing the
phrase "FILE SYSTEM ERROR".
When still having problems, just post a comment when more help is needed.
Sep 19, 2009 | Philips GOGEAR SA6045 MP3 Player
My Philips SA52xx GoGear MP4 Player won't start up. It just starts starting up and freezes on GoGear, it also makes wierd crackling sounds when playing music... My Philips GoGear used to start up within 10...
if it has too many songs on it try deleting some of the songs off the player, and if thats not the case, stop using it for a few days then try to turn it on again
May 31, 2009 | Philips SA3125\02 MP3 Player
Sa3345/85
Try pushing the reset button on the bottom, next to the USB socket, then try switching on again.
If this doesn't work, then you may have corrupt firmware. Try a factory restore, as follows:
Open Philips Device Manager.
Whilst pressing and holding the [VOL+] button on the player, connect to the PC.
Continue to hold [VOL+] until told to release, then follow the on-screen prompts.
This will format the player and re-load the firmware.
NOTE: ALL FILES WILL BE DELETED FROM THE PLAYER.
May 12, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips SA6045 Mp4 player- virus?
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Mar 15, 2008 | Philips SA3125\02 MP3 Player
Philips SA5145 MP3 Player Logo
123 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
