Keyboard on toshiba satellite not working
Keyboard completely not work where is the problem?
  • 7,627 Answers
Has the laptop been damaged? Maybe a loose connection? Take a look at this video: http://www.youtube.com/watch?v=W6Ccq5PN1Z8
Posted on Jan 11, 2013
sriramoju
  • 171 Answers
SOURCE: keyboard not working
first check with another external keyboard if it works ok, otherwise remove the keyboard drivers from device manager and then the restart the system
Posted on Mar 16, 2008
joecoolvette
  • 5660 Answers
SOURCE: Replace keyboard on Toshiba Satellite 1410-s173
First remove the AC adapter (Charger) if plugged in. Then remove the battery.
Next step is removing the Keypad Securing Strip. This is a plastic cover right Above the keypad, and below the LCD screen. Looking at it, you'll notice on the Left and Right sides of it, that it has a U-shape.
This U-shape covers the LCD screen hinges.
Take a small flat tip jewelers screwdriver, and come from the right side of this plastic strip. You will see a thin parting line, where this plastic strip meets the laptop body. Your flat tip goes in this parting line. You have to use finesse. It's doubtful you'll break the plastic strip, as it's REAL tough! But if you slip, you could scratch the plastic. (Actually, it's pretty hard to scratch that plastic! Just thought I would caution you. The plastic strip is made of a spaceage plastic. Pretty tough stuff!)
The plastic strip has tabs around the edges, every so often. These
plastic tabs snap into place, and hold the Keypad Securing Strip on. When you begin, it's a little tough to get that flat tip down in there. (Remember ->Jewelers screwdriver!)
Plus, you may be at one of the points that there is a tab. Usually there is a 'dimpled' flat place, that looks like a flat tip should go there.
With the flat tip jewelers screwdriver inserted a little, ease back on the screwdriver, and lift the plastic strip up.
It will look like it's bending. If you have another flat tip Jewelers screwdriver, or a small butterknife, you can insert it, and hold this part up. Then take the other flat tip, move over a little, and start lifting up.
Once this Keypad Securing Strip starts coming up, it will come to one of those tabs, and the tab will come up and out. You'll hear a POP, and think you broke it! You didn't.
Go along the edge, and keep popping this strip up. Use caution, as to how far you insert that flat tip screwdriver!
There are tiny little wires under there, and you don't want to pinch one, or tear it loose. Keep the flat tip, about a half a fingernail length in, and you won't.
Once you get towards the other side enough, the strip will let loose, and come up.
Without disconnecting the wires, see if you can lay the strip towards the back, and lay it out of the way. Towards the LCD screen. You are trying to get to the screws, that secure the keypad. They will be in a metal strip for the keypad, and towards the LCD screen.
I can't remember at this point if there are two, three, or four screws. You'll be able to see, and you'll know.
(Use Caution! You can easily drop these screws! They might go right into the body of the laptop. You MAY be lucky enough, to pick the laptop up, turn it over, and gently shake the laptop, to have them fall on the table. You MAY not be so lucky, and have to disassemble the entire laptop, to get to them!)
IF, the Keypad Securing Strip will not lay out of the way, so that you can get to the keypad screws, you'll have to remove it.
It isn't tough, but it looks daunting the first time.
You will see small White connectors in the middle of the cables.
Two wire cables, if memory serves. These connectors are small White rectangular blocks. There is a Female and a Male. You just take your fingernails, and ease the connectors apart.
Don't worry about how they go back together. They are different sizes. You just match up the size.
Now with the keypad securing screws removed, ease the keypad forward a little, and bring the front of it up to a tilted position. (Towards the LCD screen is the front of the keypad) You don't want to bring it straight up, as there is a flat ribbon cable you need to disconnect. The flat ribbon cable attaches at the back of the keypad. (Towards you) It has a White connector.
This connector is different, from the ones you have disconnected already. The connector itself has a locking 'bar'.
This thin rectangular piece of plastic, goes across the length of the connector.
It is positioned at the front of the connector. It comes forward, towards the flat ribbon cable end, that is connected to the keypad.
It slides. It only slides so far, then stops. It is at this point, that you remove the flat ribbon cable itself. The one towards the keypad. There will be No connector on that flat ribbon cable. It will be just the ribbon cable itself.
When you reattach it, you just slide the flat ribbon cable back into the White connector. Then you ease that locking bar back into position. The position that it started from.
Now reverse your steps.
Posted on Apr 18, 2009
  • 23 Answers
SOURCE: keyboard illumination
ok marty assuming that u r using vista and that this illumination has a support software try this go to the start menu and at the search area located at the bottom of the menu type keyboard illumination or something similar i am sure that this thing is software supported and some support software name will pop up from where u can get it working try it best of luck
Posted on Sep 13, 2009
SOURCE: toshiba satellite a215-s5837 keyboard does not work
Yes, replace entire thing. It's really a membrane key anyway. NO contact to clean..
Posted on Feb 10, 2010
  • 10406 Answers
SOURCE: 1qaz keys on my toshiba satellite a100 laptop are
A keyboard sends "scan-codes" to the computer,
e.g., "user pressed ALT and has not yet released it,
user now pressed CTRL and has not yet release it,
user now pressed DEL and released it".
So, if you've changed keyboards, then the new keyboard _should_ be sending the correct scan-codes; it must be your computer's motherboard that is not properly interpreting the scan-codes. Ouch!
Replacing the motherboard is _not_ cheap.
Posted on Apr 10, 2010
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
How to fix key on Toshiba Satellite L655-S5061 Laptop Keyboard
The keyboard is made that limited to no service can be done, replacement of the entire keyboard is required. Short term solution is use external keyboard if available.
Apr 15, 2012 | Toshiba Satellite L655-S5160 Laptop PC...
Toshiba Satellite.C655.enable.space.bar
Hook a external keyboard, if okay! problem with the laptop keyboard. Try a system restore and bring the computer back to a earlier time before this happened, just might work. The keyboard can be disabled from the bios setting I don't see how it can be done any other way.
Mar 17, 2012 | Toshiba Satellite C655-S5140 Notebook
I wife spilled champagne on my Toshiba Satellite and the keyboard stopped working. Computer still works so I dont see damage to mother board but is there a easy fix or should I just buy replacement...
You can plug in an external keyboard to a usb port and it will work. You can also buy a replacement. Usually they are fairly cheap and easy to swap out. Usually three or four screws from the bottom and a time ribbon underneath the keyboard.
Mar 01, 2011 | Toshiba Satellite M100 Notebook
Not all the keys are working on the keyboard of my TE21oo Toshiba Satellite yet an external keyboard works fine. Any suggestions?
Yes, replace the keyboard, On most machines not too bad of a job, and the board on normal machines is like 60 to 80 bucks. Not sure with Toshiba, some of their stuff is too pricey.
Sep 27, 2010 | Toshiba Satellite M70 Keyboard
Toshiba satellite a215-s5837 keyboard does not work
Feb 10, 2010 | Toshiba Satellite A215-S5837 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Keyboard just quit working
Its most likely just a bad keyboard unless something got spilled on the laptop. I would call Toshiba customer support and have a toshiba repair shop look at it. 1-800-457-7777
Feb 07, 2009 | Toshiba Satellite M35X-S349 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
