Were are the hdmi ports on my toshiba c660d153
Can i run toshibs c660d153 to my digital tv
    Problem Solver:
  • 6 Answers
Your laptop does not have HDMI port only VGA, you have two choices check if your TV has a VGA port and if it does you can connect the laptop to the tv (you will need a vga cable.) if tv doesnt have VGA connector then you could try finding a USB to HDMI adaptor for example:
http://www.cooldrives.com/index.php/usb-hdmi-adapter-dvi.html
Posted on Jan 11, 2013
4 Suggested Answers
MalKontent68
  • 748 Answers
SOURCE: i TRIED TO CONNECT MY LAPTOP TO AN HD TV VIA THE HDMI PORT
Most probably it will be enough to press Fn + F5 to change the display output. Pressing this combination sequentially toggles between 3 settings usually:
Internal LCD
External output
LCD and external simultaneously.
The external-only option is the best, as it will give you an option to set a screen resolution suitable/optimum for your TV, as oposed to the resolution of your internal LCD display, which is optimum for your display, but doesn't use the full capabilities of your TV.
Good luck, and please come back with a testimonial/rating if helped.
Posted on Jul 23, 2010
Geekman
  • 32281 Answers
SOURCE: i do not see HDMI port in my toshiba m300 notebook
According to these specs, it does not have a HDMI port.
http://www.notebookreview.com/default.asp?newsID=2320
Posted on Dec 25, 2012
Geekman
  • 32281 Answers
SOURCE: my toshiba notebook m300 does not have HDMI port
It does not have a HDMI port
Toshiba c55t outputs video via hdmi, but no audio
Check your sound manager on the toshiba. It will normally default to the analog plugs (green mini phone plug) on the rear. You may have to select the digital audio option to get the sound thru the HDMI port.
Mar 06, 2015 | Toshiba Computers & Internet
How can you connect a Toshiba L300 laptop to a Panasonic TH-L32X20Z TV
Your laptop should have a AVG port , run a cable from this to the HDMI port on the TV ,showing AVG port
Feb 25, 2015 | Toshiba Satellite Pro L300 Notebook
Why won't my Toshiba Satellite L655 laptop connect trough HDMI anymore?
Try pressing the appropriate function button to change the screen from internal to external. Possibly F4?
May 15, 2014 | Toshiba Satellite L655-S5101 Laptop
Were are the hdmi ports on my toshiba c660d153 laptop
That specific model does not have an HDMI port.
You could buy a VGA to HDMI converter though. They are relatively cheap (under $10) and one would allow you to output the display to another screen.
Jan 11, 2013 | Computers & Internet
HDMI Ports on Toshiba Flat Screen TV stopped working
That's highly unlikely!!! More likely is that the cable is having problems or that someone mistakenly changed the picture i the TV from HDMI to regular reception. If the HDMI ports are changed to regular TV reception they don't see the HDMI ports only the regular video ports!
Jan 01, 2013 | Televison & Video
How to connect sony ps3 to toshiba 32av500a
Use any HDMI cable to to this.
Connect cable to the "HDMI" port on the back of the PS3. Connect the other side of the HDMI cable to the "HDMI" port on the Toshiba TV. If the Toshiba TV has multiple HDMI ports, make note of which port you plugged the HDMI cable into.
Change the Toshiba TV to its "HDMI" video display mode. Press the "Power" button on the PS3 to turn the console on. The PS3 will automatically detect the HDMI cable. Select "Yes" to use the audio and video from the HDMI cable. Select "Yes" to have the PS3 automatically use the optimal settings for the Toshiba TV. Select "Yes" to accept the recommended resolution. Press the "X" button to save the settings
Dec 22, 2012 | Toshiba Televison & Video
Is my regza tv model 32rv635d hd ready or full hd.
Hello The Toshiba Regza 32RV635D is a Fully HD TV. with four HDMI connections.
Connections
The location of the connection ports is in keeping with today's standards. They are easily accessible and well constructed.
Port Listing: 4 HDMI, 2 SCARTs, Headphone Jack (with Independent Volume Control), S-Video, Composite Video, Common Interface, Component Video, Digital Audio Out (Optical/Toslink), RF In and D-Sub.
You can read the reviews here:-
http://reviews.cnet.co.uk/tvs/toshiba-regza-32rv635db-review-49302355/
and
http://www.techradar.com/reviews/audio-visual/televisions/plasma-and-lcd-tvs/toshiba-regza-32rv635db-679432/review
Hope this helps, if so do rate the solution.
Jan 03, 2011 | Toshiba REGZA 47HL167 TV
I just got the Toshib 46rv530u and can't figure out how to get it to change video to 1080p
hi,
1080p full hd video can obtain only through hdmi. for that u need a full hd blue ray player or full hd sat receiver . the tv automatically changed to full hd according to the input connecting to it .go to hdmi setting and check whether hdmi connectivity is ON. also check the hdmi setup of ur input device.
ok
Dec 16, 2010 | Toshiba REGZA 46RV530U LCD TV
Can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Dec 01, 2008 | Toshiba Satellite A205-S4617 Notebook
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
