Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
My camera is on auto but isnt taking pictures,
The lens is on auto and so is the body but there is no noise of the camera focasing (which it usually does).
PLEASE HELP ME, i have a concert to photograph in a week and need it fixedd
  • Anonymous Jan 25, 2009
    my camera is on all the same settings but makes a funny noise and does'nt take the ppicture
  • 95 Answers
Be sure that nothing is blocking the contact point between the lens and camera. remove the brownish color or sand it toretain the conductivity between the two.
Posted on Jan 22, 2009
I own a Nikon D5000 and am experiencing issues with the 55x200 lens. When trying to take a picture (on auto mode) of an item that is too close, I am hearing a squeaky noise (like the noise made my a VCR...
The 55-200mm lens does not focus closer than 1.1 meters (3.6 feet). If the subject is too close, then the autofocus tries and fails to focus or keeps trying (and squeaking). Either way, you won't be able to take a picture. In manual focus, you can take a picture but it will be out of focus and blurry.
Every lens has a minimum focus distance, closer than which it will not focus. Some lenses focus closer than others. It's a matter of design; making lenses focus closer makes them larger, heavier, and more expensive.
If you want to take close-ups, you have several options. You can buy close-up adapters that fit onto the front of a lens. You can buy a special close-up lens ("macro" or "micro" lens). You can buy extension tubes to fit between the camera and a lens.
Jul 18, 2011 | Cameras
When i look through the viewfinder its darker than usual, my lens wont seem to come off its stuck even while holding down the release button and trying to rotate it by force. When taking pictures on auto...
Hi tin_080 , the aperture actuating lever was bent or loose and is ahead of the control mechanism of the diaphragm opening in the camera body.
Check this: point the lens towards you notice that the diaphragm is closed.
To avoid more costly damage you take it to a workshop for servicing.
Best regards
Mar 26, 2011 | Nikon D90 Digital Camera with 18-105mm...
I use thais lense on a cannon rebel xti and it takes black pic
Error 99 is one irritant in many Canon SLRs. In general, it means there is some problem with the contacts. So try cleaning the electrical contacts of the body and lens with a pencil eraser.Please take care to hold the camera upside down while doing this so that the residue does not fall inside. Also take out the battery and clean the contacts. Now re-attach everything and try taking the image. Also check if your lens has an aperture ring and aperture lock. If so, lock the aperture ring at the minimum aperture. If these do not solve the problem, try updating the firmware to the latest one.
Dec 12, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Camera won't take a picture when autofocus is on
It sounds like you have a problem with the auto focus on the lens. The 18-135 has a focusing motor inside the lens itself. If this motor is not working, then it won't focus. It could also be the contacts (small and silver on the lens look like ball bearings buried halfway into the top part of the lens where it connects inside the camera body) or the contacts inside the camera body. These can be CAREFULLY cleaned with alcohol and a QTip or a clean pencil eraser. Just make sure you don't get anything into the lens or camera.
If the camera is over a year old, it may just be time to take it to the camera shop for a cleaning.
Aug 26, 2009 | Nikon D80 Digital Camera with 18-135mm...
The Autofocus does not work on my Nikon D40
1 Possiable dirty lens contact terminals
2 Auto focus motor in lens is jamed/malfuntion
3 Auto focus engagement pin on camera body is not engaging the lens
4 Correct lens,old nikon lens and some 3rd party lens wont work on the D40
Jul 18, 2009 | Cameras
Screen vibrates intermittantly. Also buzzing noise.
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
May 14, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Canon EOS 40D not working when turned on
I'm sorry to tell you this but you do NOT have anything set wrong. To test my theory turn your camera to full auto. Next make sure your switch on the lens is set to auto. Then just try taking some shots of some objects across the room. If that doesn't allow you to take pictures do the exact same test with a different lens. That way you've taken the lens out of the equation. Sorry I couldn't give you a better answer but I'm pretty sure you'll need to return the camera to cannon.
Dec 28, 2008 | Canon EOS 40D Digital Camera
Picture won't take on auto
snoopytwo, jmv23 & guests,
Sounds like you have been taking photos in both auto & manual modes, make sure your f-stop is set at the range it needs to be to allow enough light for the camera to take the photo. Since the lens and the camera communicate, if the lens is closed down & not allowing enough light the camera will not take the photo - does that make sense - Look at the metering in auto mode and see what the camera says the conditions are for a specific lighting condition check to see if the lens has a aperture position for Auto, usually a dot on the lens ring to align with a setting in red or green (likely a F-22) depending on the make of lens, that has been moved to some place in the middle and not returned while trying other manual settings so the shutter won't release because the camera is told by the lens there is not enough light or slow enough shutter to take this picture.
randy320sgi
May 21, 2008 | Nikon N65 35mm SLR Camera
Camera won't talk to lens
Is the lens switch in manual or auto mode?
Feb 25, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Prime lens
make sure the aperture ring on the lens is set to the minimum aperture number, (usually a orange colored number), i.e. f22,f32
Jan 23, 2008 | Nikon D200 Body Only Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
55 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
