Question about GE 24 in. GLD5860LSS Stainless Still Built-in Dishwasher
Not cleaning properly. Not Draining properly?
My unit recently had a problem. It would not drain at all. I worked my to bottom of the unit and cleaned out the trap - sort of. It is under the bottom arm which I could not detach so i sort of unclogged it to the best of my ability. I found some labels from an apple and some assorted garbage. The unit was able to drain. But know it seems this created my new problem. When I run a cycle my dishes(glasses are a nightmare) seem to get encrusted with debris. The heat cycle bakes it on. I ran the dishwasher with Vinegar, sort of helped a bit but still get debris - old food - on my "clean dishes" What to do?
  • 1 more comment
  • Anonymous Feb 07, 2008
    UNIT WILL NOT DRAIN
  • valcarlin Jul 01, 2008
    diswaher is not draining
  • Anonymous Jul 13, 2008
    No Drainy! :(
    Problem Solver:
  • 8 Answers
Don't Buy GE :)
pump may me clogged does it drain, can you hear water spray. is water filling into unit on start up? I had to take pump of bottom of mine had piece of tooth pick jammed in impeller + GE just stinks anyway. I will never buy again
Posted on May 01, 2009
SOURCE:
The door on my dishwasher everytime you open it is making a loud creaking sound and there is water at the bottom of the dishwasher always. what to do?
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 03, 2010 | KitchenAid Dishwashers
I have water standing in the bottom of dishwasher after it has cycled a load
Hi
Thanks
Rylee
Dec 10, 2009 | Frigidaire Dishwashers
The dishwasher doesn't seem to be draining. there is a pile of water on the bottom
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 21, 2009 | Asko D1776 Built-in Dishwasher
Water left in bottom of ge evolution dishwasher.
Hi
Thanks
Rylee
Nov 08, 2009 | GE Dishwashers
Dishwasher is not draining
Hi
Thanks
Rylee
Nov 04, 2009 | Maytag 24 in. MDBH955AW Built-in...
Hi
Thanks
Rylee
Nov 03, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Water is sitting in bottom of dishwasher after cycle is completed - fair amount of it
Hi
Thanks
Rylee
Oct 22, 2009 | GE Profile PDW8000G Built-in Dishwasher
THE WATER WILL NOT DRAIN OUT OF THE BOTTOM
Hi
Thanks
Rylee
Oct 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Water not draining from dishwasher
1.attache the drain hose to the bottom of contertop.
2. drain back valve is not work properly.
Dec 20, 2008 | Whirlpool Dishwashers
Washer won't spin properly
It may not be draining properly, open the bottom front access panel ,3 screws on bottom front , remove the large filter access and watch for water spill.
clean of any debris. while down there check pump impellers for freedom of movement.
reassemble , then check under the rubber skirt and be certain no objects got under the tub.
Feb 27, 2008 | Danby DWM5500W Front Load Washer
GE 24 in. GLD5860LSS Stainless Still Built-in Dishwasher Logo
212 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Vitally Alcher
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
