Washing machine failour
My washing machine can't wash,the washing indicator shows that the washing process is taking place but it doesn't in real sense.
  • Ahmed Jan 12, 2013
    Jesus, cant you spell failure? this country is broken
  • Washing Mach... Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Jan 11, 2013
Is there a filter in the machine that \i should be cleaning as i keep getting black bits on the clothes?
The black bits are scum flaking off from between the inner & outer bowls, usually more common with cold water wash. Place old towel in washer, fill washer to high level with hot water, add washing soda & or vinegar, let washer run to end of wash cycle, turn off & let it soak for around an hour, turn back on & let it go through cycle. Commercial washing machine cleaning products should also be availably in your supermarket / hardware stores. You may need to repeat process until no more gunk comes out.
Dec 21, 2013 | Fisher and Paykel Aquasmart wl80t65c
Computer shows ddo &won't finish the wash
Hello noella_30 - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a professional needs to check reed switch.
Dec 02, 2012 | Frigidaire GLTF2940ES Front Load Washer
Whcandy washing machine grand go f 662 stops mid cycle and the cold wash light flashes and the softener isnt usedat's your problem?
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your self offer can fix it; here's how.
TOOLS NEEDED TO SOLVE PROBLEM ARE BELOW.
Bucket and rags,Screwdriver,
New drive belt (if necessary),
New drive motor (if necessary).
1 Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Thanks.
Nov 08, 2011 | Washing Machines
Candy washing machine grand go f 662 stops mid cycle and the cold wash light flashes and the softener isnt used
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your selfer can fix it; here's how.
TOOLS NEEDE TO SOLVE PROBLEM ARE BELOW.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reset the agitator.
Thanks.
Bottom rotor is not working
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-yourselfer can fix it; here's how.
Bucket and rags,Screwdriver,New drive belt (if necessary),New drive motor (if necessary)
Thanks.
Drain line clogged on Whirlpool model ET1CHMXKB09. How do I access the drain line?
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with most old washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your self offer can fix it; here's how.
Thanks.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
One rusty piece of metal dropped from the middle of plastic cover. Now, the washing machine lost its sensor, it keep showing dE and peep all the time. Unable to process washing. What can I do now, please...
'dE' stands for 'door Error' indicating that there is a problem either with the lid/door lock or the lid/door locked sensor requiring a service call, sorry.That piece of metal was probably part of the door lock ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 04, 2011 | Washing Machines
Washer won't spin, what do I do
Check the lid or door switch this is the usuall issue with a washer that won't spin. The other is a blocked pump or clogged pump filter.
Apr 30, 2011 | Maytag Washing Machines
Dear Mr/Ms, I think my ecosave washing machine has some mis-functions. Whenver what process has been done, symptoms are the same. The symptoms are the followings . . . . - blinking error LED light:...
The error came from an electronic control, the damage usually occurs in the data memory. under normal circumstances should have after finishing washing or spin process, washing machine will turn off automatically, indicated by the beep sound and flashing lights first. if you quite understand you just need to fix the electronic control block only, reset IC memory or the easiest way is to unplug all cables (socket) connected to electronic control, turn on the washing machine and then power off and reattach all the cables socket into place. particularly note the socket cable of  water level sensors and unbalance switches. electronic control block is usually coated with rubber glue. but I often fix it without having to replace the whole (one block / set electronic controls). good luck
Aug 07, 2010 | Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
