Question about Balance CM2019 19" LCD Monitor
Power Button locked - Can't Unlock
I've locked the Power Button, and now I can't get it to unlock. It's not in the menu like lock option was. Any suggestions?
  • Anonymous Apr 13, 2009
    I have Zenith 19" TFT monitor. I am unable to unlock the power button in my monitor. Please help me.
Why do the headlights. Come on when any door is opened on my 2008 trailblazer
The Headlamps On at Exit and Perimeter Lighting modes can be adjusted using the steering wheel controls to select the wanted function as displayed in the driver information center. The Headlamps On at Exit selection will allow the driver to customize the period of time that the headlamps remain illuminated upon exiting the vehicle. This period can be adjusted from 0 seconds to 180 seconds. The Perimeter Lighting feature allows the driver to select if they want the headlamps and backup lamps to illuminate when the door UNLOCK button on the key fob is activated. This feature can be turned ON or OFF by using the driver information center steering wheel control buttons.
programming Features with the Driver Information Center (DIC)
To enter programming with the driver information center (DIC), perform the following actions:
Turn the ignition to RUN.
Place the vehicle in PARK.
Press the Personalization button on the steering wheel to enter personalization programming.
Automatic Door Locks
Continue with the following steps in order to personalize the automatic door locks:
Press the Select button in order to enter the menu. The first choice seen is the current setting.
Press the Select button in order to scroll through the following options:
• LOCK DOORS: IN GEAR
• LOCK DOORS: WITH SPEED
Press the Personalization button in order to advance to the next option.
• UNLOCK DRIVER: IN PARK
• UNLOCK DOORS: IN PARK
• UNLOCK DOORS: AT KEY OUT
• UNLOCK DOORS: MANUALLY
Remote Activation Verification
Continue with the following steps in order to personalize the remote activation verification feature:
• LOCK FEEDBACK: BOTH
• LOCK FEEDBACK: OFF
• LOCK FEEDBACK: HORN
• LOCK FEEDBACK: LAMPS
• UNLOCK FEEDBACK: BOTH
• UNLOCK FEEDBACK: OFF
• UNLOCK FEEDBACK: HORN
• UNLOCK FEEDBACK: LAMPS
Delayed Lighting
Continue with the following steps in order to personalize the delayed lighting feature:
• HEADLAMP DELAY: 10 SEC
• HEADLAMP DELAY: 20 SEC
• HEADLAMP DELAY: 40 SEC
• HEADLAMP DELAY: 1 MIN
• HEADLAMP DELAY: 2 MIN
• HEADLAMP DELAY: 3 MIN
• HEADLAMP DELAY: OFF
Perimeter Lighting
Continue with the following steps in order to personalize the perimeter lighting:
• PERIMETER LIGHTS: OFF
• PERIMETER LIGHTS: ON
Mar 13, 2017 | 2008 Chevrolet Trailblazer
My menu control is locked and i want to know how to unlock this dell P2210t
pressing the Menu button takes you directly to the OSD settings menu. You should then select the Unlock option to unlock and allow user access to all applicable settings
Aug 27, 2014 | Dell P2210 Monitor
Samsung young locked?
Hi ,
If u dont want the data and if its okay if the phone is formatted then try this code it will surely work----switch off the phone first and press and hold volume down+menu button+power on/off button, u will get the option to full erase or format, select that option with the volume up/down keys and select by pressing menu or the power on/off button.
Jun 19, 2014 | Cell Phones
How to work my touch screen on my jelly bean 4.1 10in
Android 4.1 (Jelly Bean) your device now has several different lock options available.
To access your lock options, touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> > > Security & Screen Lock.
Screen Lock Options
  • Slide - provides no protection, but lets you get to the Home screen quickly, or open Camera and start taking pictures immediately.
  • Face Unlock - lets you unlock your phone by looking at it. This is the least secure lock option.
  • Pattern - lets you draw a simple pattern with your finger to unlock the phone. This is slightly more secure than Face Unlock.
  • PIN - requires four or more numbers. Longer PINs tend to be more secure.
  • Password - requires four or more letters or numbers. This is the most secure option, as long as you create a strong password.
The Lock Screen on Android 4.1 (Jelly Bean) uses two timers. The first timer is the "Sleep" timer which turns off the device display to extend battery life. You can turn the display on and swipe to unlock. The second timer called the "Automatic lock" timer turns on security features like pin, pattern, password or face unlock and protects the device from unknown users. This"Automatic lock" timer begins after the "Sleep" timer expires and you will be asked to enter personally recognizable data like pin, pattern, password or the face unlock when the display is powered on.
Note: The Automatic lock option will only show after a screen lock option (other than Slide) has been set.
To adjust the "Automatically lock" timer go to Settings > Security & Screen Lock > Automatically lock > Select desired time frame.
To adjust the "Sleep" setting go to Settings > Display > Sleep > Select desired time frame
If you are using facial recognition and do not want the "slide to unlock" to appear, set the "Automatic lock" timer to "5 seconds".
Power button instantly locks
There is an option in Android 4.1 (Jelly Bean) which will automatically lock the device when the display is on and the power button is pressed. As soon as the power button is pressed your device will lock.
Note: The Power button instantly locks option will only show after a screen lock option (other than Slide) has been set.
To activate the "Power button instantly locks" setting, go to Settings > Security & Screen Lock > check the Power button instantly locks checkbox.
It is important to note your phone may contain security policies set by your IT administrator which may override any settings you attempt to set under screen security. For example, if you set your phone to automatically lock for 30 minutes and phone locks after 10 minutes, it may be due to security policies set by your IT Administrator. Please contact your IT Admin for more information.
For more information on using your new lock features select one of the quick links below:
Lock and unlock basics
Set screen lock
Respond to incoming calls
Face unlock is grayed out
To unlock the screen, press the Power key, then touch [img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics06.png">and flick to .
[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics01.png">
To add a message to the lock screen:
1. From the home screen, touch Menu [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/JB/razr-menu.png" width="34" height="23">>
2. Touch Security & Screen Lock > Owner info and type your message.
Set screen lock
Depending how you use your phone, you may want to set some form of automatic screen lock to prevent unauthorized access. If a screen lock has been set, the screen locks when your phone's display goes to sleep. It is important to note your phone may contain security policies set by your IT administrator which may override any setting you attempt to set under screen security
Before setting a screen lock it is important to note that you will need your Gmail / Google Account credentials to reset any security lock, so please do not set a security lock on your device without first setting up a valid Gmail/Google Account you can remember and access.
To adjust your phone's lock settings:
1. From the Home screen touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> >
2. Touch Security & Screen Lock > Screen lock.
3. Touch the type of lock you want and follow the onscreen instructions.
If you have previously set a lock, you must enter the pattern, PIN, or password to unlock the lock settings.
4. You can choose among these lock options, listed in approximate order of strength: Slide, Face Unlock, Pattern, Pin, and Password
After you set a lock here, a lock screen displays whenever your screen wakes up, requesting the pattern, PIN, or other specified key
Respond to incoming Calls
While the screen is locked, you can respond to incoming calls in three ways.
  1. To answer a call, touch[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/icsphoneicon.png">and flick to .
  2. and flick to .
  3. and flick to . Select a message to immediately send it.
    Tip: To silence an incoming call alert, press the Power key or the volume keys.
Face unlock may be grayed out due to security policies set by your IT administrator which may override any setting you attempt to set under screen security. Contact your IT admin for more information.
Was this answer helpful?
YesNo
Sep 13, 2013 | Computers & Internet
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
Power button locked
Please tip and trick in my profile: http://www.fixya.com/users/budmrtn
? OSD Lock —The OSD can be enabled or disabled by
“SD Lock”displays for 10 seconds.
?If the OSD is locked, press and hold the Menu button for
?If the OSD is unlocked, press and hold the Menu button
Apr 15, 2010 | HP w1907 LCD Monitor
Help me my system is OSD Lock give me the solution.
Option 1: OSD lock - all 4 buttons are locked except the "POWER"
button. Press and hold the "MENU" and ">" buttons for 3
seconds to lock the buttons. Repeat this step to unlock.
Option 2: OSD & Power button lock - all 5 buttons including the
"POWER" button are locked. Press and hold the "MENU"
and "<" buttons for 3 seconds to lock all 5 buttons. Repeat
Mar 06, 2010 | ViewSonic E70f 17" CRT Monitor
It unlocks easy in my pocket and calls people
ENV3 right? two options: option 1:go to settings and tool from the main menu (flipped open and pressed ok) Go to 6: Phone settings. Click security. Type in the last four digits of your cellphone #. Go to 4: Lock phone now. To unlock it: type the last four digits again. If you want to lock it on power up. Go to 3: Phone Lock on that same menu
2nd option: Click over on the keypad surrounding the ok button. Key guard will have a picture of a lock. Click OK on key gaurd. Go to 3: Unlock options. Go to press once or press twice. Then it will unlikely to dial numbers in your pocket. Go to 2: Keygaurd Timer. Set it for 7 seconds. Then, click cancel. Go to 1: Lock Now on the same menu for instance results.
Dec 02, 2009 | LG enV3 VX9200 Cell Phone
Balance CM2019 19" LCD Monitor Logo
174 people viewed this question
Top Balance Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
