Question about DeLonghi Heating & Cooling
My Delonghi Pinguino - PAC W160A, doesn't cool and shows error code CL. I have cleaned the filters and water tank... Is this ChildLock? If so, how do i fix this?
  • theho600
    theho600 Jan 11, 2013
    Thank you Royzee. That link put me on the site with the manual. CL means i need to descale and can reset the alarm/error code by holding the power button for 10 seconds. Cheers :)
  • 134 Answers
SOURCE: Exhaust Hose DeLonghi PAC-210U replacement
Hi
You need to go here
://www.delonghi.co.uk/accessories.php
Posted on Feb 14, 2009
  • 10865 Answers
you can contact the company directly at
Contact Center
1-877-882-8604 Monday – Friday
8am – 8pm EST
good luck with this.
flatech
  • 111 Answers
SOURCE: Delonghi pac w160a...''no water symbol'' stops on
In the back of these units where the cord pulls out, there is usually a red reset button, try pushing that to reset the unit, also make sure the filter is clean, pulls from the top out of the unit. Make sure the coils are clean as well behind the filter.
Good Luck!
Posted on Nov 14, 2009
  • 66 Answers
SOURCE: DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Posted on Feb 19, 2010
dcramer531
  • 1654 Answers
SOURCE: I have the same problem. My Delonghi AC (PAC
Did you look in the back of these units where the cord pulls out?
There is usually a red reset button, try pushing that to reset the unit, also make sure the filter is clean, pulls from the top out of the unit.
Posted on Jan 10, 2011
I just bought a used DeLonghi Pinguino PAC 02. It seems to cool ok but the exhaust hose gets very warm. Is that normal?
Yes, that is normal. It's exhausting the heat from the compressor out the window.
Thanks for choosing FixYa.
Sep 09, 2011 | DeLonghi Pinguino PAC-02 Air Conditioner
I have the same problem. My Delonghi AC (PAC W160A) shows no water symbol even the tank is full. I checked for the red button , but i couldn't locate any.
Please check float valve and sensor. Some times by mistakes the error could display. Reset it by removing power or batteries and then reset it.
Jan 10, 2011 | DeLonghi Air-To-Air Portable Air...
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
I own a delonghi pinguino eco PAC T120 and when i switch it on it shows 'ft'on the screen. it doesnt turn the air on. what can i do?
Probably, the
"ft" means to check the filter. If your filter has not been cleaned in a while, it cannot breathe,and operate properly.
Dec 22, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi pac w160a...''no water symbol'' stops on in airconditioning mode even though water tank is full
Good Luck!
Nov 12, 2009 | DeLonghi Air-To-Air Portable Air...
Why HP or LP error showing frequently in running period of PAC units?
could possibly be an air filter issue. check your owners manual under trouble shooting for what these codes mean. HP and LP error codes usually mean hig and low pressure.
Feb 03, 2009 | DeLonghi Pinguino PAC-02 Air Conditioner
Empty wateron DeLonghi Pinguino Pac L 90
That probably is Ft, meaning full tank. Look on the bottom of the back side, and there should be a small "hatch" that will open. The two small hoses in there are drain hoses that can be unplugged to drain the tank. They're right at the bottom, so if you have a way to raise the unit up a little that would let you drain the water into a container. Might be a good time to clean the filter too.
Sep 08, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Pinguino pac-166 not cooling enough
CHECK AND CLEAN THE DUST FIELTER AND ALSO CHECK THE BLOWER THEN TRY IT
Jul 06, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Error Message
It's actually "Ft", which means "Full Tank".  The instruction manual says to drain the internal safety tank through the drain hoses.
To drain the tank, open the cover on the rear of the appliance. Pull out the 2 drain hoses, take off the caps, and let all the residual water flow out.  When all the water has been drained, place the caps back on the hoses and put the hoses back inside.
It also says you need to clean the filters and let them dry thoroughly before putting them back.
This is also the procedure for "End of Season Operations."
Hope this helps!
Jun 05, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
122 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
