I loaded a new roll of paper and got error code E161-403F. So far I have switched the printer on and off (and unplugged the machine) and checked for anything trapped around the print heads (that are only 1 month old).
SOURCE: Canon MP500 Printer head error
Print heads for nearly all printers are rated at 2 years. You may also need to clean the tube from the resevoir at the ink supply to the cartridge and clean the working resevoir on the cartridge as well. If you are up to this challenge there is a how-to at your manufacturer's web site or you can have a tech do it. Most people, when they realize how inky you will be getting choose to have a tech do this.
It is best to use 100% denatured alcohol, from your hardware store, to clean these parts and tubing. But, you must take precautions.
DO NOT USE DENATURED ALCOHOL UNLESS YOU READ AND FOLLOW THE DIRECTIONS ON THE BACK OF THE CAN.
I'm not kidding about the precautions. I do all this stuff outside when there is a breeze in the air and then I stay up wind of my work.
If you have any questions whatsoever just feel free to comment back to me.
Regards,
Worldvet
SOURCE: canon ipf 8000 print head problems
You need to boot the printer into service mode.
Hold down the roll/source button and the info button while you are powering on the machine.
This should get you booted into the service menu where you can then access the replace printhead function
When you have successfully replaced the printhead, reboot the printer to get out of service mode,
You may also want to check the firmware version of your printer and update it.
Updates can be found on the Canon website
SOURCE: Canon PIXMA MP530 Error Code 5100
OK. It sounds like there's something on the carriage bar restricting the movement of the ink carrier. Perhaps some ink got on the bar.
Try taking a clean lintfree rag dampened with rubbing alcohol and clean the bar. This may have to be repeated a number of times to get the foreign matter off the bar and the ink carriage.
Let me know if this helps. iF it does not we can try something else.
Thanks.
SOURCE: canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
SOURCE: I need to change the
you can solve this error code by removing the purge unit (take care of the ink).
Then you have to turn upside down the unit to check the gears. There is a white gear that moves in the ''air''. you have to re adjust the gear to transfer the move normally.
Then the problem dissapears.
Also you have to check if the motor is still moving.
