Question about Denon AVR1611 5 Channels Receiver
IR receptor not working
Hi. I have a Denon 1611 and the IR receptor is not working. I can control all receivers functions with the buttons on the panel but not with the remote control. The remote is working, I ve already tested. Also the IR IN port (P2) in the rear is not working. I reseted the receivers processor and the remote worked normal for a few minutes than the problem came back. I reseted again but this time didn t work. Any sugestions? Thank you.
djnick989
  • 1067 Answers
SOURCE: Denon AVR-1905 remote
www.remotewarehouse.com grenteeed fit match
Posted on Jan 26, 2008
marsrover
  • 682 Answers
SOURCE: Denon AVR-1707 Receiver - remote stopped working
please apply a new fresh battery to it-confirm from right orientation(polarity)-try to apply a contact cleaner spray over the bad button and press it many times.-remove any thing between remote and receiver.-you can use universal remote and confirm befor you buy the new remote that it support your receiver.
Posted on Jul 12, 2008
  • 336 Answers
SOURCE: Denon Remote Required
www.encompassparts.com has them but hold on to your hat!
Manufacturer den.jpg Part Number 3990949003 Part Number Variations Description REMOTE CONTROL RC974 AVR2805 Your Price $118.29 Detailed Description n/a
Posted on Jan 24, 2009
  • 88 Answers
SOURCE: Denon 528 amplifier cuts out after a few minutes
disconnect the speakers and see if amp will stay on. if this the case maybe suspect one of the o/p amps
Posted on Feb 08, 2010
  • 101 Answers
SOURCE: Denon AVR 1609 volume Zone 2
Logitech recommends that zone 2 is controlled using device mode on your Harmony remote. Controlling zone 1 and zone 2 simultaneously within activities may lead to the AV Receiver turning on and off unexpectedly as you switch between activities. For example, if you try to turn on zone 2 within an activity, it may turn on or off zone 1 and vice versa. Controlling zone 2 in device mode will prevent this from happening.
Posted on Apr 20, 2010
I have a 20.1 Dish remote controller. I would like to use the AUX selection to operate my Denon AV receiver. Can you help me with this?
Depending on the age of your receiver, this may be possible. Turn on the receiver. Then press and hold the Aux button until all of the mode buttons light up. Press 2 to tell the remote that the unit to be controlled is an audio receiver. Then you will need to try one of the Denon 3-digit codes. Press # and check that the mode flashes 3 times. Check if your receiver turns off. If it does, check if the other buttons work to control the receiver. Otherwise try another Denon code by starting at the press and hold the Aux button step.
If you want the remote only to control the volume, mute and power functions of the receiver, press 1 after entering the three-digit code and before pressing the # key.
The Denon device codes to try are 669 670 680 682 696
744 759 760 762 792 809 . You can find the directions for programming the Aux key on page 11-12 of the manual. The code list for audio devices starts on page 43. The manual is available from Dish here: https://www.mydish.com/filestream.ashx?ID=3025 . Usually the code list for universal remote features will not always work with devices that were released less than 6 months before the remote was programmed. Devices released after the remote was programmed are similarly not guaranteed to be supported.
I hope this helps.
Mar 29, 2017 | Denon Televison & Video
I have a denon avr-1611 and can get sound playback through my connected speakers (not tv speakers) but no video output from hdmi. I have the receiver connected to a samsung tv. Is there any fix for th
You should check your Denon manual to be sure that the receiver has been set up correctly. My 1913 has many set up options including associating a particular HDMI out connection with a particular source like CBL/SAT or DVD. The fact that you hear sound indicates the HDMI cable connecting the cable box or DVD player to the receiver is working ( at least the sound portion of the HDMI in cable.)
Next, is the HDMI connection you are using to the TV the one selected in the source listing on the TV ? The sound and video circuitry on a receiver are separated and you can hear sound but see no video if the TV isn't selecting the correct source. For example if the TV is set to HDMI1 but you are plugged into HDMI 2. If this doesn't solve your problem try this:
At this point you don't know if the problem is the receiver HDMI connections or TV HDMI connections or a bad HDMI cable. The first thing to try is a new HDMI Cable. If that doesn't solve the problem then do the following.
If the TV has more than one HDMI connection try another HDMI port. Be sure to switch the source on the TV to the new HDMI port ie. HDMI1,HDMI2 or whatever.
If this fixes the problem you are done. If not then Try the same thing with the HDMI out ports on the receiver. Try each one not forgetting to set the receiver to use the HDMI port you are testing.
each time.
Since this can get confusing I would write down what you are testing each time so you don't get lost or confused.
If none of this works then you can try hooking up another TV to the HDMI cable, if you have one. If you do this and you still have a problem it points to the receiver as being the culprit.
The most likely problem is you have misconfigured the system so that is where I started. Each test is dependent on the fact that your system is correctly configured to begin with.
Sep 04, 2014 | Denon AVR-1611 A/V Receiver - 3D - 75 W...
Wont turn on
follow this steps and fix it.God bless you
There is something blocking the receptor on the main unit.
Remove any obstructions and clean the area in front of the receptor.
The remote is too far from the receiver or at too extreme of an angle.
Move closer to the receiver (within 23 feet) or change the angle (within 30 degrees) to the receiver.
A fluorescent or other bright light is shining on the receptor on the main unit.
Turn off the light or shield the receptor.
The device has a keylock or lockout feature turned on.
Check the display for a key or lock symbol, then follow the instructions in the device's user manual to turn off the keylock or lockout feature.
Either the remote or the receptor on the device is not functioning.
Use an Intraed Sensor to see if the remote is sending a signal.
If the remote is sending a signal, it used to control that device, and no other solution works, you should have a service center look at the device and remote to determine the problem and if it can be fixed.
If the remote is not sending a signal and you have replaced the batteries, you will need to repair or replace the remote, depending on cost.
Jul 26, 2013 | Televison & Video
Denon 1611 region free hack
Question is, does in state from the manufacture that it is in fact, Region Free? If its not, you won't be able to play it. In your question above, you say "hack", which means that someone outside of Denon, has rewritten the firmware, for which there you are gambling that the DVD may not ever play again, without some serious repairs. If you would like more assistance, please contact me at my website, audioserviceclinic.co. Thank you.
Dec 26, 2011 | Televison & Video
Tengo un receiver denon avr1609 y quiero restaurar los valores de fabrica como puedo resetear
uno de los tres por debajo de las soluciones de trabajo para que el receptor
1. Para reiniciar el sistema, a su vez el receptor apagado por el peque?o bot?n on / off, no el bot?n de espera grande. Mientras que fuera de noche y pulse el bot?n directo puro, a la vez y sigue tomando con su mano derecha mientras presiona el peque?o bot?n on / off con la izquierda. Ver? el flash men? del receptor. Cuando lo ves flash dejar ir de la noche y botones de acceso directo puro y el receptor se reiniciar? si mismo a la estaci?n de radio 87.50.
2. Pulse el bot?n "Power" al mismo tiempo presionando el bot?n "Standard " y "Simulaci?n DSP" en el panel frontal de su receptor Denon. Estos botones tambi?n pueden estar ocultos debajo de un panel tir?n en funci?n del dise?o y el modelo de Denon que se utiliza. Algunos modelos de Denon requieren diferentes combinaciones de bot?n que se pulsa simult?neamente mientras se presiona el bot?n "Power", como el "Modo Surround" botones. Algunos modelos de receptor Denon no proporcionar? las instrucciones de restablecimiento en el manual del usuario, para encontrar las combinaciones de bot?n derecho debe ponerse en contacto Denon.
3. Pulse el bot?n "Power" para apagar el AVR-
Pulse el bot?n "Power" al mismo tiempo la tecla "altavoz A "y "Speaker B" botones. Espere a que el AVR-788 a la pantalla comenzar? a parpadear a una velocidad de alrededor de una vez por segundo.
Suelte los botones despu?s de la pantalla comienza a parpadear. El AVR-788 es ahora restablecer la configuraci?n predeterminada de f?brica.
Mar 15, 2011 | Denon AVR-1609 Receiver
How to unlock the region coding for Denon DBP-1611?
Hi Guys, i like to make my DBP-1611 Denon Blu ray regio free, can anyone help-me PLEASEE??
Thanks
André Curti
Dec 06, 2010 | Denon DBP2010 BluRay Player
Hi my name is Sonia and i just purchsed a Denon Receiver, however the remote i that came with it doesn't work with the receiver. What can i do?
You can buy a universal remote at walmart to operate basic functions or go to 800remotes.com to buy a replacement
Sep 19, 2010 | Denon Televison & Video
Aug 07, 2009 | Denon AVR588 Receiver
Denon RC-980 subsitute remote for Denon AVR-3200
I have a remote left over from my denon ACR3200. the remote is RC-825. It is currently listed on Ebay.
Dec 24, 2008 | Audio Players & Recorders
IR Receiver
Are you serious?
In case you are serious, IR=infrared.
When you point your TVs remote control toward the TV and press a button, it is the IR receiver on the TV which receives the IR signal which is transmitted from the IR LED (Light Emitting Diode), which is the small bulb like part, on the front end of your remote control.
Any device using a IR remote control, must have an IR receiver to gather the siganl being transmitted. The IR siganl is a coded message of instructions for the device.
Dec 08, 2007 | Jazz DV-179 Digital Camera
Denon AVR1611 5 Channels Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
