I have a 7kg DWD-F10115 washing machine, it developed a problem an now it cant wash but can do other things, kindly help plz
The indicator shows that process of washing is taking place but it doesn't in real sense, when i select other details like rinse ,it does but the spinning an washing process derailed completely
kevin000
  • 1847 Answers
SOURCE: Simpson Esprit 750 Washing Machine.
the control panel has gone bad needs replacement.
Posted on Jul 15, 2008
  • 3 Answers
SOURCE: Spin cycle error - UNB
Haier have had one or two problems with there spin,
option 1 make sure the machine is balanced perfect [no rocking at all ] use a level on the machine [ truly ] it works.
option 2 you can not wash one item [ underload the machine or overload the machine this will give same result UNB .
option 3 if you have had the machine a few months and this has just started [ clean the armature on the motor with emery cloth and a quick spray of W D 40 please plug out the machine first
0161 355 8254 if you need help , good luck
Posted on Mar 04, 2009
  • 9 Answers
SOURCE: Beko washing machine will not complete wash cycle. it will not rinse anf then spin. You have to manually select spin and drain after wash is done. can the maching be reset in anyway.
your timer is most likely bad
Posted on Apr 20, 2009
  • 3 Answers
SOURCE: hoover optima hnf6167 7kg washing
My washing machine completes its cycle but is leaking water from the left hand side on to the floor, Why is this???
Posted on Apr 25, 2010
  • 4 Answers
SOURCE: LG Intellowasher 7kg 800rpm WD-8074FHB
It could be that the springs have become lazy (stretched) and not supporting the spinning weight as good as they once did or as happened to me one of the shock absorbers at the base of the unit has come adrift from its securing point. Replacement parts are easily available but you will need someone strong to fit them with all that new tension.
Posted on Jun 07, 2010
How can I get a shorter wash on the Logixx7. Every wash is lasting at least 3hrs!!!!!!!!.
Hi dear,
I do not know what type or model of your washer but those LOGIXX series should have a INTENSIVE wash button. Make sure that button not active when you setting your program by default and you are not over loading your machine. You need to use specific program for specific wash load. Example: Let's say your machine has 7Kg dry weight wash capacity. That's indication for Cotton Fabric Only. Your machine able to wash 7Kg Cotton fabric but it can not able to wash 7Kg WOOL, Dedicates, Jeans etc. Refer your machine's user manual. I hope that helps. Thanks.
Jan 31, 2016 | Bosch Washing Machines
Wash Capacity WF810W
wash capacity?? what is the dry weight?? you meen
did you look at the manual ???
i see its a 7KG machine so 7KG DRY weight
wet weight LOL
what type of water and what did you put in the drum
so its a 7KG machine
so you can put in 7KG of matter to then get wet and get washed
Mar 05, 2015 | Whirlpool Washing Machines
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
My Daewoo does not want to spin, any suggestions?
first does all of the water pump out when wash cycle is done? if not then check your drain lines and see if pump is coming on. if it is not then it wont let the washer spin,
Jun 03, 2014 | Daewoo Washing Machines
Instruction manual for hotpoint aquarius WDL540 7kg Washer/dryer
My washing machine's indicator flashing after 5 minutes,what should i do?
May 13, 2012 | Washing Machines
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
Daewoo Washing machine Problem
If it is new then it is under warrty plz call the dealer you bought iy from for service
Aug 02, 2008 | Daewoo Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
