Osaka Gas Blower Heater Model: 43-553 The heater takes a very long ignition and then gives error 11 or 12 .. Another heater is functioning ok on the same line so there is no problem of gas pressure .
    Genius:
  • 1,669 Answers
It sounds like a gas line or gas jet is clogged. Clean off the gas tip that is near the electronic igniter. Also find a small diameter wire to clear any obstruction in that jet. Also, carefully clean off the igniter tips.
Posted on Jan 11, 2013
  • ehsan Apr 27, 2013
    can anyone take a picture from gas tip place ?
    I have same problem and the spark works correctly but there is no gas flow! after a while i get error 11
No problem at all. just lower the amount of gas input. Just open the minimum amount of gas valve open to run the heater. your gas pressure is quite high which shutoff the system.
Posted on Nov 20, 2014
meBNme
  • 334 Answers
SOURCE: blower turns on when stat calls for heat but
Here is the ignition sequence for a spark ignited furnace. This will help you understand what is happening/not happening.
Thermostat calls for heat.
draft inducer motor (DIM) starts drawing draft through heat exchanger.
Pressure switch detects proper operation of DIM, and sends signal to board to begin ignition.
(it detects negative pressure)
Ignitor starts ignition attempt and gas valve sends gas to burners.
Upon ignition, flame sensor detects flame and sends signal to board stopping ignition sequence and continuing gas flow for heat mode operation until thermostat is satisfied.
During this sequence the blower motor is brought on, and by using a series of temperature limit switches, the system assures that the unit is operating properly.
(If the blower is not operating, or the airflow is inadequate, the heat exchanger will overheat and trip one or more temp limit switches.)
There is also a "rollout" switch that detects improper flame pattern "rolling out" into the controls compartment.
Now, to apply that to your situation.
If you have no spark, than the failure is happening before the gas is supposed to be flowing.
That usually means a failure at the D.I.M. Typical causes for that are a clogged flue pipe/vent, damaged/deteriorated fan blades, bad fan, or bad pressure switch.
If one of the temp limit switches or rollout switches have tripped, it will simply shut off the system.
(Some units will turn on the blower motor and shut down everything else.)
You can try resetting the unit by disconnecting power for 1 minute, and attempting a restart.
First look for any flashing LED lights. If you see any locate the wiring schematic (usually on the inside of the front panel) and look for the flash codes.
If the reset does not solve the problem, let me know what flash code you are getting, and/or let me know exactly what you see the furnace doing, in detail, after the restart.
Posted on Oct 03, 2009
machtcl1
  • 61 Answers
SOURCE: Payne Gas Pack Furnace A/C and Heat Unit
Do you have power to the unit?
Is it a 110v or a 220v unit?
check your power supply.
Posted on Jan 02, 2009
hvac1960
  • 2133 Answers
SOURCE: need Owner's Manual for Osaka
SERVICEMANUALS @ COST www.mauritron.com Manuals at free download: homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html
Posted on Dec 30, 2010
  • 2976 Answers
SOURCE: gas heater won't work
Which flame sensor did he replace? The pilot flame or the plenum temp. sensor.
Posted on Aug 10, 2009
SOURCE: Rheem classic super quiet 80.
YOUR TEMPERATURE SENSOR NEEDED .
CLEANING, LIGHT SANDPAPER WILL DO THE TRICK.
IT LOOKS LIKE AN UP RIGHT NEEDLE ATTACHED TO A SMALL WHITE DISK. http://alltemp.com/FreeInHomeEstimate.html
Posted on Mar 05, 2011
English manual of 43-531 gas heater
Via google input heater name in search followed by user manual ,should help .
Jan 04, 2018 | Water Heaters
My osaka gas heater 140-9173 is not switching on rather a green light on key is permanently on. in this case how to switch on the osaka gas heater
The green light means it's in standby mode. Make sure the child lock is not on and that it's not in timer mode. Also, check to see if the heater is dirty on the inside, unplug and clean as necessary. Make sure that the gas supply line valve open and that you have pressure in the line. The over heat thermister could be tripped and the whole unit needs to be unplugged and then plugged back in.
Jan 21, 2017 | Heating & Cooling
Osaka gas 43-564. what's the meaning of writing on panel
I need user manual (in English) for OSAKA gas heater 43-564 model
Jan 25, 2014 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
OSAKA 43-530 , Error 55 and middle green light flases in left pannel
If the gas lights & doesn't stay on, then there is a flame sensing issue. Remote sensor may have flame impingement (dirty). Clean flame rod sensor with light sandpaper or cloth.
Jan 06, 2014 | Weather King 12AJA4801AH Air Conditioner
Hi, I have Osaka Gas Heater model 43-540.
A natural gas heater can only burn natural and vice versa unless there are changes such as orifice and regulator. They can easily be converted to use either fuel, but you have to know what fuel supply you have, and what the appliance is set up for. Since you've already tried LPG, if it turns out the appliance is natural gas, then replace the spud (burner nozzle) before trying to operate it again. LPG cannot pass through the small nozzle hole in a natural gas appliance.
Nov 25, 2013 | Heating & Cooling
Jandy LXi gas heater error message "ignition control failed
if ignitor is glowing try changing position of the shutter 1/2 to 3/4 open should lite
Dec 22, 2012 | Jandy Laars LX Pool Heater / 250,000 BTU /...
Hi i need English Language manuals for Osaka Gas Fan Heater Model 43-659... as the operating buttons of the heater is in Japanese Language. by mis handling it i got its timer ON. now dont know how to fix...
I have gas fan heater made by Tokyo Gas, model MA-A630TFH.
on the front pannel all the language is jAPENESE. PLEASE HELP ME AND MANAGE FOR OPERATIONAL MANNUAL IN ENGLISH.
Oct 20, 2012 | Heating & Cooling
Osaka gas heater manual
DOWNLOAD LINK
http://www.dl4all.com/aka/tag/osaka+gas+fan+heater+user+manual.html
OR
http://www.osakagas.co.jp/indexe.html
Jan 24, 2012 | Water Heaters
Pool heater will not ignite
My heater worked ok , btu made a clicking sound, now it shows a AO error? What can I do I dont have enough money to call a pool man again.
Jul 03, 2009 | Hayward H Series Pool & Spa Heater 400k...
Heating & Cooling Logo
1,387 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
