Question about Video Game Consoles & Games
Fatal error AmmoType_Open(): - Video Game Consoles & Games
Fatal error
Copy the file config.qvm and other .qvm files from C:/program files/eidos interactive/progect igi/pc to C:/program files/eidos interactive/progect igi/pc/common/ai
May 21, 2013 | Video Game Consoles & Games
The photos r not opened.when i opened it shows the fatal error
hi ram
  1. mainly this fatal error occurs when an portfolio may be converted into smaller or other than that may this error occurrs
  2. to avoid this don't change type and open it in windows photo viewer...
Dec 25, 2010 | Computers & Internet
Everytime I use to open GTA IV it says GTA IV FATAL ERROR: RESC10 wats this and how to solve??
If you keep getting the "RESC10 Fatal Error" then turn clip capture off by pressing "ESC" then going to game then turning it off.
I hope this will work for u. plz vote
Sep 23, 2009 | Video Game Consoles & Games
Fatal error when installing HP Officejet 8500, fails at 96%
hi did you get any particular error during the installation that said fatal error 1935 or 1709 or some other message if you get any error message please mention the specific error code and try the step mentioned below
insert the cd in to the computer and then go to computers and right click on the cd icon and open it now you will see a Util folder open it and then open CCC and in CCC you will se some files like uninstall_L2, Uninstall_L3, Uninstall_L4
if you have a HP computer then open uninstall_L3 and continue to clean the printer entries If you do not have a HP computer then open UNINSTALL_L4 and continue
after cleanup restart the computer and then go to c drive >>Program files >>HP and delete the digital imaging folder
now install the printer software once again if you still get a fatal error at 96% then do not click on the ok button of the error screen directly restart the computer and when it restarts go and try to print in will print fine
and still if you have any problem then you can call the HP helpline for free support that is 18004746836 24hrs support
Sep 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Get 'fatal error' during HP C4599 install
hi did you get any particular error during the installation that said fatal error 1935 or 1709 or some other message if you get any error message please mention the specific error code and at what % you get the error is it at 18 % 32 % 56% 94% or 96 % if you get the error at 96% followthe step mentioned below or else please tell us the % at which you get the error
Sep 10, 2009 | Office Equipment & Supplies
Our OKI C5100 is showing 171:Fatal error. What should we do?
The 171 Fatal error:
Upper Thermistor, State:Open
When an open circuit has been detected in the heat roller thermistor (low temperature)
Check the heater connector and the thermistor connector to make sure they are seated properly. If OK you probably need to replace the fuser.
Hope this helps.
Sep 03, 2009 | OKI C5100n Laser Printer
Fatal error : 144 on a Okidata
this is indicated when the toner feed switch error
or the toner locklever-open error occurs repeatedly when new toner is used.
it has to do with the yellow.
3 possible solutions.
Confirm that the lever is in position.
Replace the toner feed unit.
Replace the ID units.
Aug 28, 2009 | OKI C9600hdn Laser Printer
Konica minolta 5430dl colour printer
13D0H: Parameter Chip failure
Unplug the power cord and plug it in, then turn
OFF and ON the Power Switch.
the PWB-A may be faulty.
May 21, 2008 | Konica Minolta magicolor 5430 DL Laser...
Fatal Error
unplug and plug back in.
Jan 15, 2008 | OKI C5150n Led Printer
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
