Question about Empire DV-215 Direct Vent Natural Gas Heater
I'm new handyman
How can i conect the thermostat cables to my heather.
From the thermostat you have R and W, R goes to the Transformer and W goes to the Gas Valve if you have a 24 volt system
Posted on Jan 22, 2009
Fiat Seicento sporting 2004 model. Only hot air comes from vent. Although the heather is off. It is aweful when it is summer.
Depends if heater switch is electrical or manual. If manual , could be cable is bent, if electrical , new switch needed.
Aug 21, 2017 | Fiat Cars & Trucks
Is this thermostat wiring correct for this Rheem water heater? also it only has one thermostat...shouldnt there be 2?
Heather, first know that most water heaters are 220 volts and are dangerous to work on unless you know that the power is off. Second it is hard to say any more without knowing the model number and the make. Third from the picture, a thermostat breaks the current in one side of the circuit and that appears to be depicted. There are usually TWO heating elements not thermostats.
Feb 09, 2017 | Rheem Water Heaters
How to set thermostat for garrison 052-2025-6
Hi my name is Dan I miss place my manual for my Garrison Convection Heather 052-2025-6 trying to set thermostat having trouble. My e-mail Danthehandyman@homail.ca
Nov 20, 2012 | Heating & Cooling
My heat don't work it blows cold air
Could be the heater core went bad, heather core lines are plugged, cover on the blower motor is off, or if your temp selector is cable, the cable may have seized
Oct 16, 2012 | Air Conditioning and Heat for Mercury...
I have AEG Lavatherm T-300-W dryer and it is not drying anymore. I checked front door filter and it is ok. Is it thermostat or blower problem? Thanks, Tom
If it spins, it's your element...but if its your element, it could just be your thermal fuses...which can be repaired rather than replace the whole element which is very expensive. operations@handyman.co.za or www.handyman.co.za
Nov 27, 2010 | AEG Dryers
Too hot wather/ thermostat problem
its 3 phase not 4 Your wired wrong one of those should be a nuetral or ground
May 10, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Heater hose diagram for 1990 dodge dynasty. The heater hoses where conected togather due to a bad heater coil that has now been replaced I need to know how to put heater hoses back where they go and I am...
remove the hoses at the temp conection inspect them to make sure they are good them follow the one that comes from the pump housing goes to the top of the heather core outlet and the return one to the bottom this may be a bit diferent if the engine is 6cyl or 4cyl.
Sep 08, 2009 | 1990 Dodge Dynasty
Thermostat won't stay on, even with new batteries on hunter therm
replace the thermoste with a new one its easy to do
1.turn of breaker to doorbell air handler and compresser (outsideunit)
2 take of thermostat lble wires as to wich leters they conect to
3 put on new thermostat enshuring whires are conected to corect letter
4 turn on beakers and enjoy!!
Jan 21, 2009 | Hunter Fan Company 5/1/1 Programmable...
WHERE TO CONECT THE 2 WIRES TO THE NEW THERMOSTAT
Connect one to Red, R or Rh.
Connect the other to White or W.
Jan 09, 2009 | Honeywell Programmable Thermostat Heater
Terminal Capio 620
The BIOS don't support USB bootable devices even with the LEGACY option ENABLED (it's only for keyboards or mouse), but ther is a way, open the box and you will notice a IDE heather on the board, the problem is it's not a standard 40 pin IDE heather, it's a mini IDE like for laptop HDD's, so what i did is i've purchessed two IDE adaptors from MINI do standard IDE, spliced the power cable for powering the devices, conected a standard flat 40 pin IDE ribbon cable to both adapters and VOILA i have a verry thin silent computer with a 15GB (MASTER) hard drive and a 52X CDROM (SLAVE), obviously with that hardware i can't close the box anny more but i'm running LINUX (DSL) fine.
cheers!
Dec 13, 2008 | Neoware CAPIO 620 (cp4h-bb-aa0) Network...
Empire DV-215 Direct Vent Natural Gas Heater Logo
131 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
rudyjoe
Level 1 Expert
vance jones
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
