Question about Frigidaire GLTF1670A Front Load Washer
No power My washer just have no power at all after a electrical power outage at home. The dryer was not affected. Is there any fuse that I can check ?
  • Frigidaire Master
  • 17,129 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Jan 11, 2013
Why did Kenmore series 110.60202990 dryer stopped working after power outage?
check electric box, termo fuse on air duck (white 2 wires normally blue)
Jan 05, 2015 | Kenmore Dryers
Is there a reset button for Frigidaire AEQ7000EGO? Had a power surge/outage and now dryer has no power, although plugged into electrical outlet.
Good Morning Friend,
I understand you had a power surge at your home, and now your Frigidaire Affinity dryer, model#, AEQ7000EGO, has no power. I do see that you have checked to make sure that it is plugged in. I suggest checking the circuit breaker or fuse that the dryer is on. Make sure that the fuse is not blown or the breaker tripped. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Where is fuse on frigidaire aeq7000ego
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Dryers
We have a frigidaire washer dryer combo. after a bad storm (our electric kept flickering off and on) our washer no longer works. we noticed that it would only fill up with water while dryer was on. now it...
Possible damage on the program control panel as it is most likely to be damaged due to a power outage. remove panel and check to confirm if the board is burnt or damaged
Jul 03, 2012 | Frigidaire FLEB8200DS Top Load Stacked...
Kenmore 65652 electric dryer won't turn on. Breaker is OK.
Hello Cheryl,
The water spillage from the washer could have affected the dryer from starting but very likely did not cause it.The most probable reason the dryer will not start is a blown thermal fuse.Here is a tip i have written about how to check the thermal fuse. http://www1.fixya.com/support/r10530385-dryer_power_but_start
GENE
Oct 29, 2011 | Kenmore 62602 Electric Dryer
Dryer won't start - is plugged in and all home fuses are working. Could be an interal fuse that was fried during a power outage. How can I check that?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Power outage recently. won't turn on
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 10, 2010 | Kenmore 64672 Electric Dryer
No Power to my TV after power outage
A lot of times its simply a fuse that goes out. Either way someone is going to have to open it up and inspect the fuses first. It 's a fairly inexpensive service call.
Hopefully the fuse took the hit from the storm.
Jun 04, 2008 | Televison & Video
Washer WM-2277HW and Dryer wont turn on after power outage.
there is a fuse on the control board but it is soldered in place and cant be changed. whole board needs to be changed
Oct 19, 2007 | LG WM-2277HW Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
