I cant install password to my lynksys router
I DONT WANT TO CONNECT ANYBODY TO MY WI FI
  • 7,627 Answers
You didn't supply the Model of Linksys, so try Linksys support for a user manual: http://homesupport.cisco.com/en-eu/support/linksys
Posted on Jan 11, 2013
mortega
  • 43 Answers
SOURCE: Forgoten my password
Physically connecting it to the router will allow internet access, but if you're trying to connect wirelessly and don't know the security key you can try logging onto the web interface from the connected computer and reset the key.
Hope this helps.
MO
Posted on Jul 13, 2008
longgee
  • 322 Answers
SOURCE: Problem with my wireless router.
To do that, you must first configure your router. Type in your browser the ip of your gateway. To get your gateway ip, type in your command prompt "ipconfig". Once type, you will be prompted with a username and a password. If you used this for the first time, the username and password are the default of your router. Once you are in, there is a menu there that you can configure to put in your wireless password. Choose WPA, it is much stronger password type.
Posted on Jun 16, 2009
anandg27
  • 1272 Answers
SOURCE: connecting my ipod touch to my wireless router through wi fi
Check for the password on the router configuration page to make sure tat you are using the correct one:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
Enter the same password on IPOD to connect to the wireless network.
Rate it,if it helps.
Posted on Jun 26, 2009
  • 6 Answers
SOURCE: I need to install a password on my wi-fi
  • Log into your router via web browser (usually routers IP is 192.168.1.1). The default password is usually "admin" and leave the username blank. Another way to figure out what IP address is assigned to your Linksys or any other router is to click START > RUN > Type CMD and hit enter. At command prompt type IPCONFIG. The DEFAULT GATEWAY is the IP address that is assigned to your router.
  • From main configuration page, click WIRELESS
  • Then click WIRELESS SECURITY
  • For security mode, choose WEP
  • Keep your default Transmit Key to (1) and set your encryption level to either 64 bits or 128 bits. (128 bits is more secure then 64 bit and much harder to crack.
  • Now you can either create a passphrase which will automatically generate key values or you can set your own key values.
  • Click SAVE SETTINGS
  • Posted on Sep 17, 2010
    Ezrahite
    • 2632 Answers
    SOURCE: I am trying to connect
    Welcome to Fixya. If you iPad is not accepting you password you can check the password or Network Key on your router. To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
    Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Passphrase. The Network Key serves as a password or security code on your network to make it secure. Network Key is case sensitive.
    Don't forget to say thanks. Thanks for using Fixya
    Posted on Feb 07, 2011
    My kindle cant connect to internet
    Go to the Settings Menu, Select the Wireless & VPN option and see if you are in Airplane mode, if you are turn that off. Then select Wi-Fi. See if Wi-Fi is turned on. If it's not turn it on. There should be a list of available Wi-Fi routers. If one is not selected select one that is open or that you have the password to. If none are open or they are locked and you don't have a password, you'll need to get a password for one, or install your own Wi-Fi router.
    Jan 13, 2016 | Amazon Kindle Fire HD
    Extremely strange issue. I recently cannot connect to wi- fi at my house or my business with my android maxx phone. It will connect for a few seconds then it disconnects. I tried connecting at my sisters...
    It sounds like you have a dual band router which has two wifi signals .. 2.4 htz And 5 htz. You might find you are better off on the 5 htz as this gets less interference.if this is not the solution try logging on with this phone but when it gives you the sSid of the router you wish to log into, go far right arrow and look for "forget this network" that will remove any previously saved password for that network then re-enter correct password and the conflict should go away.
    Dec 05, 2014 | Computers & Internet
    Will not connect to wirless internet
    link sys router have drivers.
    if you want to connect to wireless in your link sys..
    first make sure the wi-fi is on..
    to make sure the wi-fi is on..
    run the driverdisk of your router,and reinstall it, in you installation there will be a question if you want to turn on your router's wi-fi i suggest if you turn on it put a password on it so that it can't be easily connected by other pc or laptop...
    then remember your password..
    after that open your laptop or CP, etc wi-fi then search for the connection..
    enter the password you put in it..
    then it will surely connect...
    i hope i've help you a lot...
    Feb 08, 2010 | Linksys WRT160N Wireless Router
    How do I find the WEP for my Westall 327W so I can connect to my wireless printer?
    First connect your router to computer with ethernet cable.
    Then access your router with it's ip
    http://192.168.1.1
    or
    http://192.168.0.1
    type user as "admin" and password as "admin" or blank or "password"
    If you can't able to access it with above ip then press RESET button for 10 seconds it is in back side of router then follow above method.
    then click on wi fi or wireless then check WEP security there is WEP code it is your password to connect your wi fi network .Then anybody need that password to connect your wi fi network.
    If it is in * or # format then set new and save settings.
    Then you connect to your wi fi router with that password.
    Let me know if you need further assistance.
    Dec 06, 2009 | Westell Wirespeed VersaLink...
    How do i re set a lost password so i can set up a secure network?
    http://192.168.1.1
    or
    http://192.168.0.1
    then click on wi fi or wireless then enable WEP security *** WEP code it is your password to connect your wi fi network .Then anybody need that password to connect your wi fi network.
    Nov 25, 2009 | NetGear WGT624 Wireless Router
    I need to password protect my router can you help??
    access your router with it's ip.
    http://192.168.2.1
    or
    http://192.168.15.1
    Nov 22, 2009 | Linksys Wireless-G WRT54G Router
    Cant connect to wifi
    Please tell what is your Wi-Fi LED status. what channel count you configured inside the configuration of router. Please be sure that your wi-fi signal is transmitting or the device is able to receive the wi-fi signal.And please tell what router you using as host and what device you using as receiver. Thanks for subscribing Fixya... All the best
    Nov 15, 2009 | Computers & Internet
    I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
    1. Dear! Check your notebook wireless settings and correct it if it is necessory.
    2. Chekc your wireless router settings may it need to update for your notebook.
    Good Luck
    Sep 28, 2009 | Computers & Internet
    How can i ins tall my rangemax dual band wireless-n router wndr3300 to my laptop to setup wifi in my house
    Connect your router to computer with ethernet cable.
    Then access it with following link.
    http://192.168.1.1 or
    http://1921.168.0.1
    type user name as "admin" and password as "admin" or blank or "password"
    Then configure your router as WEP.
    Then go to wireless and check that wi fi is enabled.
    Then go to wi fi security and add WEP key it is your password to connect your wi fi.
    Also enable dhcp if you want get ip auto to computers.
    configure your wan settings as your internet service provider like dns ip addrses.
    Then save settings and restart the router.
    Now go on your laptop first turn the wi fi switch on your laptop .
    Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
    Then double click on wi fi icon and click on "View wi fi networks."
    then connect then enter password which you set in router wep key.
    Let me know if you need more assistanse.
    Thanks.
    Aug 31, 2009 | Computers & Internet
    Have a linksys router and adapter not sure how to install, my daughter wants to use her laptop but cant get the internet
    http://1921.168.0.1
    Thanks.
    Aug 29, 2009 | Linksys Wireless-G WRT54GS Router...
    Computers & Internet Logo
    23 people viewed this question
    David Payne
    David Payne
