Question about Bosch HMT8655GB Microwave Oven
Locating the fuse in a hmt8655gb microwave
I am assuming the fuse in my hmt8655gb microwave has blown but I am unable to locate it to investigate. If someone could let me know where it is and how to change it that would be great. Thanks.
  • Bosch Master
  • 17,129 Answers
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on; use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Posted on Jan 11, 2013
Testimonial: "Thanks for the help after a bit of "messing" I now have a fully working microwave."
Kenmore elite microwave model no. 721.66339011 just stopped heating ...anyone know what or how to fix?
Hello, the fuse normally is located behind the control panel and easily accessed by removing the panel. Here is a schematic to assist you in locating the part...
Dec 17, 2016 | Kenmore Microwave Ovens
LG LMV1813ST MIRCOWAVE STOPPED WORKING?
The fuse can be replaced, but the underlying issue should still be investigated and resolved. Otherwise the new fuse will blow also.
If the microwave is not working the thermal fuse may have blown.
When a microwave stops working the problem is usually the line fuse or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Aug 02, 2014 | LG LMV1813ST Microwave Oven
Microwave has no heat but everything else is running
Most microwave ovens have a High voltage fuse for protection of the magnetron. This fuse has possibly blown. This fuse is normally in the form of a cartridge with attached wiring and is located near the magnetron. I strongly recommend that you have a qualified technician investigate this fault as there are lethal voltages associated with the magnetron.
Mar 22, 2014 | Microwave Ovens
Does not come on
follows this steps and fix it. God bless you
Line Fuse
Every microwave oven has a line fuse. This fuse is designed to blow if too much current is drawn through the microwave circuitry. The fuse can be replaced, but the underlying issue should still be investigated and resolved. Otherwise the new fuse will blow also.
Main Control Board
If the microwave is not working the main control board may be defective. This is not common. When a microwave stops working the problem is usually the line fuse or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Thermal Fuse
If the microwave is not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Feb 07, 2013 | Microwave Ovens
What is the internal resistance of WB27x10194
follow this steps and fix it. God bless you
Line Fuse
Main Control Board
Thermal Fuse
Thermoprotector
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.2_7_2013_10_19_58_pm.gif
Feb 07, 2013 | GE SpaceMaker Microwave Ovens
Goodmans st101ss microwave no power
please follow this steps and fix it. God bless you
Line Fuse
Main Control Board
Thermal Fuse
Thermoprotector
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.1_24_2013_5_05_57_pm.gif1_24_2013_5_07_19_pm.gif
Jan 24, 2013 | Tappan TMT157E1 Microwave Oven
Have a whirlpool microwave model GH5184XPS-4. This morning I turned the "Cooktop Light" on and a few minutes later I heard a small pop, looked over and the lights had gone out. One of the bulbs...
yup most probably that is the case.
you can locate the fuse usually it is placed near the main power supply or just trace the supply cord going in your unit. but before you open your unit be sure it is unplug to avoid electric shock.
slowly disassemble the unit and be sure that you can replace all the screws back to it original positions. after locating the fuse, check if it has a continuity and be sure to replace the same fuse rating. also investigate why the fuse had blown up and look for abnormalities.
if nothing found then replace the fuse and put all back then test the unit. if still it blows fuse, their must be something wrong with the unit and have it service to qualified personnel.
Dec 31, 2010 | Whirlpool Microwave Ovens
Bosch HMT8655GB, after being used no heat and cuts out at 22 secs
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
e6tuwe
May 12, 2009 | Bosch HMT8655GB Microwave Oven
Blown Fuse on a Microwave
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Let us know if you need further help with torubleshooting.
Nov 28, 2008 | Kenmore 62702 Microwave Oven
Problems with my microwave (Emerson MW9090SS)......
Most probably the fuse has blown out...You have to replace it..Dont worry it wont cost you much..If you need help locating the fuse feel free to ask..
Oct 26, 2007 | Microwave Ovens
Bosch HMT8655GB Microwave Oven Logo
305 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
