Question about A4tech PK Computers & Internet
My webcam is no run
When i connect webcam there is no respons. how to fix it?
  • A4tech Master
  • 27,725 Answers
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Hope this helps.
Posted on Jan 11, 2013
Runs very slow
Primary respones to fix your slow netbook:
1. Clean all Temporary Internet Files
2. Clean the registry.
3. Remove malware.
4. Transfer all unnecessay downloads to an external device.
External hard drives are cheap....available for less than $100.
The more files you have on the netbook, the slower it runs.
Feb 16, 2013 | Dell Inspiron Mini 10 Notebook
Can you help me connect my webcam to my computer
just check if you have a slot for the webcam like usb slot then try to check it if your pc will respons on it..but make sure that you install the drivers first before you apply of checking of it..check the connection of cables and plug-in of your cam to pc.
Sep 18, 2011 | Intel Computers & Internet
Aztech HW550 3G problem is Lan port not respon and i get ip 169.254.99.66 - 255.255.0.0 and reset not respon. I cannot login to the router.
An address of 169.X.X.X usually means connectivity issues from your computer to the router.
Try the following:
1. Connecting only the router to the computer, one of the 4 ports together not WAN or Internet. (so remove cable modem at this point).
2. Go to a command shell (cmd in Start->Run).
3. Type in ipconfig /release
4. ipconfig /renew
If you still don't have a proper IP try replacing the Ethernet cable, this can usually be a source of the problem. Also this usually works too, press and hold the Reset button for 10 seconds or so. This should revert the router to the factory defaults, and retry steps above.
Sep 01, 2011 | Aztech HW550-3G 300Mbps 802.11n Mimo...
I have a alienware computer running win7 and veo webcam wont work with it is there drivers to fix it
yes you should download and install a new driver which should be compatible with window 7.
Jul 27, 2011 | Veo Connect Webcam
Primary dns server not responing
be sure router is running and cable is connected.
Feb 06, 2011 | Toshiba Tecra A8-S8514 Notebook
When i click on web cam in yahoo messanger. it hang for a while and not responing, when i tried to close, its not closed also, coz, it say not responding?
In addition to the webcam set up you will need to check the support software -
1) Internet Explorer - IE is coded with Yahoo Messenger and responsible for most functions - Signing in, games, etc. You do not need to make it your default browser but keep it up to date and clean.
2) Microsoft DirectX . This comes pre-loaded on most Windows computers but has to be updated - I am currently on version 11
To start the DirectX Diagnostic Tool, click 'Start', click 'Run', type dxdiag in the Open box, and then click OK
Run through the tabs checking the 'notes' windows for information
The version will be shown on the 'Systems' tab
YAHOO MESSENGER WEBCAM SET UP
Plug in your webcam and visit this site - Hit 'Allow' in the top window and check your cam in the left hand panel.
Do not proceed if the camera fails to work here, but concentrate on your webcam software / drivers
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to Yahoo Messenger 10.
COMPATIBILITY WITH YAHOO MESSENGER
You MUST use Internet Explorer to visit this page, with your webcam plugged in, to check compatibility and automatically download the latest webcam control. Make sure your webcam broadcasts on this page before moving on
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/webcam/mstacamtest.html
CONFIGURE SOFTWARE
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the Yahoo software may have difficulty in locating it. Mine, I just unplug it from the USB and plug it back in, if yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Of all the chat programs, Yahoo is the most painful software to set up but if you follow these instructions you should be ok.
INTERNET CONNECTION
Webcam connected
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
TESTING
> Messenger > My webcam - the warning panel will launch, click 'OK' and your webcam will start. You should be rewarded at this stage with your happy smiling face.
SET WEBCAM DEFAULT
With webcam still running > Messenger > Preferences > Webcam Broadcast > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK
Take a note of any additional software, if you have multiple choice for Camera Source, you may wish to uninstall any redundant webcam software later to prevent conflicts
AUDIO
Open Video and Voice - run through your default equipment and make a test call - click OK
PERMISSION OPTIONS
> Messenger > Preferences > Webcam - make your default equipment selections and who you will allow to view you > Apply > OK
IN USE
When you are both on line and wish to show your webcam > Actions > 'Invite to view my webcam'.
Messenger 10:- > Actions > More Actions > invite to view my webcam. This will launch an invitation on your contacts screen when they 'Accept' your webcam broadcast will start- There can be considerable time lag ( +1 minute) before they see you, so don't be too impatient ( You can check the status on the bottom left of your webcam panel. You can 'drag and drop' the frame to a convenient location by grabbing the top border.
Your contacts may need to configure their connection the same as INTERNET CONNECTION above (Ignoring webcam connected) if they get a "webcam not connected" message
Sometimes you may have to broadcast the 'small image' option from the 'Webcam' menu on the top of your image frames. This happens when one of you is down on resources -its like sending a large photo by email - its quicker if you cut the size down
you can zoom up to 200% from the same menu when the webcam picture comes through
Use the 'Always on top' option from the 'webcam' menu - or your image will disappear under the message window when you type a message
Sep 05, 2010 | Logitech Quickcam E3500 Webcam
I hv yahoo 10 but am not able to activate video calling or even pc to pc calling. how do i start them?
For video calling both parties have to have Messenger 10
For webcam chats your contact can have an earlier version than you
To initiate the video chat click the webcam icon
For webcam > Actions > More Actions - Invite to view
First of all you have to set up your webcam
CONFIGURE SOFTWARE
INTERNET CONNECTION
Webcam connected
TESTING
SET WEBCAM DEFAULT
AUDIO
PERMISSION OPTIONS
IN USE
Aug 15, 2010 | Yahoo Messenger
I press the power button on the front and no fans run
Sounds like your power supply is not supplying 12v to the system. Check all your power connectors are seated properly on your motherboard, if so then i'm afraid you need a new power supply.
Mar 26, 2010 | Gateway 500GR PC Desktop
My ps2 slim wont recognize any disks
1 ) First did u try other disk beside that one if yes and same no respone
2 ) Then try using disk cleaner with anti static liquid
3 ) Let it run about 10 minite
4 ) Try the disk games if no respone
5 ) Open your ps2 and make some cleaning but do not ever touch the lens
6 ) After that try back the games if not respone try
7 ) Listen to the disk spining or not if no mean the spinner broken or part in ps2 mean cost a money if yes i think your lens must be replace
Dec 01, 2008 | Sony PlayStation 2 Slimline Console
Computers & Internet Logo
26 people viewed this question
Top A4tech Computers & Internet Experts
micky dee
Tony
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
