SONY MHC-GNV99D display not working
When I power on other lights are on but no display. everything functioning correctly. But with out display.
  • 250 Answers
SOURCE: display don't work
This is a pretty hard problem to solve. First of all you need another display, and then you need to unsolder all the connections to the existing display and then solder in the new display. There are about thirty soldering points, so you will need to be able to solder really well. The alternative that I have found which works OK for me is to shine a torch onto the display. You can then see it FAIRLY well. Hope this helps you.
Posted on Dec 03, 2008
smarthome2
  • 1114 Answers
SOURCE: dvd not playing.c 31 00 occur
The only thing you can do is get a CD DVD player cleaner with liquid. Found at any store these days, then run it a couple times. If it plays, Problem solved, if not, it must be repaired. They will put a new transport in the unit. Usually runs 100-150 to replace. Weigh the cost to fix vs. the cost to replace and the age of the unit before you get it repaired. Hope this helps
Posted on Jun 02, 2009
SOURCE: my sony MHC-GX450 has power but does not function,
Mine did the same thing. I unpluged , and carfully took top off where I found a CD stuck. I carefully rermoved CD and put back together. When I plugged it back in I heard a click and the display lit up and I was good to go. I might have just lucked out.
Posted on Jun 18, 2009
fieldy14
  • 456 Answers
SOURCE: sony mhc-dx5 power protect
something inside the unit has become faulty electronically, otherwise if u have moved the unit with cds inside, they may be out of allignment and causing the unit to go into protect.
Posted on Jul 06, 2009
  • 4234 Answers
SOURCE: sony Mhc GS100 want power up
The unit is in protect mode because a problem was deteected in the final output stage of the amplifier. The pop in the speakers is a god indication that there is DC current in the output stage. This is not a good thing. This is a relatively common failure of all receivers and can easily be fixed by any shop that does audio repair. Expect a parts cost in teh $30-$40 range.
Dan
Posted on Aug 19, 2009
Sony MHC-GS200 does not play CD's and emits a squealing sound when unit is powered on. Sound comes from CD compartment even when Radio is selected. Carousel will not rotate either.
The only way to find out will be to open it to view the CD area. Then power it up. And watch what happens.
It could be a foreign object in the mechanism.
Nov 30, 2016 | Sony MHC-GS200 CD Shelf System
Mhc-rg222 red light blinks power button wont turn on unit
Check the back of the unit for speaker wire shorts, if everything looks fine suspect the output ic's in the stereo.
May 26, 2012 | Sony MHC-RG222 CD Shelf System
I have a Sony MHC-ZX70DVD unit, when turned on the display shows the radio working but ther is no audio output through to the speakers or headphones at all. Also the CD/DVD player woun't eject and all...
From Sony's Trouble Shooting site:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C154211&fes=true&mdl=MHCZX70DVD
If none of this helps, I suggest making sure your wires are correctly connected from your CD player to the speakers. Also, make sure no exposed wires are touching, it should make an audible hiss if they are touching anywhere.
If none of this helps, then I suggest taking it back to where you got it, may just be a dud.
Hope you get it working though,
Cheers.
Mar 09, 2011 | Sony MHC-ZX70DVD System
I have a SONY MHC-GNV99D. The display shows locked and the disc tray does not open. it flashes "locked". How to open it. Plz help
check underneathe, sometimes there is a key that may be locking it. i had a sony with a tray that had a plastic key.
Aug 29, 2010 | Audio Players & Recorders
I've sony mini hifi MHC-GZR88D. flicker
cold reset your hi fi system, by powering on your system then while holding stop button press disc 3 and power at the same time.
Feb 10, 2010 | Sony Electronics - Others
My sony MHC-GX450 has power but does not function, power light just blinks. Any advice would be great!
Jun 11, 2009 | Sony MHC-GX450 CD Shelf System
DEST ERROR CODE
I HAVE A SONY MODEL MHC GNZ55D AND IS WRITING DEST ERROR ON THE DIS PLAY AND CANNOT LOAD OR OPEN DISC TRAY PLEASE HELP AM A TECHNICIAN
Display indicates 'DEST ERROR' when any DVD functions are used.
May 16, 2008 | Audio Players & Recorders
Defective sony vcd Model MHC-VX33
If it havent been use for a long time try dusting it and cleaning it first, sometimes dirt gets stuck on vital places which makes it go crazy. Hope this works. Please dont forget your rating for me as well...We take time in answering problems. Thanks
Jan 25, 2008 | Audio Players & Recorders
29 people viewed this question
 Grubhead
Grubhead
