Question about Microsoft Windows XP Home Edition
How to fix error 80244019
Getting error 80244019 during windows update
3 Suggested Answers
Fardinfard
  • 392 Answers
SOURCE: Unable to check for updates with Windows Vista
I've been having the same error when I try to run Windows update on a Vista Ultimate machine setup for use with our SBS 2003 server running ISA 2004.
The Solution that I found is this.
When you setup Vista for use with a domain it creates the following regkey with a subkey etc ( policy ) that sets Vista to look for a WSUS server.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate]
"WUServer"="http://serversbs"
"WUStatusServer"="http://serversbs"
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU]
"NoAutoUpdate"=dword:00000000
"AUOptions"=dword:00000004
"ScheduledInstallDay"=dword:00000000
"ScheduledInstallTime"=dword:00000003
"NoAutoRebootWithLoggedOnUsers"=dword:00000001
"RescheduleWaitTime"=dword:00000001
"UseWUServer"=dword:00000001
When I deleted this key and rebooted my PC windows update was working.
Hope this was somehow usefull
source: http://www.vistax64.com/vista-general/3421-windows-update-error-code-80244019-a.html
Good luck
Posted on Feb 24, 2009
  • 489 Answers
SOURCE: my windows can't check for updates (windows vista home premium). it's showing error code 80244019
Press Win+R, type 'services.msc' and press Enter. Respond to the UAC prompt. Check that Background Intelligent Transfer Service is started and its startup type is 'Automatic.' (It can also be Automatic (Delayed Start).) If it is not started, right-click on it and select Start. Scroll down to Windows Update to make sure that it is started and it startup type is 'Automatic' or 'Automatic (Delayed Start).' If it is not started, right-click on it and select Start. If you had to start either service, try to run Windows Update again by clicking on Start -> All Programs -> Windows Update.
Posted on Apr 14, 2009
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem if you need more help with this post a reply with the error message details Hope it helps.
Jan 11, 2013 | Microsoft Windows XP Home Edition
How to fix error code. STOP: 0x0000C1F5
This issue occurs because the Common Log File System (Clfs.sys) driver does not fix the $TxfLog file when the file is corrupted. In addition to the Stop error message, Windows Vista may not start during startup until the offending disk is removed from the computer.
Support for Windows Vista without any service packs installed ended on April 13, 2010. To continue receiving security updates for Windows, make sure you're running Windows Vista with Service Pack 2 (SP2).
To fix this allow Microsoft Windows to update you to the latest service pack.
http://windows.microsoft.com/en-US/windows7/Install-Windows-updates
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Sep 18, 2010 | Computers & Internet
During Window Update error Code: 80073712 is found
To fix it,
Click the start pearl, type CMD on the search line, right click CMD.exe on the Menu above, click "run as Administrator". On the command line type the following command:
reg delete HKLM\COMPONENTS /v StoreDirty
also navigate to C:\Windows\winsxs, and delete a file called "Pending.xml" [its on every vista install if you can see it or not]
you will need to enable "show all files" and uncheck "protected operating system files" from "folder options" in control panel
Jul 07, 2010 | Dell Vostro 200 PC Desktop
My windows can't check for updates (windows vista home premium). it's showing error code 80244019
Apr 14, 2009 | Microsoft Windows? Vista Home Premium...
Windows can't check for updates. Error code 80244019
you should run system recovery so as to remove some unw
nted programmes
Mar 30, 2009 | E-Machines eMachines Desktop PC
Unable to check for updates with Windows Vista Home Premiun, SP1, 32 bits, error code 80244019 for Windiws Update and 0x80244019 for Windows Defender, last update instaled Jan/01/09
Good luck
Feb 23, 2009 | Microsoft Windows Vista Home Premium with...
Error 1935
The first step is to make sure ou have all of the latest windows updates. This problem could also possibly cause the windows updates not to install correctly as well, so let me know if you get an error when trying to install the updates. If not, make sure to reboot after the updates are installed then try to re-install the surpac software.
Let me know if this fixes the issue or not.
Dec 28, 2008 | Microsoft Windows Vista Ultimate Edition
Intel cpu ucode loading error
You need to update the BIOS.
Go here to get the update, enter...
Product: motherboard
Series: Socket 775
Model: P5VD2-VM SE
Operating System
ASUS Download Link
Oct 16, 2008 | EliteGroup L7VMM2 Motherboard
Fixing error number for windows xp
If you tried exiting Windows Update, waiting 10 to 15 minutes, and then starting Windows Update again, or if you allowed Windows Automatic Updates to install updates during its 24-hour time cycle, and the error message still persists,
Other methods to solve issue:
Click Here
Sep 14, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
26 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
