Sensor pressure switch pictures - Washing Machines
  • Washing Mach... Master
  • 17,130 Answers
Please check this link Pressure switch
Posted on Jan 11, 2013
2009 cummins isx cm871 fualt code mid 128 sid 372 fmi 1
[PDF]Fault codes .pdf - heavydutypowertrain.Com
www.heavydutypowertrain.com/md200codes.pdf
Description. Sample Fault Code Chart. Sample Display. 128. PID/SID FMI. MID. 110. 003 ... MID 128 - CAT. CAT. PID/. SID. FMI Fault. Code. Fault. Description. 1. 11. 72..... Injector Metering Rail #1. Cummins (Continued). PID/. SID. FMI Fault. Code ...372. Fuel Pump Control Module. 12. 374. Fuel Pump Control Module. 13.
2009 Volvo ISX Cummings Codes ' TruckersReport.com Trucking Forum ...
www.thetruckersreport.com > ... > Volvo Forum
Sep 13, 2013 - Well my truck finally stopped today and has these 6 codes. Anyone have any idea what they are? MID 128 SID 380 FMI 11 MID 128 PID 131 ...
[PDF]Diagnostic Fault Codes For Cummins Engines - Allied ...
www.alliedsystems.com/pdf/Wagner/Forms/80/80-1044.pdf
Dec 18, 2015 | Cummins Signature ISX QSX15 Series Service...
Is there a oil safety switch on 2002 Chevy s10 zr2
You have a oil pressure switch which is located by the oil filter,it is screwed into block,just removed electrical connector,get wrench and remove.
  • When the oil pressure is either high or low it will either turn the oil light "on" in the dash or move the gauge to the extremes
  • Undetected high or low oil pressure can result in internal engine damage and/or gasket leakage. Here's a picture of what it look's like.
http://www.autozone.com/external-engine/oil-pressure-switch/duralast-oil-pressure-switch/chevrolet/s10-p-u-2wd/2002/6-cylinders-w-4-3l-sfi/31135_652060_8450
Aug 10, 2015 | Cars & Trucks
Adding to my question about the correct location of the oil pressure switch. The car is a 2002 Hundai Accent GL. I need a PICTURE OR DIAGRAM of the location on the engine to make sure I'm working
location of oil pressure sensor on 02 hyundai accent gl with a 1.6 liter engine is driver side front of engine. lower near the bottom of the radiator.mind you that is for a 1.6 l
Apr 18, 2013 | Hyundai Accent Cars & Trucks
I have a code p0453 is a ford fiesta 2012 what's the probleme
P0453 FORD - EVAP Pressure Sensor/Switch High
Possible causes- Evaporative Emission System (EVAP) Pressure Sensor/Switch harness is open or shorted
- Evaporative Emission System (EVAP) Pressure Sensor/Switch circuit poor electrical connection
- Faulty Evaporative Emission System (EVAP) Pressure Sensor/Switch
- Damaged fuel tank pressure sensor
This likely is an emission system warranty problem.
Oct 15, 2012 | Cars & Trucks
THE "SWITCH" GOES BAD EVERY
Please look at the list below, keeping in mind that this is not an exhaustive list of the switches that your vehicle is equipped with. After staring at the list for a while, tell me what is wrong with your question.
>> A/C High Pressure Switch
>> A/C Low Pressure Switch
>> A/C Refrigerant Pressure Sensor / Switch
>> Ambient Temperature Sensor / Switch HVAC
>> Blower Motor Switch
>> Brake Fluid Level Sensor/Switch
>> Brake Fluid Pressure Sensor/Switch
>> Brake Light Switch
>> Brake Switch (Cruise Control)
>> Cabin Temperature Sensor / Switch
>> Combination Switch
>> Coolant Temperature Sensor/Switch (For Computer)
>> Cruise Control Switch
>> Door Jam Switch
>> Door Sensor/Switch (For Alarm)
>> Door Switch
>> Driver Information Center (DIC) Switch
>> Engine - Coolant Temperature Sensor/Switch
>> Fog/Driving Lamp Switch
>> Fuel Door Switch
>> Garage Door Opener Switch
>> Glove Box Lamp Switch
>> Hazard Warning Switch
>> Headlamp Dimmer Switch
>> Headlamp Switch
>> Heated Glass Element Switch
>> High Pressure Sensor / Switch
>> Hood Switch / Sensor
>> Horn Switch
>> Ignition Switch
>> Ignition Switch, Buzzer
>> Low Pressure Sensor / Switch
>> Neutral Safety Switch
>> Parking Brake Release Switch
>> Parking Brake Warning Switch
>> Power Door Lock Switch
>> Power Mirror Switch
>> Power Seat Switch
>> Power Window Switch
>> Pressure Cycling Switch
>> Rear Defogger Switch
>> Remote Switch
>> Seat Belt Buckle Switch
>> Seat Heater Switch
>> Seat Memory Switch
>> Shift Interlock Switch
>> Sunroof / Moonroof Switch
>> Telescoping Wheel Switch
>> Tilt Wheel Switch
>> Traction Control Switch
>> Transmission Mode Switch
>> Transmission Temperature Sensor/Switch, A/T
>> Trunk / Liftgate Switch
>> Trunk/Liftgate Sensor/Switch (For Alarm)
>> Turn Signal Switch
>> Underhood Lamp Switch
>> Valet Switch
>> Washer Fluid Level Switch
>> Windshield Washer Switch
Aug 17, 2011 | 2001 Cadillac DeVille
Is it possible for me to replace the oil sensor switch on my 2000 catera and if so how?
Yes, the sensor is usually near the oil filter. It takes a big deep well socket. 19 or 21mm, something like that. I have pasted the procedure below. The sensor looks like the picture below.
Please let me know if you have more questions, and thanks for using FixYa.
  1. Raise and suitably support the vehicle.
  2. Remove the 4 splash shield bolts.
  3. Remove the splash shield.
  4. Disconnect the electrical connector from the oil pressure sensor/switch.
  5. Remove the oil pressure sensor/switch.
    NOTE Use a catch basin to catch escaping oil.
To install:
NOTE Replacement components must be the correct part number for the application. Components requiring the use of the thread locking compound, lubricants, corrosion inhibitors, or sealants are identified in the service procedure. Some replacement components may come with these coatings already applied. Do not use these coatings on components unless specified. These coatings can affect the final torque, which may affect the operation of the component. Use the correct torque specification when installing components in order to avoid damage.
  1. Install the oil pressure sensor/switch. Tighten to 30ft.lbs. (40 Nm).
  2. Connect the electrical connector to the oil pressure sensor/switch.
  3. Install the splash shield.
  4. Install the 4 splash shield bolts and tighten the splash shield screws until fully seated, do not over tighten.
  5. Lower the vehicle.
Apr 12, 2011 | 2000 Cadillac Catera
Where do you find the oil pressure sensor for 2006 F-250 superduty Diesel
The oil pressure sending unit on a 6.0L is found on the top of the engine just a little in front of the oil filter. Here is a picture but it might be hard to see. On the right hand side of the picture it says Oil Pressure Switch, try to follow that arrow. Sorry the picture is so blurry
Feb 13, 2011 | 2006 Ford F-250 Super Duty
93 FORD TAURUS SHO 3.2 ENG WHERE IS THE OIL PRESSURE SENSOR?
If you're in front of the car facing the engine, it's on the front upper right side of the engine just to the
right of the temp. sensor. Hope this helps.
Nov 20, 2010 | Ford Taurus Cars & Trucks
Where is the oil pressure sending unit on my '98 chevy s10 blazer 4.3? and could you send me a pictures of where it is?
on the top left side of engine near the distributor/high voltage switch sorry dont have picture
Mar 30, 2010 | 2003 GMC Sonoma Extended Cab
Oil Pressure Problems, leaks
I believe what you're looking for may be called an oil pressure switch or oil pressure sensor instead of an oil sensor. If this is correct it should be easy to locate at almost any local auto parts supplier or online at places such a www.rockauto.com. Rock Auto has an easily searched catalog and the prices seem reasonable. Also there are pictures of the part.
If what was removed is an oil pressure unit and the engine is started oil will definitely be pumped out of the engine. I hope this is of some assistance.
Nov 27, 2008 | 1994 Pontiac Bonneville
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
