Netgear router only allows me to get to Google domains?????
A new apartment we just moved into for temporary housing has a Comcast connection with a netgear router.  Google.com works fine, but anything else fails. All the other data connections work wirelessly, but the browser can resolve or load anything.  Typing the IP address doesn't work either. Ping works but nslookup returns: default server unknown.
DNS? PTR record? Not sure how to fix any of that in Vista.
Thanks for any help!
  • 79 Answers
I would try to reset the router to factory default to do that unplug the router for 30 sec or at the back of the router, there should be a small hole where u can stick a paper clip. stick it in there and hold for 30 sec the hole should say reset.
Posted on Jan 22, 2009
Connecting MacBook or NetGear Router to Comcast
As a Comcast tech I assure you there are no special protocols used on a standard residential installation. There should have been nothing the tech downloaded to your pc most especially an executable file. I would assume he or she was making sure you were able to get to the customer installation page before they left. However if you have a router that the ports are not functioning on you are most welcome to have one shipped to your home for replacement. The wifi key provided on the bottom of the router is case sensitive most generally all in caps. If you dont have a spare cat5/6 cord to see if thats the issue ask them to send one with the new modem. Comcast does not charge you a fee for a truck roll when its faulty eqt. of their own. I have installed hundreds of apple products including the ones you are referring to as well as netgear routers they all work with the gateway Comcast provides the customer. Now if you want there is a tiny factory reset pin button at the very top of the gateway in the back you will need a paper clip to push it in. Hold it in there about 10-15 seconds and the gateway will reboot and return its setting to factory spec. try that first before calling customer service.
Jan 07, 2013 | Comcast XFINITY
Tip
Keyword blocking and parental control features on NETGEAR routers
The below steps illustrates the required troubleshooting procedure to configure keyword blocking and parental control features on NETGEAR routers.
Applicable routers are WGR614, WPN824, WGT624, WNR2000, WNR1000, WNDR3300, WNR854T, WNR834B etc:
Login to the router page using the below steps:
1. Connect a computer to the router using any one of the 4 available ports.
2. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
-In the routers configuration page, under the Content Filtering Section
- Select Key Word Blocking
Key Word Blocking is:
If you want to limit access to certain sites on the Internet, you need to set up content filtering. There are two ways to filter content:
* blocking access to certain domains (for example, www.badstuff.com/XXX) or
* blocking sites that contains certain words (like profanity or explicit sexual material).
When users try to access a blocked site, they will get a message: "Blocked by NETGEAR".
-To Enable Site Blocking:
Click Per Schedule to turn on Site Blocking and block according to the settings on the Schedule page.
Click Always to turn on Site Blocking to allow blocking all of the time, independent of the Schedule page.
Note: On the Schedule page you can set when keyword and domain name blocking occurs.
To Disable Site Blocking:
Click Never to turn off Site Blocking.
-To Block Keywords Or Internet Domains:
1. Select when to turn on Keyword Blocking (Never, Per Schedule, or Always).
2. In the box where you see Type Keyword Or Domain Name Here, type the word or domain name you want to block.
3. Click Add Keyword.
4. The word or domain name will appear in the list below.
5. Continue adding names and keywords until you are finished.
6. Click Apply when finished.
Block List - The list under the heading "Block Sites Containing these Keywords or Domain Names" contains the current list of items to block.
To Delete A Keyword Or Domain Name:
1. Select the word or domain name in the list.
2. Click Delete Keyword.
3. Continue selecting and deleting names and keywords until you are finished.
4. Click Apply.
To Delete All Keywords And Domain Names:
1. Click Clear List.
2. Click Apply.
To Allow One Computer To Have Unrestricted Access To The Internet:
1. Select the Allow Trusted IP Address To Visit Blocked Sites check box.
2. Type the IP address of the computer in the Trusted IP Address area.
You should only need to type a number in the last box.
3. Click Apply.
To Allow Unrestricted Access To The Internet:
1. Select Never in the Keyword Blocking menu.
2. Click Apply.
on Mar 18, 2010 | Computers & Internet
At least once a day I have to re boot my router so my wireless gear can pick up the signal. Why?l
After checking ALL cables and reseating connections, checking for bent pins, Contact Comcast have them analyze the signal. And have a Comcast Tech come out and trace the signal through the house. It may be outside. I had a similar issue, the problem was outside, a underground box had been run over by a big lawn mower damaging the box allowing water to enter.
Dec 28, 2012 | NetGear N300 Wireless Router
Internet status light on netgear wireless n300 blinking. internet service on and off. 2 macs in house.
You can do a reset on the router to make a factory settings.On the back of the router you can look for a small hole usually with the word reset.Press it for 20 secs with the router on but disconnected from the Ethernet cable.Start up your PC and surf to the router Web UI (192.168.***) and make your settings.
May 26, 2012 | NetGear WNR2000 Wireless Router
I have several computers in my house, and just purchased a Netgear N600 High Performance Router. All computers easily pickup the signal and connect to the new router. However, one of my computers using a...
you might try moving your computer closer to your router
make sure your routers and your dell 1450 settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet if applicable
hope this helps
Jan 26, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Is netgear compatible with comcast broadband service
Yes the NetGear router is compatible with Comcast. You'll just connect the one 'computer' output from the Comcast box into the WAN input on the NetGear box, and in the outputs from the Router plug it from there to your computer.
Nov 22, 2009 | NetGear RangeMax WPN824 Wireless Router...
Wireless router connection problems
That is very possible. I would reset the router by reset switch on back. Also both routers will tend to build up a static charge loosing the connection. You can unplug it for 10 seconds and replug in.
I would also try setting up new home network using automatic settings.
Jun 23, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
PS3 online game (NFS Undercover) not working on new router.
I might advised you to call the PS3 manufacturer to gather the ports of the PS3 then you'll needing the help of netgear provider to open the ports of the PS3 to the router, so that the PS3 will allow to the firewall of your router.
Mar 11, 2009 | NetGear WGR614 Router
Can only access internet if computer connected to router is on
Reset the router to factory default and then set it up again. See page 7-7 (75 in the reader) in this user manual to reset the router.
http://kbserver.netgear.com/pdf/wpn824_ref_manual.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 11, 2009 | NetGear RangeMax WPN824 Router
In Italy, have Netgear router, can only get google
The first thing to do is ensure they haven't been blocked in the router. To do this, log into your router and click Block Sites on the left hand side. If they are not displayed there, make sure it's not a DNS issue. To do this, log into your router and click Basic Settings. The change your DNS servers, to the OpenDNS servers; 1. Locate "Domain Name Server (DNS) Address " 2. Change the setting to "Use These DNS Servers" Primary: 208.67.222.222 Secondary: 208.67.220.220 3. Click Apply, and re-boot your router IMPORTANT: If your router is already set to "Use These DNS Servers", make sure to make a note of the IP's already in there, just incase you want to switch back, or the OpenDNS servers do not work (unlikely but possible). Once re-booted, try accessing the previously blocked websites. If you find they are still unavailable, check they aren't blocked directly on your computer (e.g. via a firewall or other security product). To do this, click Start > Run and type: CMD At the prompt, enter the following and press return (do this for each line below); nslookup {BLOCKED_DOMAIN} >> nslookup.txt tracert {BLOCKED_DOMAIN} >> tracert.txt Where {BLOCKED_DOMAIN} is one of the domains you cannot access. nslookup will provide the website's current IP for you. Aslong as this is NOT an internal IP (169.*, 172.*, 192.*, 10.*), it is resolving correctly. Tracert will allow a trace connection from your computer, to the affected websites. Lines you do not want, will contain a *.
May 25, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
